Question about Sony MDR-023 Consumer Headphones
Need replacement foam ear pads for Sony MCR-023 headphones. Where can I get them?
4 Suggested Answers
Grubhead
  • 5487 Answers
SOURCE: replacement foam ear pads for headphones
Try this site: JNTWorld. I highly recommend it.
Posted on Aug 11, 2010
SOURCE: ear pad replacement instructions for Sony MDR-V6 Headphones
Hello to all who have exhausted all avenues seeking instructions on how to remove and replace Ear Pads on Sony MDR-V6 Headphones.... All that is required is a little patience maybe some fingernails... The Pads simply slip on and off by pinching ends of cuff that is nearest the plastic backing of The Headphones by pulling them from their seat/flange .. i found it easiest to just roll the cuff off using my thumb w/rolling motion away from the plastic backing/housing of the headphones.. no tools required.. they are installed exactally like one would place a tire on a rim.. exact same motion is required as when removing a tire.. i can give no better illustruction than comparrison to tire removal and replacement. Be careful to make sure one end in completely set deeply into one side before attempting to pull opposing side over its side/flange..start on top and work way around to bottom or vise versa.. To get an idea of what you are attempting to do take a close look at new headphone pad rear and you will see the small flap of leather on rear .. there is a small overlap that fits perfectly over the flange.. dont try to force it as you may tear them...
Posted on Nov 14, 2008
SOURCE: My Motorola S305 stereo bluetooth headphones' foam
Hey, this might be too late to help you, but I figured I'd share in case anyone else came across this while looking for help (as I did).
There's a small inner ring that the edge of the foam ear pads wraps around, but you can't really fit it under there while it's attached to the earpiece. The solution? I used something thin (specifically a nail file) to remove this "ring". It actually seems designed to pop on and off. I was then able to easily wrap the foam ear pad around the ring, then re-attach the ring to the rest of the earpiece.
Hope that helps!
Posted on Feb 27, 2011
Testimonial: "I figured this out a month or two ago, but it's good to see someone else put it online for others to find. In my case, I found a credit card worked."
Replacement foam ear pads
Yes you can. Go to my blog site and you will see a link to a place that sells them.
Apr 12, 2014 | Philips SBC HP400 Headphones CS01 Stereo...
The thin black material covering the foam ear pads is flaking off and getting on face, ears and clothing. Can we get replacement pads? Dennis Christian
Yes there's a firm that might have them, you'll find it at the bottom of my tip on headphones. Just click my user name to find it.
Feb 21, 2011 | Labtec 835 Headphones
I'm looking where to buy sony mdr-rf970r ear pads
https://servicesales.sel.sony.com/ecom/accessories/web/productSearch.do?searchOperation=modelSearch&searchText=MDRRF970RK&sessionId=FLk3TTjKj9RC2AYaSnUQb_k
This is the link from sony style for accessories and online ordering for your headset. Hope this helps.
Oct 03, 2010 | Sony MDR-RF970RK Headphones
My Motorola S305 stereo bluetooth headphones' foam pads on one of the ears is falling off. I've tried using something like a credit card to pinch the foam back into the game where it seems to be held in,...
Hope that helps!
Sep 28, 2010 | Motorola Stereo Bluetooth Headphones
Need earpad replacements for Optimus Pro-100 Wireless headphones
Just flip the headphone pad inside out on the Optimus Pro 100 wireless headphones.
Find the 3 screws on each headphone speaker, you have to push the existing cover back, but you'll find them. Remove the 3 screws. Be careful of the speaker wire that will be attached to the cover plate that has the ear pad on it. Also, look carefully at how the components are assembled inside the headphone, as you might disturb their setting. They are easy to return to their proper place if they move.
Gently remove the ear pad, turn it inside out and you will have a new covered ear pad. GENTLY, re-install ear pad onto speaker plate, be careful not to break the speaker wire that is attached. I found a little flat screwdriver helps to pull the edge of the pad over the plate. The ear pad is actually quite strong and can take some abuse, but don't pull the speaker wires loose.
After you have the cover back on, find the screw holes and put the 3 screws back in. Presto, a little cleanup on any loose pieces of covering from the original side and your done for another couple years or so.
Feb 26, 2010 | Audio Players & Recorders
Need replacement earpads for Sony FM/AM Walkman SRF-H4 headset radio
LIKE YOU ALL, NO CURE OR REPLACEMENT FOR THE ROTTED PADS. WENT TO HOME DEPOT AND BOUGHT ECONOMY PLUS BRAND AIR CONDITIONER FILTER MATERIAL, ABOUT $3.00, FOR A WALL AC. THEN WENT TO DOLLAR GENERAL AND BOUGHT SCUNCI BRAND BLACK HAIR ELASTICS, EIGHT OF THEM FOR $2.00 TO KEEP PONYTAILS, NOW EAR PADS, IN PLACE. CUT THE AC MATERIAL TO FIT, AND ATTACHED WITH HAIR ELASTICS. ONLY A PURIST WOULD COMPLAIN ABOUT LACK OF COLOR MATCH. THERE WAS A SOLUTION, ONLY A MATTER OF FINDING IT. GOOD LUCK ALL OF YOU. R J BURNS, PENSACOLA, FL
Jul 17, 2008 | Audio Players & Recorders
Sansui SH-15 Headphones - need foam ear pad cups - Toronto
Those headphones (I have a pair - they are rather nice, aren't they?) are over 30 years old and I doubt you'd be able to find any 'official' replacement pads. My suggestion would be to check out cheap headphones with the same sized pads and cannibalise them. If you do find any replacement pads specifically for the SH-15's, then I would also be buying a lottery ticket and maybe bet on a few horses, because you would have to be one lucky person.
Feb 05, 2008 | Radio Communications
Sony MDR-023 Consumer Headphones Logo
1,085 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
