Question about Whirlpool Dryers
Everything is working except the timer is not
Everything is working except it is not drying. The timer dial is not advancing when in High Heat mode.
  • 120 Answers
Suggest you replace the timer dial, this should do the trick.
Posted on Oct 06, 2009
Gas dryer dries sporadically. dial for automatic dry doesn't move
Fixing an Electric Dryer that Doesn't Heat and the Timer ...
? 5:51
https://www.youtube.com/watch?v=0mo_gw0p2CI
Jun 29, 2013 - Uploaded by SamuraiRepairman
Although electric dryers are the simplest appliance to work on, ...Replaced outlet, cord, and moved the outlet so we don't have the same ... Whirlpool LER4634EQ0 110 v timer motor, when timer contacts TM .... David Villa 7 months ago ... 3 years and now thedryer won't heat and the timer doesn't advance, ...Missing: cu
Nov 17, 2015 | Whirlpool Dryer. Gas Dryer. 7.0 cu. ft. in...
My dryer works on high heat on the timed side of the knob, but won't work on the low heat and high heat (more dry, less dry or energy preferred setting)
Does this mean the timer wont move or it will not dry ? if it will not dry it is more than likely the timer , if it wont advance then you have a shorted element
Nov 03, 2015 | Dryers
Gas dryer heats at first then take forever to dry, auto dry setting does not advance
If it works to begin with and fails afterwards then that can only be them solenoids mounted on the gas assembly. Here is my home video which shows how to check and replace:
May 02, 2013 | Dryers
Kenmore 110.60812990 will not stop
if it's not advacing in time dry you have a bad timer,that timer should count down no matter what the dryer is doing,if you have it in auto then it could be no heat,when it's in auto or more or less cycle the heat comes on and the timer won't move until the heat shuts down,when the heat is off timer advances,when the heat starts the timer stops,it will do this until the clothes are dry and then timer will shut off but in timed cycle,timer isn't counting down get a new timer.
Apr 05, 2013 | Washing Machines
When in auto dry mode, the heat comes on for an initial warming but then does not come on and the dial does not advance. When using timed drying, the dial DOES count down but heat does not come back on...
It sounds like you have a faulty timer. To test it, remove timer knob and remove screws. Remove screws from behind control panel. Disconnect leads from timer motor, use a Volt/ohm meter and probe leads, if reading is high or infinity, it's faulty. Should range between 2 or 3k. You can also test the temperature selector switch. It's located next to start switch. Take off leads, probe with meter, Turn switch, reading should range from zero to infinity or vice versa.
Apr 12, 2011 | Dryers
Dryer Timer dial will not move but dryer works
Will the dryer move forward in timed dry? if it does not then you need a new timer. If if will advance in timed dry but does not advance in auto mode then the high limit needs to be replaced on the heater.
Apr 10, 2009 | Roper REX4634KQ Electric Dryer
Timer does not advance, even in timed mode
My parts sources list 3 different timers for this dryer depending upon the MAN.#.
They are
33002855
33002808
33002854
Feb 22, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Extremely low drum heat but setting is on HIGH.
Electric (Kenmore - 60931) dryer takes forever (several cycles) lately to dry clothes set on high heat (actual heat in tub feels low though). There are no obstructions in the venting and the 240 volt connection is fine. The timer rotates the dial (timer motor working). Help!!!
Sep 15, 2008 | Zanussi TC7102W Electric Dryer
Dial/heat problems
First, check your circuit breakers. If you are in North America, there are two linked breakers with a 30-50 amp rating. Turn them both off and then back on to reset them. I doubt there are fuses in the dryer. Next, is the motor running and the timer advancing? If not, there are issues there. If still no function, I'm going to guess at the timer as the culprit since it is working intermittently. Oh, and check to see if any wiring to the appliance is burned or damaged, including junction boxes.
Jan 18, 2008 | Dryers
Dryers Logo
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
