Question about Dell Inspiron 1525 Laptop
I can't connect to the internet from computer. When I type ipconfig I get Media Disconnected. We have vista on computer
  • 34 Answers
Make sure vista recignized your wifi card.
control panel, add/remove hardware- hardware list- if not there then search for new hardware. if it is there, then right click and select drivers at the top dropdown menu then update driver.
Also, go to dell.com find the support section and find drivers and downloads. Enter service tag number and select wireless as your category and install the necessary driver for your dell laptops wifi card
Posted on Oct 06, 2009
Ipconfig media disconnected
Do you have an internet connection on your computer? My Toshiba shows all media is disconnected and even shows a red X on my internet connection, but I am connected to the internet. I believe it is a driver that needs to be updated. Your question is very vague so I can not really give you a solid answer.
Dec 26, 2013 | Toshiba Computers & Internet
Tip
Tips for Media state Media disconnected or Network cable Unplugged
Wired adapter or NIC Local Area connection if says "Network cable unplugged" or if in the command prompt if you type "ipconfig" and if you come agross an error message "Media state media disconnected" then it means there is some problem with a physical device or connections
Solutions: 1. Try with a different port on the switch or the router. It could be the fault with the Router/Switch port 2. Try a different Ethernet cable. It could be the fault with the Ethernet cable 3. Try with a different NIC or a different computer. It could be the fault with the NIC
Wireless adapter or NIC
Wireless network connection if says "Network cable unplugged" or if in the command prompt if you type "ipconfig" and if you come agross an error message "Media state media disconnected" then it means there is some problem with a some device issue or the wireless settings
Solutions:
1. Try scanning for wireless network and reconnect 2. Remove the profile or preferred networks from its list 3. Check and make sure the SSID and the Security KEY are correct 4. Restart the computer 5. Try with different security types like WEP,WPA or WPA26. Check if the MAC filter on Router/Access point is enabled
on Aug 21, 2010 | Computers & Internet
You may need to go to the linksys website and download a patch.
Sep 16, 2012 | HP Pavilion a1419h PC Desktop
Can you tell me the default IP address for this unit as I have lost the pass word and need to reset the unit
If your computer is plugged into the router, you can easily get the router's IP address by going to your command prompt and typing "ipconfig" without the quotes.
Command Prompt is under Start (or Orb if using Win7 or Vista) > All Programs > Accessories
After typing "Ipconfig" and hitting return, command prompt should display something like this:
Windows IP Configuration
Ethernet adapter Wireless Network Connection:
Connection-specific DNS Suffix . : blah.blah.comcast.net.
IP Address. . . . . . . . . . . . : 192.168.0.196
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 192.168.0.1
Ethernet adapter Local Area Connection:
Media State . . . . . . . . . . . : Media disconnected
Ethernet adapter PdaNet Broadband Connection:
The router's address is your "Default Gateway." You should be able to put that address into an Internet Explorer window and it will bring up the configuration interface.
If you find this helpful, please rate me -- trying to get my "Wiz" rating so that I can provide Premium service.
Thanks,
Chris
Jul 27, 2011 | 2wire 2700HG-B Router (2700HGB)
D link router connection Hi I have recently bought a D link Dir 615 router and cannot connect to internet on my vista laptop. I have set up wireless on another laptop, PS3 and blackberry phone and they...
Everything looks normal:
Description . . . . . . . . . . . : Atheros AR5007EG Wireless Network Adapter
Physical Address. . . . . . . . . : 00-1D-D9-44-F8-15
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Link-local IPv6 Address . . . . . : fe80::1c05:824a:4808:dd81%14(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.0.102(Preferred)
Lease Obtained. . . . . . . . . . : 21 February 2011 13:48:48
At the command-line prompt, try: ping www.ucla.edu
If it responds, then you *DO* have a good Internet connection.
