Question about Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker
Whirlpool icemaker makes hallow ice, I found plastic line in crawl space had a hole and good leak in it, replaced saddle valve and plastic line with 1/2 copper line installed new house shutoff valve behind fridge added new ice maker line, still hallow ice with some solid I am confused please help
  • bayou1841 Oct 10, 2009
    Defrost cycle not working. Replaced defrost timer circuit and defrost temp sensor, still not working. Suggestions
    President:
  • 1,304 Answers
You may want to change your water filter
Posted on Oct 06, 2009
Whirlpool side by side has low pressure with filter, works great without.
more than likely the saddle valve...the valve you or the plumber installed to tie into the water line and shut it off for filter install. it's getting clogged up. Turn it all the way off and on again 3 or 4 times this should clean out the little hole feeding thru the valve from the pipe.
hope this helps.
take a look here...pics of a saddle valve.
https://www.doityourself.com/forum/electric-large-kitchen-home-appliances/395295-ge-refrigerator-freezer-no-water-flow-ice-maker.html
Jan 25, 2018 | Whirlpool Refrigerators
Tip
I have the Kenmore version of this product and the same thing happened. My...
I had water leaking in to the freezer compartment of my LG french-door refrigerator (LFD25860). It was getting on to food in the main basket and embedding it in a block of ice, as well as puddling-up on the bottom of the freezer and eventually blocking the door from closing properly. Because the water seemed to be covering a wider area than you would expect from a blocked defroster drain I didn't believe that my problem was covered by the other FixYa recomendations -and it turned out I was right.
The problem turned out to be that the "funnel" that the water flows through to fill up the ice tray was blocked by a solid piece of ice. When the icemaker would call for more water it would flow down the clear tube (with the open slots on the top) hit the ice and spray/overflow in to the freezer compartment.
The solution was obviously to pop this ice out, but that did require me to remove the icemaker from the wall of the freezer compartment. To do this you
  • remove one screw from the bracket on the bottom of the icemaker
  • Slide the icemaker up and slip it off of the two screws with rubber grommets on them.
By the time I got to that stage I had already removed the basket from the main drawer and removed the pull out tray/basket from the drawer pulls (by simply lifting the plastic tab on the right side and lowering the plastic tab on teh left side). I am not sure if you can remove the icemaker without this step, but I believe so.
Also, if you want to entirely remove the icemaker from the freezer there is only one plug with wiring to undo. As I mentioned above, the water hose doesn't not connect to the icemaker, it ends above the "funnel" and the water drops in. So removal is much simpler than you might expect.
As for the cause of the ice block, I am not sure but I believe it was either because the ice maker made too much ise one time and some cubes could not pop out. When additional water entered the funnel it didn't flow in to the ice tray, backed up, and froze in the funnel. The other thought is that when the door was not closed properly while our grandparents were visiting, the ice melted and subsequently re-froze causing the problem.
on Oct 05, 2009 | LG LFD25860
We have a Samsung side by side. Ice maker on the top as part of frig. water is leaking and I see the ice stopper is not closing to keep the warm air from entering the ice compartment. Any ideas
If the icemaker is leaking water onto the floor:
  • Turn off the icemaker and then turn off the water supply to the icemaker. See Icemaker On/Off Switch.
  • The water supply line is usually located under the kitchen sink.
  • Locate the cold water line and look for a small 1/4" copper line attached to it. Where these two lines meet, there will be a saddle valve. This is the shut-off valve. Turn this valve in a clockwise manner until it stops. This will shut off the water to the icemaker.
Aug 11, 2017 | Samsung Refrigerators
Whirlpool side by side ice maker not making ice
The first thing I would check is water through the door. If pressure is low replace the saddle valve that taps into the water line. If you have strong pressure then you can remove the front panel of the icemaker and take a piece of wire and strip it at both ends. Stick it into the T and H holes on the ice maker. This will put it into harvest mode. Leave the wire in the unit until you hear a click then remove (about 15 secs) If the rake cycles all the way around without filling then you probably have a water supply issue (inlet or solenoid valve) Also check your fill tube and make sure its not frozen. If the fill tube is frozen remove it and clear it and replace your saddle valve.
