Question about Poulan 38-Inch Steel Deck 15.5 HP Briggs & Stratton I/C Engine With 5 Speed
Need digram to install deck belt for blades - Poulan 38-Inch Steel Deck 15.5 HP Briggs & Stratton I/C Engine With 5 Speed
    Problem Solver:
  • 3 Answers
MOWER BLARES WILL NOT DISENGAGE WHEN LOWER DECK IS RAISED UP
Posted on Jun 26, 2011
  • 437 Answers
You are going to need to find the model number under the seat.
Go to www.precisionope.com and look up under OEM parts. You should find a parts list and diagram to route the deck belt.
Posted on Oct 06, 2009
2 Suggested Answers
  • 760 Answers
SOURCE: I need the belt digram for a 50
You need exact model numbers. Go to www.searspartsdirect.com
put in your model number and see parts list. Go to the right hand side of page and click on manuals.
Posted on Aug 03, 2010
Model 917.20381 riding mower. Why don't blades disengage?
Terry, Deck full of debris around belt tensioner not allowing it to release, tension arm seized/spring broke, wrong/small belt installed.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
CRAFTSMAN 42 MOWER REPAIR
My mower deck will not disengage
Blade will not disengage Craftsman 917 270662
https://answers.yahoo.com/question/index?qid=20090407155731AACRvsq
Sears Craftsman 917 272481 LTX1000 Riding Mower Deck Belt Blade...
Apr 08, 2016 | Craftsman Garden
How do I determine why the blades will not engage on my mower
With the mower turned off and the deck at its lowest setting, check the top of the deck for any debris like rocks or sticks. Then watch the top of the deck while you move the engage lever. If nothing is moving, you either need to adjust the cable, reattach the cable, or install a new cable. If you see the lever with the pulley on it moving, when the engage lever is locked on, check the tightness of the belt. If it's loose, that is your problem and it could be a stretched belt.
Sep 18, 2014 | Craftsman Garden
How can i get a diagram of how to change a v-belt on a cub cadet 60" recon mower
There is a site that I use frequently. Go to Partstree.com and enter your model # then look up the diagram. Usually there is a digram on the deck .
Sep 14, 2014 | Cub Cadet Garden
Our indestructible deck has made mowing impossible, it clogs all the time and then "coughs" like it's dying. We have to stop mowing and turn off the blades and turn them on again to shoot the...
Hi and welcome to FixYa I am Kelly.
Maybe I am missing the obvious but I have had a couple of people that had this problem with since new use of a mower. One of them had the wrong blades with the deck and the 2nd one the baldes were installed with the air foil side DOWN. If you have Air-flow problems under your deck the above is possible or your blade deck drive belt is routed incorrectly. The decal for the blade deck belt routing should still be on your deck. Look at the decal drawing vs the actual routing of the deck belt. It is highly possible that one or more of your blades is driving backward.
If you can not find your decal (would be hard not to find it on a deck not 1 year old!), I will try and look it up but I need the model number of mower and the DECK (2 ea model numbers 1 for mower 1 for deck)
Thanks for choosing FixYa,
Kelly
Apr 22, 2011 | Garden
I need the belt digram for a 50" craftsman lawn tractor, it has two belts on the deck.. any help?
Aug 02, 2010 | Craftsman 26 hp 54 in. Deck Deluxe Yard...
How to put a belt back on a cub cadet lt1050 lawnmower
Take the belt and apply axle-grease to it alllll over. apply large amounts of grease to each pully - and then just slide it on.
May 31, 2010 | Cub Cadet Street Sign- tractor lawn riding...
How to chage belt to blades
If you can get the mower up on some blocks, it would be helpful. Remove the deck pulley guards. Undo the deck front eye links and let the front of the deck hang down. Disconnect the spark plug lead for safety's sake. Turn the belt using the blades as leverage and prise the belt off the engine pulley. The belt should now be clear to remove from the machine. Installation is simply reversing the removal process. After the belt is fitted, it may need adjusting after breaking it in. At the rear of the deck above the pivot plate on the opposite side to the tension spring is a threaded rod with a 14mm nut on it which you turn out for more tension or in for less if the belt drags. It's very hard to get at so give the belt a good run first to let it settle in before taking this step
Apr 14, 2010 | Mtd 46" Dozer Blade, Fits All & Yard -...
Install belt on toro mower model 70041
For removing/replacing the deck belt, the general method is:
  1. turn off engine, remove key and set parking brake
  2. disengage blade by putting blade engage lever into off (disengaged) position
  3. lower the cutting deck to the lowest position (closest to the ground)
  4. relieve the belt tension (depending on the model, use a 3/8 inch ratchet set to tighten in the square hole of the idler bracket)
  5. remove and replace the belt
NOTE: it's not necessary to completely remove the cutting deck.
Useful diagrams for removing the cutting deck, http://216.213.143.2/ProAuthor/ManProc.cfm?ManualID=425&ProcID=14794
For deck belt diagrams, http://216.213.143.2/ProAuthor/ManProc.cfm?ManualID=425&ProcID=14796
If the transmission drive belt needs to be replaced, several components must be removed and special tools (i.e. air/impact wrench) used in order to change the tractor's transmission drive belt. See an Authorized Toro Service Dealer to have your drive belt replaced.
Sep 09, 2009 | Toro Lawn Mower With Toro Power Tools
My john deere lt 133 mower with a double blade mulching deck, 1 blade stopped working and only 1 blade cuts now, how do i fix this. Thanks Patrick
This model mulching deck uses a flat/ribbed serpentine belt that is set at very high tension.When belt breaks under the cover only one blade will turn due to IT being driven from PTO clutch as the other blade being turned from serpentine belt.This deck was Deere's first and last shot at making a true mulching deck and only made it a couple years.When you buy the VERY expensive belt it will come with detailed instructions on how to install it.Goog luck.
Aug 07, 2009 | Garden
Poulan 38-Inch Steel Deck 15.5 HP Briggs & Stratton I/C Engine With 5 Speed Logo
477 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