Feb 21, 2011 | D-Link Computers & Internet
Lap Top access - unable to access internet on lap top
1.Powercycle equipment (Unplug and plug back in)Wait 15 seconds then plug back in.
2.Check connections the Ethernet cord from modem should be plugged into back of router into internet port.
3.If modem runs off signal from a local tower and there is not sufficient signal on the modem you will need to contact your ISP ( Internet Service Provider) to check for outages if not skip to step 4.
4.Open your network connections window.
A.Windows XP:Start/Run/Type ncpa.cpl this will bring you to network connections.
B.Windows vista/7 Start/Search bar Type ncpa.cpl
5.Windows XP:Right click on Local Area Connection and click properties,
A.Click Internet Protocol and hit properties ensure Obtain ipaddress automatically and Obtain DNS service automatically is checked if not check both and close window.
B.Windows Vista/7 Right click Local Area Connection and click Properties, Uncheck Internet Protocol Version 6 and click on Internet Protocol Version 4 and hit Properties Ensure Obtain ipaddress automatically is checked as well as DNS server.
6.You will need to manually renew ipaddress if this does not work
A. Windows XP:Start/Run/Type CMD and hit enter,
B.Type ipconfig /release
Then type ipconfig /renew then restart computer
A.Windows Vista/7 Start/All Programs/Accessories/Right click Command Prompt and hit run as administrator.
Then type ipconfig /renew restart your computer
7. If this does not help run an Antivirus. Hope this helps Happy Thanksgiving
Nov 26, 2010 | D-Link RangeBooster G WBR-2310 Wireless...
Media Disconnected (Windows Vista)
Your ISP is there to help you connect to the internet even supplying hardware to work with there network if they won't help try a different ISP when setting up a new account (DSL or cable) they will send a installer out and make sure you can connect. Good luck mysleuth
Apr 29, 2009 | Computers & Internet
Vista home premium
· power cycle the modem and router (turn-off the modem and router, and wait for 10-15 seconds before powering on the modem first, then wait for 3-4 solid lights before you turn-on the router; check a website, or else
· bypass router (by directly connecting your computer to the modem)
· checked a website
· checked the IP address by clicking start button for winXP, click run and type cmd, on the c:> prompt type ipconfig then hit enter, get the IP: if the IP address starts with 169.254.x.x…the type ipconfig /renew…or else type first ipconfig /release, then type ipconfig /renew.
· If media is disconnected, check the modem cable that runs at the back of the computer, unplugged and plug it back, or try other cat 5/ modem cable.
· Check the device manager for network adapter (is properly working), by right click on my computer, click on properties, and click on hardware tab, and click hardware manager button, click the plus sign next network adapters, makes sure there is no markings such ? ! or X marks, or else install the device manager for the Ethernet card.
· Type Ping google.com, check if the it receives and sends packet, if it does, then check the browser…
· Check browser settings, delete cookies, temp files on general tab…(click on tools->internet options), click on the connections tab, the make sure it is “never dial a connection”, check the LAN settings, make sure that there is no marks or checks on the boxes..click ok. Click on the advanced tab, click on the button “restore defaults”. Hit apply and ok. Close the browser, and open it up again and check for online website.
· Once connected, install back the router, if the there is no website shown, please your router brand support line for the reconfiguration of the router.
Apr 22, 2009 | Dell Dimension 3100 PC Desktop
Setting up routher
Try setting the router to factory defaults by holding the reset button on the back of the router for 10-15 seconds. After the router resets, open the CMD window on the computer by clicking start/run type cmd, type ipconfig /release then ipconfig /renew this should make the connection from the computer to the router. BPCS
Dec 30, 2007 | Actiontec GT704WG Wireless Router...
Netgear DG834G router
Are you getting any internet?
Are you using Windows Vista?
Oct 19, 2007 | NetGear DG834G 54 Mbps 802.11g Wireless...
Dell Inspiron 1525 Laptop Logo
91 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
