Question about Frigidaire Washing Machines
Frigidaire AFT7000FS1 stopped working
I have the same problem where mine won't spin or drain the water. I had this problem for the first time 4 months after I bought it. I had it repaired and the same thing happened four more times within 9 months. The pulley on the basket was bad and had to be replaced. I have a frigidaire service policy and they gave me a hard time to have it replaced. They wanted me to have it repaired at least four times before they would replace it. It's a big job. I haven't had the problem since they replaced the entire piece. However, I do keep getting error messages now and then when I'm washing. I'm trying to figure out what they mean.
SOURCE: washing machine error code on Frigidaire ATF6000E
thank you larkinator.. that totally fixed the problem as far as i can see right now, I am letting it "wash" a load of nothing. it was a bunch of BS how they hid the filter... I had to literally take apart my whole machine. :-) but its fixed, THANKS!!!!!
Posted on May 28, 2008
SOURCE: Frigidaire front load washer (LTF600ES1) Error E20
took off the screw clamp and it had a sock in it. works great now thanks
Posted on Nov 08, 2008
  • 196 Answers
SOURCE: Washing Machine starts, squirts water, then stops.
E5E  IS FOR  Communication problem. THERE IS 100 %WIRE SHORTING SOMEWHERE.PLEASE CHECK OUT.
ALSO OTHER ERRORS Error code - Fault condition
E11 Fill time too long.
E13 Water leak in tub or air leak in air bell.
E14 Reed switch.
E21 Water not pumping out fast enough.
E23 Drain pump relay on control board failed.
E24 Drain pump relay on control board failed.
E31 Better models. Pressure sensor not communicating with control board.
E35 Better models. Pressure sensor indicates water overfill.
E41 Control board thinks the door switch is open.
E42 Door remains locked after cycle is completed.
E43 Control board problem.
E44 Control board problem.
E45 Control board problem.
E46 Control board problem.
E47 Board thinks the door PTC circuit is open in spin.
E48 Board thinks the door PTC circuit is closed.
E52 Bad signal from tacho generator.
E55 Motor overheating.
E56 High motor current.
E57 High current on inverter.
E58 High current on motor phase.
E59 No tacho signal for 3 seconds.
E5A High temperature on heat sink.
E5B High temperature on heat sink.
E5C High temperature on heat sink.
E5D Communication problem.
E5E Communication problem.
E5F Communication problem.
E67 Input voltage on microprocessor incorrect.
E75 Better models only. Water temperature sensor circuit.
E76 Better model only. NTC temperature for the cold water valve over the limits.
E95 Communication error.
EB1 Incoming power frequency out of limits.
EB2 Incoming line voltage above 130 VAC.
EB3 Incoming line voltage below 90 VAC.
EF1 Clogged drain pump.
EF2 To much soap.
Posted on Nov 12, 2008
huuum
  • 750 Answers
SOURCE: frigidaire front loader wont final spin timer stops at 7 min.
its_me_ac You probably have a faulty timer switch.
You can buy parts at this site , v
Please give me a good rating
Posted on Dec 05, 2008
SOURCE: frigidaire gallery front load won't spin
I had this exact problem. After draining, it tumbled. until 7 minutes left, and then just stopped. I replaced the door lock and switch yesterday, and that fixed it. The spin cycle works again.
Posted on Oct 22, 2009
My kenmore 29822800 won't fill with water, it works on spin and drain
The last time I moved, my washer/dryer combo (Frigidaire) had the same issue for approximately 7 months before finding out all I needed to do was level the washer, and of course, make sure the faucet connected to the washer is turned to on position. Hope this is helpful.
Praysemema.
Mar 13, 2013 | Kenmore Washing Machines
My Frigidaire Affinity front loading washing machine model #ATF6000FS1 won't spin when loaded.What's the problem?
sounds like you have something in your pump stopping the water draining it will not spin with water try unblocking the punp
Sep 27, 2012 | Frigidaire Affinity Washing Machines
Frigidaire model fex831fs4 will not drain or spin
My problem was a little different but I want to post this for others that might experience the same.
