Question about LG 42LC2D 42 in. LCD HDTV
Hello my picture seems to have shifted upwards ie the top of the image is now at the bottom of the screen then there is a black line then the next two thirds are above the black line. I think on an old tv you would call it a horizontal shift problem. tv is 37le2r
The problem was not actually the tv the fault was on the satellite box. I unplugged the box from the mains to reset it and the picture was restored to normal.
Posted on Oct 07, 2009
Samsung TSL2793HF - Slight Right Side Pincushion and Horz Line Bottom to Top Until the TV Warms up
Yes, this is rare but I have seen it before--not fixable if it is what I think it is----It is what is called a Dome effect---the shadow mask in the picture tube is actually contracting and or expanding depending on temperature---
Directly behind the phosphor coating (the stripes that you see on the screen) is a metal screen--the holes or perforations in it line up with the stripes on the phosphor screen.
Some masks either have a material or a defect causing the dome effect----Not likely to be anything else---a Pin amp problem will not usually act the way you describe but a shadow mask inside the picture tube will act exactly that way.
Dec 02, 2012 | Televison & Video
I have a 2" black line at the top of the tv. And also smaller black lines across the middle of the tv.
Dear Jeff,
It seems like the Horizontal IC in your TV is dying. This and the Vertical IC is responsible for displaying images on your TV. (Look at your TV through your Phone Camera and you will see upward scrolling lines.This is the Horizontal IC in action.)
I would strongly advise you to get your TV repaired immediately.
Oct 19, 2012 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Black bar on the top and bottom during watching the tv
Hello
If you are watching television and you see black lines on the left and right sides of the screen, check to see if you are watching an HD broadcast or a standard definition broadcast. You can do this by bringing up the TV guide menu on your remote. If the show is in HD, it should take up the full screen. However, if it is not HD, bars will be present on the left and right of the screen. That is because standard definition programing is in 4x3, which will not take up the entire screen.
If the picture you are watching not only has black bars on the sides, but on the tops and bottoms of the screen as well, your "Zoom" mode has somehow gotten off-kilter. Press the "Zoom" button on the remote until the image appears correct. If this does not work, power down the television, wait a few moments, and power the TV back on. The image should be correct now.
If the image on the screen looks stretched or squished, this is because your HD cable receiver is not set up properly for your widescreen television. Press the "Menu" button on the receiver
May 06, 2011 | Samsung 50 in. Plasma TV
How do I change it from wide screen to regular? I have a black area above and below the picture.
Hello
You can set the picture size by remote control itself.
You can vide 480i format programmes in three picture sizes. 4:3, 16:9, and ZOOM
You can change the picture size by pressing the PICTURE SIZE button on the remote control.
4:3 Picutre size
To fill the screen, the top and bottom edges are extedted more widely, although the center of the picture remains near the former ratio.
If receiving a 4:3 programme, the image size is displayed in its originally formatted proportion.
16:9 picure size
This image displays the size of standard 16:9 with black bars at the top and bottom.
If receiving a 4:3 programme, the image is displayed with black bars at the top and bottom and stretched wider.
NOTE: If a fixed bar remains on the screen for a long period of time, the image can become parmanantly engrained in the screen and cause subtle but permanent ghost images. Never leave your TV for long periods of time while it is displaying these images.
Zoom picture size [for 16:9 formats]
The entire picture is uniformly enlarged --it is stretched the same amount both wider and taller (retains its original proportion). The right and left edges of the picture may be hidden.
OK.
Dec 14, 2010 | Insignia NS- 27" TV27 TV
Picture at top of screen, bottom half is black...middle of screen has horizontal red, green line which is slightly bowed upward. model # is GE 46gw948
Call a good TV Tech and tell him the Convergence Amp IC's need to be replaced. Should not cost over $325.
Jul 29, 2009 | Televison & Video
White screen divided in half with black line
Your ccd imager is defective . You need to replace the ccd imager .You need to contact the service center to get one for your camera .
Jan 30, 2009 | Kodak EasyShare Z700 Digital Camera
Color off seems amber
Double check the wb settings in camera, (and be sure to check WB Shift) I'd suggest adding a Blue shift to your images to compensate for the Amber until you find something thats a decent trade off, if you can't eliminate the amber shift.
Dec 14, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Faint horizontal lines from top to bottom after an hour of use...
I can tell you right off the bat that is a service issue you will have to take up with sharp. Contact their operational support, they have a quick turnaround with things like that. When you call, they will most likely ask you to take digital pictures of these black lines and have you e-mail the pics to them.
Dec 08, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Half picture shows up and top portion is black
The camera firmware should be reloaded, if this fails then the camera is likely beyond end user servicing and should be repaired by a professional.
The reason your only seeing bottom half is as the reflex mirror is opening upwards to expose the sensor ( traditional cameras opened the mirror then a shutter to expose film ) your cameras sensor is only registering or transferring the bottom half of the image because it is the image is registered bottom first to the top until the shutter closes and the mirror returns to resting position.
Your problem could be the result of firmware or a more serious issue.
Aug 10, 2008 | Nikon D40x Digital Camera
White line
you have a shifted picture upwards the white line is the overlaped picture. Try accessingthe service menu and shift the picture down. Patrick
Jun 18, 2007 | Daewoo DSC-30W60N 30" TV
LG 42LC2D 42 in. LCD HDTV Logo
115 people viewed this question
Computer Repairing
Computer Repairing
