Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Burning smell in the back, turns on then off makes a static noise when trying to turn on
5 Suggested Answers
mpersaud
  • 97 Answers
SOURCE: burning smell
the power source is trying to start and it sint. the lamp is done with because thiese tvs need high voltage. its probably melting pallastic around it . get rid of this, much money to fix up and or try getting itn fixed if stiill have legeble warranty
Posted on Jan 29, 2008
SOURCE: TV shuts off by itself and has a burning smell
mine is doing the same thing but i was able to pinpoint it to a capacitor arching and smoking. haven't replaced it yet so i'm not sure if it's just a bad capacitor or a more involved issue.
Posted on Aug 17, 2008
SOURCE: my tv make a noise that will turn on but within 3 second shot off
I wrapped electrical tape around the transformer in the back, that stops the sparks, don't ask me how is that so. I just thought, the elect. tape would prevent the static from traveling to any other parts of the circuit inside of the tv. Don't try it if you think it's not going to work. It is dangerous and I got zapped 2 times before I got it right. be careful
Posted on Jan 20, 2009
  • 8457 Answers
SOURCE: my 61 inch RCA HD TV started to shut of by itself.
Ur high voltage is dead.The fly back transformer.Big black block of plastic with a red wire with cap to the CRT(tv tube) is dead.Usally that where the noise came from.
Posted on Sep 09, 2009
Smells like something is burning when turning on fan mostly when turning on heat. Also makes a gurgling noise. Can hear it and smell from interior of van
Check you coolant level(gurgling sound). A sweet smell is most likely a leaking heater core. Burning oil is valve cover gaskets.
Sep 03, 2016 | Cars & Trucks
Why does my vax power 2 cylinder hoover make a noise and smell of burning rubber when I turn it on we have cleaned inside and out and all filters
That is the smell of perhaps burning insulation when there is excessive current going into motor. If something in unit is binding the motor will not spin fast enough, generate less back emf, use more current, overheat and burn out!!!!!!!!!!!
If it has a drive belt and that is rubbing up against something and not turning properly that will also cause the smell.
Do not use unit in this condition -you risk permanent damage.
Aug 31, 2015 | Hoover Vacuums
Vax v-091 burning smell and clunking noise
Is there something stuck inside, underneath, being turned along with the motor? burning smell usually means something got caught and the belt snapped. Not expensive and don't know if it's an easy DYI. Shouldn't cost too much to have it repaired or you can google the brand and model and the word belt, see what you find.
Mar 01, 2014 | VAX Appliances 2000 Canister Vacuum
Noise and burning smell from heater
Yeah.
Pine needles get into the heater box and clog the heater fan motor's "fan".
You also may have rodents in there,making nests.
The wife was smart to turn off the heater fan B-4 the fuse blew.
Feb 21, 2013 | 2006 Toyota 4Runner
Jvc lt-z32s2 went dead and makes a static sound at back of unit.
check weather the power cord or component at the power supply board get burned.
Oct 02, 2012 | JVC Televison & Video
I have a Frigidaire cooling and heating unit. Last night we had freezing rain and ice. I heard a weird noise coming from the unit then smelled a burning smell. I turned the unit off. The top vent...
Sounds like the motor burned up when the ice blocked the air which it was not able to cool the motor it will need to be replaced. (the motor)
Jan 29, 2010 | Heating & Cooling
My 32v434t television.
The TV was making the clicking noise and not turning on because an internal error was being detected.
Now things had got worse , and something had blown inside the TV.
The burning smell and high pitched noise is coming either from Flyback transformer or PSU board. Repair is a delicate matter and must be done by a technician.
Jul 05, 2009 | RCA TruFlat 27F520T 27" TV
Burning rubber smell and the dryer will not turn on
sounds like you need a new belt for your dryer, the smell of burning rubber is the belt slipping, thats my guess
Feb 09, 2009 | Dryers
My tv make a noise that will turn on but within 3 second shot off
Jan 18, 2009 | RCA D52W19 52" Rear Projection Television
Panasonic PT-47WX49E will not power on
Thats a power supply module going bad. Dont use it until a person with knowledge on TV see that. Or if you feel you can DIY open the back panel to see if there is a toasted or foreign object near the power supply area. Its located when you follow the main plug going into the back panel of your TV. Look for a dying Fuse too. And watch out for Capacitor that has still current, you may electicuted with that component. That parts its only for qualified servicemen area only.
Aug 06, 2007 | Panasonic PT-47WX49 47" Rear Projection...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
32 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
