Question about Juniper Networks (SSG-5-SH-BT) Firewall
I have to much sessions allocs fail. The sessions bar is always on red color
    Problem Solver:
  • 10 Answers
You sem to be maxing out the session table on your
Firewall.
If you have a SSG5, then your max session limit is 8K
To find out what your max session is type: get session info
In the below output, the max session limit is 8064
-Greg
gateway-ssg-> get session info
alloc 49/max 8064, alloc failed 0, mcast alloc 0, di alloc failed 0
total reserved 0, free sessions in shared pool 8015
Posted on Oct 27, 2009
THE COLOR ON MY RCA IS GOING INTO MORE ORANGE AND GREEN THAN RED
your not giving much information to go on such as a Model number ect . most likely there is a problem in the red screen control circuit or a red crt that has failed . you may want to see if you can find some one local with experiance that can assist you in diagnosing the problem
Mar 09, 2014 | RCA Televison & Video
I have had a P4018WT for about 5 years. I recently replaced the chain wand now I need to re tighten after 8-10 cuts. My son said that he had to do the same thing when he borrowed it. I do not think I was...
It is always a good idea to always check your chain tension on a regular basis and adjust it as required before any cutting session. That said, I would not consider that retightning your chain every 8-10 cuts (not sessions) is normal under 'domestric' usage: I would check the condition of the chain bar and more specifically the bar locking nuts (if ensure, just replace the nuts with the appropriate special bar locking nuts).
Sep 18, 2011 | Poulan 18" Wild Thing Chainsaw
I had to reset my computer but before i saved all my protools sessions to a disk now when i go to open them i get this message. "The original disk allocation for this session cannot be used. Check the...
Hi rfanklin65,
Did you remember to save the audio file folder to the disk as well as the session data? If so, are the audio files on the same disk as the Pro Tools sessions?
Are you running a Windows or Mac system?
Thanks, Krisfaudio
Apr 30, 2011 | Digidesign Mbox 2 Barebone
When my MP3 player is fully charged what color should the bar be red or green.
The bar is usually colored red when the device is low on battery power. Some devices have a red bar while in battery use. It should be green when fully charged or charging. I don't know what kind of device you have but that is the usual default colors.
Jan 12, 2011 | Audio Players & Recorders
Wire color abbreviations Isuzu Rodeo
P - Pink
LB - Light Blue
V - Violet
GR - Grey
LG - Light Green
BR - Brown
L - Blue
Y - Yellow
O - Orange
G - Green
R - Red
W - White
B - Black
Some wires will be allocated 2 colors ie B/W. This is a color with a different color line running along its length.
The first denotes the main color (Black in our example) and the second denotes the tracer line (White in our example)
Sep 09, 2010 | 1992 Isuzu Rodeo
MY MONITER CHANGES COLOR AND ITS PISSING ME OFF HOW CAN I DO IT. IT ALWAYS CHANGES COLOR MOST OF THE TIME IT CHANGES TO RED COLOR
One or two of your color guns are failing. On a CRT, there are three color guns, Red, Green, Blue. They work together to produce all colors in the spectrum. If the monitor goes all one color, it generally means at least one color gun is failing. The cost to repair far exceeds the value of the monitor or the price of a new LCD panel.
Mar 11, 2010 | HP Pavilion MX70 17" CRT Monitor
Dell Inspiron 1501 Laptop-6'' Red Vertical Line
The color red and especially red colored lines or a pinkish hue are indicative of an impending screen failure. The only other possibility is that the data cable on the left backside of the lcd panel may be loose at the socket or on the motherboard. 9 times out of 10 though, it is the lcd panel that it failing.
Jan 17, 2010 | Computers & Internet
How chat on gmail account please helpme
When you're signed in to Gmail, you should always see a Quick Contacts box along the left of your screen. Clicking on a name in Quick Contacts will start a chat session or an email. The people you can chat with have colored balls next to their names—green means they're online, yellow means they're idle and red means they're busy.
When someone IMs you, a chat session will show up on the bottom right corner. You can chat with them right there, or pop-out the entire chat session to its own window.
You can decide right at the outset to save chats in your Gmail account, but this can also be turned on or off in "Settings." And when you're chatting, use "Options" to go "off the record."
Dec 16, 2008 | Cell Phones
Screen flickers for about 20-30 seconds sporadically
Try looking at the LCD screen at a sharp angle to see if ghost-like video can be seen during the 'off' time of the flicker.  If video is still present even though not that visible, then either the backlight or its power supply are failing. The color problem could also be caused by a backlight lamp that is not ionizing completely.
Dec 14, 2008 | Acer AL1912B 19" LCD Monitor
Unable to Install Red Hat Linux Enterprises 4
when the time of installing only you have to take linux boot loader then it will show both operating systems otherwise i think the problem is monitor configuration in linux installing
Mar 24, 2008 | Computers & Internet
Juniper Networks (SSG-5-SH-BT) Firewall Logo
588 people viewed this question
Top Juniper Networks Computers & Internet Experts
David Payne
David Payne
Are you a Juniper Networks Computer and Internet Expert? Answer questions, earn points and help others
