Question about Sony Playstation 3 (PS3) Console
Cant turn on from stan-by
Cant turn on from stand-by. When turn the ps3 on the light goes from green to red and cant turn on
Turn ps3 on light goes green then flashes blue then back to red
PS3 turn on goes green then flashing red is not a new issue. Please read this post and you can find the solution :
PS3 Red Light Blinking Fix
Feb 09, 2011 | Sony Playstation 3 (PS3) Console
Cant get into my ps3
you ever heard the three rings of death on xbox...the yellow light on ps3 is similar to that,you need a new ps3
Mar 01, 2010 | Sony Playstation 3 (PS3) Console
My 12th old ps3 has been faultless until 6/2/10 .It will not boot up at all .The start up red light turns to green as per normal then after 2 seconds it flashes red and goes back into stand-by mode Any...
That is the PS3 "Red light of death"
The articles below could help you fix them :)
<a href="http://ezinearticles.com/?Have-You-Got-Issues-With-the-PS3-Red-Flashing-Light?-Fix-This-Problem-Today&id=3629324">PS3 Red Flashing Light</a>
<a href="http://ezinearticles.com/?PS3-Red-Light-Fix---Quick-Guide&id=3512073">PS3 Red Light Fix</a>
<a href="http://ezinearticles.com/?PS3-Blinking-Red-Light-Problem-Solved---If-You-Have-This-Problem,-You-Really-Need-to-Read-This&id=3512063">PS3 Blinking Red Light Problem</a>
<a href="http://ezinearticles.com/?PS3-Red-Light-of-Death---How-to-Fix-it-Quickly-and-Easily&id=3512067">PS3 Red Light OF Death</a>
<a href="http://ezinearticles.com/?Thinking-About-Buying-a-PlayStation-3-Repair-Guide?-Then-You-Better-Read-This-Before-You-Do!&id=3676847">Playstation 3 Repair Guide</a>
Feb 07, 2010 | Sony Playstation 3 (PS3) Console
Red light but no green
This is known as the yellow light of death for the ps3. This can be caused by dust buildup in the console, and the console overheating. Once the console overheats, it causes the solder on the board to melt. Once melted it bridges(connect), and shorts out the board causing the error your getting now. If you have had the unit for 3 years the warranty is probably out, but go ahead and contact sony with this site:https://service1.us.playstation.com/rma.htm?_flowExecutionKey=_cAB96F84F-8DB4-2C4E-3368-C3B01BB770F5_k8997F39E-B8B8-B1EF-51B9-162937A6B113
If the unit is indeed out of warranty, go to www.wiredextreme.com. We are a console repair company based in Texas, and we can fix your console. We give a free diagnosis of what is wrong with your unit(excluding shipping), and will call with an estimate of repair. All our work comes with a 30 day warranty, and you can buy extended warranty for up to 4 years.
Nov 16, 2009 | Sony Playstation 3 (PS3) Console
My PS3 has a problem, Every time I try to turn on my PS3 the power light first goes green, then yellow- beeps twice, then turns red- blinking. Now I cant even start up my PS3 because every time I try,...
Its Died go here http://www.youtube.com/watch?v=U70SgRDVcBo&feature=PlayList&p=7671174E22A52E35&index=0&playnext=1 to fix it or Pay Sony to do it or just use it as a Doorstop
Sep 06, 2009 | Sony Playstation 3 (PS3) Console
I cant get my PS3 to work
Is your warranty purchased from Sony itself or from the place of purchase i.e. Walmart extended warranty? Return it to the place of purchase. They should have your PS3 serial number and can look it up. Once they verify you have the extended warranty, they should take care of it.
If you purchased direct from Sony, try this link:
Playstation.com Knowledge Center concerning returns
Contact Official Playstation
Addressing the actual probelm. I am not sure if this would work but turn off the PS3, Once light turns red, touch the power button and keep holding as light turns green then goes back to red. The try restarting the PS3. Thats a video reset. It may work, it may not.
More help concerning power issues on ps3 from Playstation.com
Hope this helps
Aug 03, 2009 | Sony Playstation 3 (PS3) Console
Only Green Lights PS3 dont turn on
Usually the "red light of death" on the PS3 as it is called by some people is due to hard drive (HDD) connection errors. Here are a few things you can try to do to fix it and get your console working again as intended, just check out this short video I made (it's less than 4 minutes and contains useful pictures etc)
For more information and advice on how to fix your console, if that does not do the trick for repairing your system, check out my PS3 red flashing lights repair blog.
Hopefully you get your PS3 working again ASAP!
Regards,
James Philipson
Jul 13, 2009 | DreamGear Lava Glow Wireless Controller ...
I cant start up my console
Your system has overheated. The thermal compound has heated and moved away from the CPU/GPU and the heat sync keep the heat from being dissipated via the heat sync. Eventually you will get the YLOD which is the equivalent of the Xbox 360 RROD. This is due to heat sysnc problems. Your CPU and GPU will more than likely need to be reflowed. I got the YLOD on my PS3 around the first of March 09. I also fixed my PS3 in about an hour. I have had no problems since. You can slow the YLOD but i dont believe it can be stopped. It seems it will eventually happen to all PS3's. One tip do not stand the PS3 on its side keep flat. This will help keep the thermal compound from moving as much when it heats up. Also i run a home based computer repair business in southern California. Feel free to email me at dwdpcrepair@gmail.com.
Jan 18, 2009 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
67 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