My Frigidaire Washer/Dryer Stack Combo Model FEX831FS4 was not draining and had a humming/buzzing noise when it got to drain/rinse cycle. This is usually and probably caused by a small sock or thin or small underwear that got sucked out the top and into the drain hose. I have no idea why they did not design this with a rubber flap like most washers to protect from items going up and out but here's how you fix it.
IF your unit is having this issue STOP and don't try runnin drain/rinse cylces anymore or you may damage the water pump and have to buy a new one. I think I damaged mine from trying to drain the water so many times with a sock clogged in there... but so far it is working anyway, just with a buzzing noise.
HERES THE FIX
You need to TAKE OFF the FRONT COVER and REMOVE the ITEMS FROM the HOSE leading to the WATER PUMP. The water pump is on the bottom front left and theres only TWO SCREWS to get off the FRONT COVER of the washer/dryer. They are on the bottom by the feet. Have someone tilt the unit backwards and unscrew them with a phillips head and then pull the front cover down and off. There is a rubber snap pin in the top center of the cover but it will come loose as you pull down.
In order to get at the water pump you do NOT need to pull the washer/dryer out, you can get at everything from the front. However it might be a wise decision to unplug the power since water will be draining everywhere.
First siphon out all the water in the tub, whatever you don't siphon will immediately coming rushing out once you remove the hose from the water pump.
I would UNPLUG the electrical connector on that water pump and tie it up out of the way because even if you siphoned the water there will still be water in the hoses and probably under the washer tub some.
Disconnect the hose that comes from the tub to the water pump. That's where I found a small children's sock clogging the pump. Dry off the water pump plug connector pins if they got wet (where you removed the plug from) and reconnect the electric connector.
We tried many times to run the drain cycle before taking the washer/dryer apart so your water pump might be shot as I think mine is. Now mine always makes a buzzing noise as if it's wore out from being worked with a sock blocking it's inner part. You might need to replace your water pump.
May 08, 2012 | Frigidaire FEX831F Top Load Stacked Washer...
I have a frigidaire 9 cylce-heavy duty-2speed ,model fws445rfs0. It fills with water, drains water but won't spin on the spin cycles. I was trying to remove the middle spinner piece inside to see if...
for schematic try:http://www.partselect.com/ModelFrames.aspx?ModelID=1004870&ModelNum=FWS445RFS0&mfgModelNum=&ManufactureID=4&Selected=ZH8J52ZV&Position=4&mfg=Frigidaire&Type=&Mark=4
Feb 02, 2012 | Frigidaire Washing Machines
Washer wont drain when it gets to drain and spin cycle
Hi hope this works for you it worked on my machine mine is a GE on the front of the washer below the door there is a panel with 3 screws and in behind that panel you will find 2" circle with a tab unscrew it there you will find the filter that that stops a lot of
fibre and lint that gets pluged and does not let the water rince or drain I clean mine every 6 months
Jan 04, 2012 | Washing Machines
My fridgidaire frontloader wont do a spin cycle
A lot of times it is the strainer clogged at the pump. That has happened to mine. Hope that helps.
Sep 06, 2009 | Frigidaire Affinity ATF7000E Front Load...
Leak. My wife noticed water leaking out bottom of washer
Try cleaning the drain plug. I did this in about 5 minutes and was amazed at how much debris was clogging up the drain. Mine was accessible by removing two screws at the bottom of washer and removing panel. Drain plug was right there and easy to unscrew. Be sure to have a cookie sheet or other pan to catch the water that will flow out. Once that drain is clear, thumping should stop because water can flow down the drain easily.
Aug 17, 2009 | Frigidaire ATF6000ES Front Load Washer
Frigidaire gallery front load won't spin
Does the washer spin after the wash cycle? It sounds like the door switch. This is a common problem with frigidaires. 90% of the time a door switch fixes it.
Jul 01, 2009 | Frigidaire Washing Machines
Washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
Feb 21, 2009 | Roper RAS8445KQ Top Load Washer
Frigidaire Affinity e 25
dip as much water out as possible remove bottom panel remove hoses from pump ckd hoses and pump for blockage
May 21, 2008 | Frigidaire Affinity ATF7000ES Front Load...
Washing Machines Logo
63 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