Good luck. Hope this helped _MJ_
Feb 07, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
The ice maker just stopped making ice today. It's made ice great for the past 3 years. Everything else works.
If the water pressure for water through the door is low I would check your saddle valve that taps into the line. I would next check your icemaker fill tube to make sure it is not frozen. If it is then you will need to replace the saddle valve because it is due to low water pressure.
You can try to manually harvest the icemaker by turning the power switch off-on-off-on and then pushing the lever in three times in a row. This will harvest the icemaker. If the icemaker harvests and the rake moves then its most likely still good. (if theres a batch of cubes frozen in the ice maker then its def bad.) If you get it to harvest and no water comes in then you will know its a water supply issue.
Replacing the inlet valve and saddle valve will most likely correct the issue. You may only need a new saddle valve and they only cost about 10 bucks.
Let me know if this helps _MJ_
Feb 07, 2010 | GE GTS22WCP Top Freezer Refrigerator
HOW DO I ATTATCH WATER FOR THE ICE MAKER
You will need to purchase an icemaker install kit. It will come with a water line and a saddle valve. The saddle valve will be self piercing and you will need to basically mount it to your cold water pipe in your basement, crawl space or under the sink. Once the valve is mounted you need to attach the water line (plastic is easier to work with than copper and hook it to the valve. Then run it to your inlet valve on the back of the ref. You may need to drill a hole in the floor behind the ref to run the line if you are tapping into a water line in the basement.To tap the valve you just turn it clockwise and it will pierce the line. Then you should be all set to go be sure to check for leaks.
Hope this helps _MJ_
Feb 06, 2010 | Whirlpool Refrigerators
ICE MAKER NOT GETTING ENOUGH WATER
I had this problem on a refrigerator with an automatic icemaker. Where the water line attaches to the source pipe is a Self-Piercing Tap valve (sometimes called a vampire tap, or a saddle valve). The hole that this device made to feed the freezer was not allowing sufficient flow during the fill cycle of the icemaker.
I had to turn off my water and trace the water line that feeds my refrigerator back to the water source. I then disassembled the valve, enlarged the hole in the water pipe slightly, and reassembled. Turn the water back on and check for leaks. The trick is to enlarge the hole just enough to deliver the need water, but keep it small enough so the saddle valve can seal the junction.
Jan 12, 2009 | Kenmore 53642 / 53644 Side by Side...
Icemaker stopped making ice
remove the front plastic cover on the icemaker and you will see a bunch of little holes make a jumper wire out #10 or 12 house wire strip about 1/4 inch off the ends an insert in the holes marked t&h this will start a test cycle make sure you hold the plastic insulation so you don't get bit if the ice maker starts cycling remove the wire and watch for it to stop listen for the icemaker valve to open if the ice maker finishes and the valve didn’t fill replace the water valves if the icemaker doesnt cycle and you may have to kind of twist the jumper back and forth to get it to make contact depending on the gauge you used then replace the ice maker motor module if you hear the valve open and the ice maker doesnt fill check for a frozen ice fill tube that should do it
May 24, 2008 | Whirlpool ED2FHEXN Side by Side...
Ice maker freezes up
Icemaker Fill Tube Freezing Make sure the water supply is greater than 20 psi. If too low, the water valve won't seat properly and it'll "weep." Common causes of low pressure are gunked-up saddle tap valves, kinked water supply line, and using a reverse osmosis filter to supply water to the icemaker. Check to see if the black, flexible portion of the fill tube is wrinkled, twisted, or kinked which can cause ice dams that block the fill tube. It turns out that the manufacturer's have been scratching their heads about this, too, and have concluded that the new fill tube air slit design helps prevent this problem.
Apr 10, 2006 | U-Line CO2075F-B Echelon Refrigerator Ice...
Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker Logo
102 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
