Question about HP Computers & Internet
Our HP L1706 monitor has worked perfectly with our Mac Mini for the last two + years. The last four days when we turn it and the computer on a green light on the monitor flashes, no picture, and maybe an hour or more later the monitor will finally display the Mac Mini desktop. Do you think the monitor is dying? Or has some setting on the computer or monitor inadvertently been changed?
  • 813 Answers
Make sure that it is directly connected to the Mac Mini and not through some other device like TV Tuner, Video capture device.
If it is already directly connected then the picture tube might be reaching the end of it's life, You need to replace.
Posted on Oct 06, 2009
HP 17'' L1706 LCD Monitor image shacking
shacking?
well you proved its bad.
a refurb at walfart is $50, about 1 /4th a repair bill.
most the monitors all before magic year 2010 LED year.
all of the now are dead for CCFL back lamps.
1: dim
2: FLASHING JUST LIKE HOME FLORESIENT LAMPS TO.
3: TURNS yellow
4: goes dead, but flash light played on front show data.
5: works not, not next day, repeat,(random)
all do that, ever one, unless your was parked on self for 5 to 10 years.
they all die 20,000 hours (not days , hours)
Feb 28, 2018 | HP Computers & Internet
Dear Sir, I have installed Ubuntu Studio 10. Display card Intel 82915/GV/910 GL Integrated Graphics Controller (rev 04) with HP L1706 17" LCD monitor which just supports 1024 X 768 resolution with...
that is what happens using new pc, new os. like linux
and then using old monitor ! welcome to PnP H3LL
1024 reso is very very old. we long ago exceed this era.
both MS and linux do not try to support the old dead no longer supported by makers, monitors.
try to imagine how many different monitors were made in last 30 years. vast.
then try to support the ones not supported now.
you do know the HP does not support 10 year old products right?
so knowing that one fact, how can Ubuntu...
study the limits of PnP, plug and play, its great but not magic,
it cant pull rabbits (dead) out of hats, now.
Btw, Walfart has new monitor for $46 , that works pnp.
ever consider a cheap upgrade?
now the real place to ask, not here.at fixya (guess yah)
https://ubuntuforums.org/forumdisplay.php?f=326
Jun 17, 2017 | HP L1706 17" LCD Monitor
My monitor HP L1706 does not ignite but the green light blinks
Your screen is in sleep mode.
Its does not receive a signal from the pc.
Check for loose connections or a damaged cable.
Your monitor could also have a defect internal.
Maybe also your graphic card in the pc.
Good luck.
Mar 03, 2011 | HP L1706 17" LCD Monitor
L1706 monitor power light flashes green/amber
A flashing power light often means the monitor isn't getting a signal. When you turn the monitor off and back on, do you see the brand logo for a few seconds? Try plugging it into a different computer to see if it comes on.
If plugging it into another computer doesn't work, it may be a bad power circuit in the monitor. A common problem with monitors is the capacitors going bad. If you're handy with a soldering iron, you can try replacing them yourself. Look here for pictures and instructions: Fix an LCD Monitor
Oct 18, 2010 | HP L1706 17" LCD Monitor
Monitor is changing color when power on:- red, green, yellow, violet, white, blue etc......repeating continuously ...... more tha ten times switch off monitor but the problem remain the same... VGA...
1706,
the monitor is bad if OSD , menu shows bad colors
try the reset in the OSD menus,,
google, HP L1706 manual, read it.?
some newer hp monitors even have test pattern in the OSD pages. (on screen display) try that.
Oct 04, 2017 | HP L1706 17" LCD Monitor
My HP Monitor Model No: L1706 problem
I sure sounds like you have backlight problem, since when the VGA cable is connected the power LED turns GREEN and blinks when VGA cable is disconnected, it means the video signal is getting to the monitor OK, so more likely the problem will be in the monitor, but just to be sure, you should also try this monitor with another PC first.
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed HP and other monitors to get some ideas what goes wrong: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further.
Apr 01, 2010 | HP L1706 17" LCD Monitor
I have the same problem. "No Input Signal"
may be the power button get stuck when you pressing to switch on.just change the power button cable with reset button and see. also chek the **** aslo just remove it and clean it and fix it again.
Sep 10, 2009 | HP L1706 17" LCD Monitor
HP L1706- screen is blank when I switch on
First if you have a extra monitor try to plug it in and see if it works. If not then check your video card. or get into the computer and try and remove and reseat the memory. Sometimes by just doing that can solve the problems
Feb 06, 2009 | HP L1706 17" LCD Monitor
Computers & Internet Logo
35 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
