Question about Hitachi 42HDS69 42 in. Plasma Television
My Hitachi T.V.42HDS69 the HDMI jacks are not working.
The problem with my Hitachi T.V.42HDS69 is that none of the HDMI input jacks no longer work. Only the A.V. cable jacks work. The HDMI jacks did work for a short period. Anyone else have this peoblem?
skippy101
  • 143 Answers
SOURCE: No hdmi signal
you have to take it in to a authorized service senter and update firmware sorry
Posted on Nov 20, 2007
  • 103 Answers
SOURCE: HDMI Malfunction
You may have to activate that imput through your menu.Alot of plasmas have the ability to mute imputs.
Posted on Mar 03, 2008
ebrus
  • 30 Answers
SOURCE: 42HDS69 cable input is only thing working
You need the original remote controller to be able to switch input modes.Universal ones usually don't work. If youdon't have the original remote and can't find it ever then the only way to reachyour tv is through coaxial antenna port. Soyou can buy an rf modulator ( very cheap) and connect your red yellowand white cables (rca cables from a dvd, game consoleetc) to the modulator then connect the modulator to your antenna with acoax cable. This worked for me. It placed the connection to channel 4and other channels are still working,
You can buy the RF Modulator from: http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=180299245670
Posted on Oct 15, 2008
SOURCE: Sound Problems with Hitachi 42HDS69
ultravision picture dark no sound
Posted on Aug 19, 2009
SOURCE: Hitachi ultravision model number 42hds69 cable problem.
Usually you need a decoder to receive "Cable" With your "Cable" usually you connect the Cable antenna, to the Cable "Box" form the "Box" to the Audio Visual EXTERNAL inputs, in the back of the TV. Now IF your TV can receive the "Cable" directly, then you would have to connect the Antenna, into the rear of the TV, now you would go to the "Tuning" section, and, the TV, would automatically "Search" for any available channels. They would then, be displayed at the end of the scan. Please find a user manual below, this will help you tune in, IF you can. If you cannot, you will have to get a cab;e "Box" and a remote. Hookup to the TV, from the "Box" to the TV, via, Audio and Video cables. You use the "Box's" remote to change channels and volume. You first must set the TV's Volume, & picture setting, the TV, is basically just used as a "Monitor" for the "Box". Hope this helps..
http://tv.manualsonline.com/manuals/mfg/hitachi/42hds69_55hds69.html
Posted on Apr 23, 2010
How to work the hdmi
how do you set up the HDMI input on a hitachi tv model #51F59A ...
https://answers.yahoo.com/question/index?qid...
Jan 8, 2010 - i tried to hook up an HDMI devise but i cant set it on input HDMI it ... My TV has HDMI, Component and AV inputs, which one should i use for my ...
HDMI not working - Hitachi 50VS69A - AVS Forum ' Home Theater ...
www.avsforum.com/.../948284-hdmi-not-working-hitachi-50vs69a.html
Dec 1, 2007 - 7 posts - ‎2 authors
I have a Hitachi 50VS69A 50 RP LCD HDTV connected to a Dish Network receiver that the HDMI input is not working on. I have been using the ... Hitachi P50H401 - all HDMI ports are dead - HELP!
Oct 2, 2008
Hitachi 51/57/65F59A CRT RPTV Tweaks Thread
Jan 19, 2007
More results from www.avsforum.com
Dec 27, 2015 | Hitachi CLE-960 Remote Control HL02121
HDMI inputs not working
Go to its service mode option, and check whether HDMI port software are installed, and activated. To get more detail about how to activate service mode, http://electronicshelponline.blogspot.com/ check this link. Pull up previous posts there, either by its left side bar, or view it in Timslide option.
Jun 28, 2013 | Hitachi 42HDS69 42 in. Plasma Television
I have lost all my HDMI inputs for my Hitachi L42X01AU, i had my PS3 hooked up and it worked but now when i hook it up none of the HDMI inputs work
try unplugged all units involved---HDMI does not like being hooked or unhooked with units powered and or on.
Wait a while and make the connections and then power set, box, whatever is inline back---the units will try to reboot and that may cure the issue- it is worth trying
Jun 17, 2012 | Hitachi Televison & Video
I just want to know how to hook up a hdmi cord to an old big screen hitachi tv
You can't, at least not directly. Older sets don't have any HDMI inputs, only composite video (the yellow RCA jack) and possibly component video (red, green and blue RCA jacks). Converters that take an HDMI input and generate the necessary video outputs are available, but they aren't cheap. And don't fall for the adapter cables you might find advertised with an HDMI plug on one end and RCA plugs on the other that supposedly convert the signal for you. HDMI can only be converted with some active electronics; a simple cable just won't work. If you want to hook and HDMI-only device to your old Hitachi, you'll need the converter.
Dec 28, 2010 | Computers & Internet
The message: input: hdmi Front keeps showing up in the upper right hand corner of the tv.
Try selecting your input one at a time. What happened is you choose the hdmi as your input but at the back of the tv you connected your input wires (to maybe hdmi2 or input 1 or input 2, etc. Good luck.
Jul 09, 2010 | Hitachi 42HDS69 42 in. Plasma Television
How do I play a PS3 on my 42HDS69 I cant get it to work, I change the input and it does nothing .
I know it seems obvious but have you gone into the PS3 video settings menu and changed output to HDMI (assuming your using an HDMI cable)
Jan 23, 2010 | Hitachi 42HDS69 42 in. Plasma Television
Is there someway to hook up our Hitachi 42HDS69 to our laptop
Your computer should have a DVI port to make this possible since your TV dont have a VGA port. If your computer have a DVI port then an HDMI/DVI cable is all you need. This allows you to connect you computer or laptop to you tv through the HDMI connection on your tv.
Dec 31, 2008 | Hitachi 42HDS69 42 in. Plasma Television
Nov 24, 2007 | Hitachi 42HDS69 42 in. Plasma Television
Hitachi 42HDS69 42 in. Plasma Television Logo
494 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
