Question about Hotpoint TDC32 Electric Dryer
Dryer wont start
All the lights are working, but the water bottle full light is on????
All other buttons work but when i press start it doesn't do anything.
Thanks
Fixed this problem now. It was the door switch. For some reason maybe through slamming the door. The door switch had dislodged itself from it's locating hole. After bypassing the switch with a paper clip and then removing and checking the switch by hand it was found to be in full working order. Once this was re-installed the dryer worked fine. Hope this helps anyone else with the same problem.
Posted on Oct 07, 2009
WK dryer water bottle full light on permanently bottle empty dryer won't work.
try cleaning the contact points at the back of the water bottle
Nov 03, 2016 | Dryers
Hoover nextra washing machine door wont lock / cycle start
sounds like the door lock mechanism. if this cannot signal it has engaged, to the board, no other function will work (you don't want the washer going with the door open, trust me :) )
Nov 08, 2013 | Hoover Nextra 160 HNWF 3137 Front Load...
Light inside dryer works fine, but lights for buttons wont turn on. So dryer wont start. It definitely is receiving power, but the buttons up top, on the front display will not even light up (regardless of...
i would double check the power a dryer runs on 220 volts if it is only getting 110 volts it will only run half of the dryer,, that means it could have power to the motor and light but not the control panel or vise versa 75% of the time when i work on a issue like this that is what it turns out to be,, take the cover off of the back of the unit where the plug goes in you will see three screws that the plug is held on with you will need a tester that reads 220 volts put one lead of the tester on the left screw and the othe on the right screw you should read 220 volts,, if not put one lead on the center screw and touch the other lead ont the other screws one at a time until you find which one doesnt read 110 volts,, if it reads the full 220 volts then you will need to check all the wires inside,, if all is ok you will need to replace the main control board
May 03, 2011 | Kenmore Elite HE4 Electric Dryer
Problem with whirlpool condenser dryer,light on to say empty water bottle but after doing all that and cleaning it out it still wont reset. HELP PLEASE!
Empty the bottle and then unplugg the dryer. Plugg the dryer back in and see if the empty light goes off.
Apr 04, 2010 | Dryers
Dryer will not work. Makes buzzing sound when
locked up dryer motor,replace-mike
Jul 17, 2009 | Dryers
Dryer does not work
Dryer just beeps, lights work, panel lights change, dryer just wont start. before this dryer worked but kept beeping thru the whole cycle. now nothing but lights.
Mar 13, 2009 | Whirlpool GEX9868J Electric Dryer
Water full light wont go out
Make sure the water dispensor is pushed back firmly as there is a switch that is operated by the dispensor. If this fails the switch may be faulty.
Post back if further assistance needed.
Thankyou for using fixya.
Nov 29, 2008 | Dryers
Water Indicator Light constantly on
Sounds like the sensors is dirty, or there is scale or deposits in the bottle. Clean out the bottle with a descaler if it has any scale (white or brown) deposits in it. If it is clear and still a problem, the sensors is inside the bottle holding section. Make sure there is not any fluff or dirt in there by giving it a hoover outand a gentle brush.
Jan 19, 2008 | Zanussi TC7102W Electric Dryer
Water full indicator light
on most condensor dryers they also have a filter water bottle and also a radiator have u checked this becomes sometimes they get clogged up with lint this then doesnt let water go through as easy and it can put your water light on
Aug 22, 2007 | Zanussi TC7102W Electric Dryer
Hotpoint TDC32 Electric Dryer Logo
122 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Dan Webster
Dan Webster
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
