Oki ml521 printing problem
A new original OKIml520/521 ribbon only lasts 4 days in the printer - then I have to replace it. What can the problem be? It sounds impossible that a ribbon is finished in 4 days. No excessive printing is being done.
  • 81 Answers
There's a small metal spindle that turns the ribbon when the carriage moves. It sticks up out of the plastic bit where you put the ribbon. These can break so the ribbon doesn't turn so it prints in one patch of the ribbon so it wears it out quickly
Posted on Oct 13, 2009
How do i get my OKI microline 320 to print darker. I added a new cartridge and it still prints light
have you tried cleaning printhead easy two screw comes out ribbon cable off soak in isopropenol will clean jets out
Oct 08, 2011 | OKI MICROLINE 320 Turbo Matrix Printer
Starts off printing normal than fades. new ribbon in it
Check the new ribbon and see if the printer has worn out one spot.
If you move the print head manually side to side the blue knob on the ribbon should spin. If it does not make sure you have the correct ribbon and it is installed correctly.
Mar 08, 2011 | OKI MICROLINE 320 Turbo Matrix Printer
Hi oki 320 turbo printer started to print very light ,i want to change the ink ,but i do not know where to put the ink ,please help
There is now ink in the machine. You just have to replace the print ribbon. This is the small black box that is mounted to the printhead.
Jul 13, 2010 | OKI MICROLINE 320 Turbo Matrix Printer
Its not printing
Make sure that you have a good ribbon installed and that the ribbon is advancing as the carriage moves. If the ribbon is not advancing it will only print until the ink has been used up on the section of ribbon stuck in front of the print head. It will also need a new carriage if the ribbon is not advancing.
Dec 21, 2009 | OKI MICROLINE 320 Turbo Matrix Printer
Problem with new installed printhead
If I remember the 320, there is a head-gap adjustment that is normally moved for replacement of the head and must be reset again. Check your manual for that term; 'Head gap adjustment'
Aug 18, 2009 | OKI MICROLINE 320 Turbo Matrix Printer
Oki 320 Turbo -- Unclear characters in output
If it is not the ribbon, you may have to replace the print head.
Genuine Okidata Print Head
Mfr Part #:
50063802
Hope that helps...
Jun 21, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
Printer won't print labels
What driver are you using ? the default driver should be IBM Proprinter.
Hope this helps
Dezzi
Jan 24, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
OKI MICROLINE 420
you are correct, you need a new print head OR adjust the head gap on the carriage
Sep 13, 2007 | OKI MICROLINE 520 Matrix Printer
Oki 520 missing print
You have replaced the item which is commonly the cause- the printhead. The other possible problems are: a connection break in the printhead ribbon cable, which makes electrical connection from the driver circuitry to the printhead. Look for a tiny crack, especially along the edge of this ribbon cable. Another possibility is an electronic component defect in the circuitry which fires the printhead, or maybe a loose solder connection in the same circuit. Lastly, when you replaced the printhead, are you reasonably certain the replacement head didn't have a broken top pin or two?
Apr 10, 2007 | OKI MICROLINE 520 Matrix Printer
87 people viewed this question
jasbo
jasbo
