Question about SmartParts INC. digital frame. 7.0 in. picture. wood (SPDPF70EW)
SmartParts Model SPX7E has worked for several months, now the display doesn't work and just has a humming sound when I turn the power on. What's going on?
Yes, we bought 3 of these frames and NONE OF THEM DO NOT WORK! They all have a problem with the the display fading in the quality of picture. I do NOT recommend anyone buying this product.
Posted on Jan 04, 2010
I am not sure if that post above qualifies as a solution :o). More like preventative care.
Posted on Dec 07, 2011
How can I transfer my iphoto and itunes slideshow yo my digital frame SPX7E using the USB cable?
Connect the frame to the computer via USB and open Windows File Explorer. The frame will be shown as a volume. Drag files to it, using right click Copy Here from the right pane to the drive in he left pane.
manual
Smartparts Digital picture frame 7 User Manual
Smartparts SyncPix 7 inch Digital Photo Frame SPX7E
May 30, 2018 | Photography
The subwoofer output on my Kenwood VR-606 has suddenly stopped working. I have tried the "setup" several times, turning the subwoofer off and back on. Also, when I first power up the system, it emits a low...
It sounds like the problem is not with your VR-606. If you hear a hum from the sub, the problem is more likely to be in the sub's built-in power amplifier. However, it is worth resetting the amplifier to factory presets. To do this, unplug the power cable from the mains supply and reconnect whilst holding down the power on/standby key. If the hum persists, connect any powered speaker to the sub-out socket, power on and listen for the hum. If no hum then suspect the powered sub amp. Turn the sub on with no connection to the Kenwood VR-606. If hum persists, the sub has a problem and will need to be replaced or repaired. By the way, you said there is a low frequency hum through the 'speakers' for about 30 mins. Is that all speakers or just the sub? Hope this helps.
Cheers, Don.
Jul 06, 2014 | Kenwood VR-606 Receiver
Hyundai accent 2001 will not start all lights work radio works heater fan works battery in 3 months old when I turn the key all i hear is a humming sound for about 1 min. than nothing. weather has be
The humming would be the fuel pump coming on. It should only hum for a few seconds, then shut off.
Your problem is with the start circuit from the battery to the starter, or from the ignition switch to the starter solenoid. Check the connections at the starter (the big cable) for tightness.
Is the battery charged up enough to turn the engine over? Check by turning headlights on and observe while someone turns key to crank. If they dim a LOT, then either battery is too low, or the starter is bad and needs removing for testing. If brightness doesn't change, then the circuit from ignition switch to starter solenoid is likely not working. Check for 12 volts at the small wire to starter solenoid with key in cranking position. If you have power there, the solenoid may be bad. Remove starter for testing. If no power at solenoid in starting position, then either the ignition switch is bad or the neutral safety switch might be the problem, or the wiring from the switch to the starter solenoid is not passing current.
Good luck.
Jan 14, 2012 | Hyundai Accent Cars & Trucks
Hello. We received a SmartParts digital picture frame Model SP800W and it doesn't turn on even with the AC power cord plugged in the wall. There is no sound coming from the frame ( sounded like there was...
Probably more than it's worth! Many of these items were found to be defective when shipped. This is the 41st one of these I have heard about with the same problem.
If you can return it for a refund or swap for another brand.
Please rate my help++++Thanks for using FIXYSA
May 22, 2010 | SmartParts (1DPFSP01) Digital Picture...
SmartParts SP15MW photo frame won't turn on--pwr adptr shows 12 v
It's the power adapter... I had the same problem as of yesterday and today I used the power supply from my HDTV and it worked as good as new. Will have to go out tomorrow and get a new power supply.
Dec 14, 2009 | SmartParts SP15MW (092566981886) Digital...
Toshiba 62HM195, Loud hum noise when TV is first turned on.
I have the exact TV and had the exact same problems. It is the light engine with color wheel that needs to be replaced, and they are VERY hard to come by for this model. Our repairman has had our TV for 5 months and still cannot locate a vendor that carries the part. He said according to Toshiba, the part has been discontinued. If you happen to find one, please post. I'll do the same.
Aug 18, 2009 | Toshiba 62HM195 62" HDTV
SmartParts SP1100B 11'' picture frame won't turn on
sounds like there was a power serge.  One of the suggestions would be to make sure you use the "safely Remove Hardware" tab on the tool bar.  The USB cable actually has power that goes through the line and can damage the flash memory in the picture frame.
your one hope would be to try another USB cable.
Mar 18, 2009 | Computers & Internet
SmartParts Frame SPX7E only allows me to load 165 photos
2 answers...
To remove a picture, connect the frame to your PC via USB. you should see the frame appear as a drive, in my case,
36972 (E:)
open the drive as Explore, you can now see the pictures, and delete what you no longer want.
you can download the software from
http://www.smartpartsproducts.com/content/support/optipix/index.php
Nov 27, 2008 | SmartParts (1DPFSP01) Digital Picture...
Dishwasher fill with water then just hums
the hum is probably the main pump powered up but not turning. the pump is an induction motor and a usual fault is the motor capacitor. try to access it, find the value of the capacitor and replace. it is a cheap part
Apr 02, 2007 | Kenmore 24 in. 16039 Built-in Dishwasher
My Matag dryer does not run, but for a while it hummed before starting.
Motors of this sort have a "start" winding, to give them an extra boost to get them turning. Once they're turning, the start winding shuts off. Critical to this is the start capacitor which, when shorted, causes the exact symptom you've described. The motor's "regular" winding gets power (and then hums), but it needs that extra boost to actually start turning. Have someone check the capacitor (with an ohmeter) or check to see if the motor's start winding is open (broken).
Apr 10, 2006 | Maytag HYG2460AWW Gas Dryer
SmartParts INC. digital frame. 7.0 in. picture. wood (SPDPF70EW) Logo
574 people viewed this question
Top SmartParts Photography Experts
Kazim ERGUNEY
Kazim ERGUNEY
Joseph Hoffmann
Are you a SmartParts Photography Expert? Answer questions, earn points and help others
