Question about Panasonic DVD-RP56 DVD Player
Does not read disc including cleaning disc
When a disc is put in, it tries to read but is not successful and ends up with stop and shows a H02 number.
    Problem Solver:
  • 13 Answers
The problem with your unit is the "Spindle Motor", this motor is the one that spins the disc so the laser can read it. I sugest you to take your player to a shop, or back for service if the unit still under manufacturer warranty.
Posted on Jun 23, 2008
Panasonic Model No. DMR-ES35V DVD Recorder error message H02
check it out this link, maybe can help you https://www.ifixit.com/Guide/Repairing+a+Panasonic+SA-HT810V+with+the+H02-H07+error/2708
Try to clean reading head from vhs player with isopropilic alcohol, maybe is dirt and give this error.
Good luck !
Dec 03, 2017 | Panasonic Dmr-es35vs DVD Recorder / Vcr...
Hi, I own a VK 90D, It was satisfactory only until about 2 months back. I started gettin DVD H05 error. It became ok after i disconnected and tried again.. But only today i got error DVD H02 n no dvd...
H02,H05,H07 is an error code in Panasonic home theater system and dvd player which appear after an unsuccessful loading of DVD,CD. This is commonly caused by a faulty lens assembly and the main board. If you want to troubleshoot it yourself, here are some basic steps that may guide you. Assuming that the disc is good.
1.Clean the lens. - Sometimes because of dust build up and some tiny foreign objects the lens can't read any disc. Try clean the lens by soft cotton buds. Be careful while doing this.
2.Replace the ribbon - Check the ribbon connected to the lens from the main board for scratch, damage. Once it has an open line then of course the lens can't read the disc. Also try to erase the contact by pencil eraser. If you've done the steps above and the symptoms still there then the next step requires you a little knowledge in soldering technique and reading the ohmmeter.
3.Check the motor - Check the motor that spin the disc with an ohmmeter. You can test it using the ohmmeter (x1) even it is connected on the lens assembly.Good motor - reading should be fairly high and it will spin. Bad motor- reading will drop to low resistance and will not spin.
Hint : 50% of my repaired unit the above parts are commonly caused of the problem.
If you confirmed that you have a defective motor then replace it with a new one. Before replacing the new motor you have to check the clearance of the disc holder with the old one. The clearance should be the same as the old because if not the lens will not read the disc if it is too far or too close.
If you already cleaned the lens, and confirmed that the ribbon is good as well as the motor then the fault is either on the optical lens and the main board. It is technical to diagnose the fault between the two, I will advice you to send it to panasonic service center to isolate the problem.
Hope it may help you.
Have a nice day!
Feb 10, 2011 | Panasonic Audio Players & Recorders
I have a panasonic RV26 DVD player. After inserting DVD it goes to the reading mode (normal) but it stays on the reading mode for awhile then code H02 shows and then stops and and will not accept any other...
The Optical head or the mother board is defective. The data is not received and so the Mp is not able to read or process.
hence if have cleaned the optical head lens, and there is no reading try to put in a audio cd to test. If the cd is read the head must be Ok and the DVD processing must be faulty possible board issue but if there is no reading then the optica head is faulty
Aug 30, 2010 | Televison & Video
Code H02
Your DVD player is having an issue with the spindle motor (the thing that spins the DVD around). The following solution works for most people, and you should only have to do this once.
  1. Unplug the DVD player.
  2. Take the cover off.
  3. Place a disc on the spindle.
  4. Put a little pressure on the disc (so it doesn't slip) and spin it around a few times.
  5. Remove the disc, reassemble, and plug back in.
  6. Try to play a DVD.
  7. Report back if this solved your problem, or if more troubleshooting is needed.
Aug 02, 2009 | Panasonic DVD-S55 DVD Player
I keep getting error code H02 after cd is in machine
Remove the cover from the player, usually a few screws on the sides and back. You will see the changer and the drive at the back (Panasonic SC-PT750). Start the play sequence and while it is attempting to read, gently start the the disk spinning near the center in a clockwise direction with your fingertip. The motor should kick in at this point. Others out there (and me) have left the cover screws out, as it will not be the last time you have to do this most likely!
Nov 20, 2008 | Panasonic Audio Players & Recorders
H02 Error after inserting a dvd disk
The trouble started with an error to close and open the DVD drawer. It indicated "close" when the drawer was open, or "no disc" when the DVD was inside, and I had to try many times before I get the right response and go on with the procedures.
But then it also started playing just a few MP3 tracks and stopping to work, showing again the inserted DVD data. Later H02, and then H07 and STOP. It doesn't even start playing stuffs, movies or MP3 tracks!
Aug 11, 2008 | Panasonic Televison & Video
H02
This weekend we were watching a movie. It started to skip. I thought it was a dirty disk, took it out, cleaned it with a dry cloth and put it back. Now nothing will play.
When I insert a disk it starts to revolve the machine says reading, two zeros appear and the it stops. My wife noted a message H02 and the manual says to call for an explanation.
We tried turning the machine off and on and we tried pulling the plug -- no luck. What is the problem?? Jeff
Apr 06, 2008 | Panasonic DVD-RP56 DVD Player
Error H02
I had the same problem and found that the motor that spins the cd so it can be read would start and stop. I opened the case removed the assembly with the motor and placed a drop of 3in1 lightweight oil on the shaft of the motor ran it a few times and now it works perfectly fine. Good luck hope this helps you as well.
Dec 21, 2007 | Yamaha DV-C6480 Multi-disc DVD Player
No Picture
i think this means it is dying. mine started to skip and then promptly stopped reading the disks too. i was told it may be the optical lense and it may be better to buy a new one than have it fixed. my problem now is that i can't find a replacement that is not upconvert (i see no difference in the component cables vs. hdmi). i am sad to lose this player. love it.
Jul 25, 2007 | Yamaha DV-C6480 Multi-disc DVD Player
Panasonic DVD-RP56 DVD Player Logo
85 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
