Question about Dryers
Low heat - Dryers
  • 3 Answers
Either Electric or Gas:
Remove exhaust hose and vacuum entire length squeaky clean or purchase new if that is too much trouble. Vacuum inside exhaust port on the back of the dryer as best you can and all other ports like the lint trap and port inside dryer where air flows to the trap before it exits out the exhaust port..
If that doesn't help, leave the exhaust hose off, turn the empty dryer on and check the airflow coming out of the exhaust port. It should be fairly robust & get very warm quickly. If it doesn't and you're Electric your heating element isn't working or almost worn out. Check manual for fuse rest, if available reset and test again. If no fuse the element is shot and needs to be replaced, a fairly easy DIY'er job, Remember, safety first UNPLUG 1st!
If gas, is gas line valve turned on, if yes the igniter is most likely shot and needs to be replaced and another moderate DIY'er project. Again ALWAYS safety 1st, UNPLUG and TURN THE GAS VALVE OFF before replacing. Repeat check and reinstall hose securely after repair.
Posted on Oct 06, 2009
Dryer low heat
It sounds like one of the heating elements has gone out. I've replaced the one in mine and it's not difficult. They just plug in like the ones in an oven. You'll be able to tell which one when you get inside if that's it.
Jun 06, 2014 | Whirlpool WED8300S Dryer
Tip
HOW TO REDUCE CHANCES OF H4 CODE IN SHARP COPIERS
The code H4 is common to all Sharp copiers. This occurs due to abnormal low temperature being sensed by thermistor. This means that the heater lamp which generates heat around the fuser rollers is either not working or producing very low heat. Low heat generated comes from low power output in the mains so, when you suspect low voltage, always switch off your copier and wait for normalcy. You can see from dim bulbs and know that's low voltage.
on Dec 02, 2009 | Office Equipment & Supplies
LG Dryer low heat doesn't work
It may be as simple as checking your lint filter.
If you use fabric softeners sheets, they tend to clog the lint filter holes. Washing it with soap and water will restore it back to normal and will allow the circulation that the dryer needs to properly dry your clothes.
May 04, 2014 | LG DLEX7177 Dryer
Low heat
Dryers either heat or they don't heat. Complaints of "low heat" are always due to a restriction in the venting system.
There is either a clog in the hose somewhere or the hose is smashed. There could be an obstruction at the exit outside or the hose runs longer than 12 feet before exiting the house, to name a few.
Mar 09, 2014 | Magic Chef Dryers
2002 toyota avalon engine check light on P0078 and P007C
P0050 HO2S Heated Oxygen Sensor -Control Circuit (Bank 2 Sensor 1)
P0051 HO2S Heated Oxygen Sensor -Control Circuit Low (Bank 2 Sensor 1)
P0052 HO2S Heated Oxygen Sensor -Control Circuit High (Bank 2 Sensor 1)
P0053 HO2S Heated Oxygen Sensor -Resistance (Bank 1 Sensor 1)
P0054 HO2S Heated Oxygen Sensor -Resistance (Bank 1 Sensor 2)
P0055 HO2S Heated Oxygen Sensor -Resistance (Bank 1 Sensor 3)
P0056 HO2S Heated Oxygen Sensor -Control Circuit (Bank 2 Sensor 2)
P0057 HO2S Heated Oxygen Sensor -Control Circuit Low (Bank 2 Sensor 2)
P0058 HO2S Heated Oxygen Sensor -Control Circuit High (Bank 2 Sensor 2)
P0059 HO2S Heated Oxygen Sensor -Resistance (Bank 2 Sensor 1)
P0060 HO2S Heated Oxygen Sensor -Resistance (Bank 2 Sensor 2)
P0061 HO2S Heated Oxygen Sensor -Resistance (Bank 2 Sensor 3)
P0062 HO2S Heated Oxygen Sensor -Control Circuit (Bank 2 Sensor 3)
P0063 HO2S Heated Oxygen Sensor -Control Circuit Low (Bank 2 Sensor 3)
P0064 HO2S Heated Oxygen Sensor -Control Circuit High (Bank 2 Sensor 3)
P0065 Air Assisted Injector -Range/Performance
P0066 Air Assisted Injector -Circuit Malfunction or Circuit Low
P0067 Air Assisted Injector -Circuit High
P0068 (MAP) Manifold Absolute Pressure /(MAF) Mass Air Flow - Throttle Position
Correlation
P0069 (MAP) Manifold Absolute Pressure / (BARO)Barometric Pressure Correlation
P0070 Ambient/Outside Air Temperature Sensor -Circuit Malfunction
P0071 Ambient/Outside Air Temperature Sensor -Range/Performance Problem
P0072 Ambient/Outside Air Temperature Sensor -Circuit Low Input
P0073 Ambient/Outside Air Temperature Sensor -Circuit High Input
P0074 Ambient/Outside Air Temperature Sensor -Circuit Intermittent
P0075 Intake Valve Control Solenoid Circuit Malfunction (Bank 1)
P0076 Intake Valve Control Solenoid Circuit Low (Bank 1)
P0077 Intake Valve Control Solenoid Circuit High (Bank 1)
P0078 Exhaust Valve Control Solenoid Circuit Malfunction (Bank 1)
P0079 Exhaust Valve Control Solenoid Circuit Low (Bank 1)
P0080 Exhaust Valve Control Solenoid Circuit High (Bank 1)
P0081 Intake valve Control Solenoid Circuit Malfunction (Bank 2)
P0082 Intake Valve Control Solenoid Circuit Low (Bank 2)
P0083 Intake Valve Control Solenoid Circuit High (Bank 2)
P0084 Exhaust Valve Control Solenoid Circuit Malfunction (Bank 2)
Mar 22, 2013 | 2002 Toyota Avalon
Kennmore Elite HE4 no heat on low or extra-low setting
Assuming this is a gas dryer, it is likely the igniter has failed. The igniter plate has to heat up to glowing in order to heat up the thermocouple that turns on the gas valve.
Sep 03, 2012 | Kenmore Dryers
Hi Sir my heatbgun is still starting but the problem is its air takes time to heat even if i turn its heat control to the max . What could be its problem?
Usually you should have heat very quickly. I can think of a few things that might cause low heat. One would be a low power level at the outlet. The other might be the heater element is just about worn out. And third is the power or heat selector switch is faulty.
I've seen the low heat from low power caused by too long extension cords as well as low power levels. Try plugging into a different outlet and directly and see if it heats up normally.
Unfortunately if it is a problem with the heater element or the switch unless you are under warranty you would have to buy a new unit. If you have warranty then you should contact the store you purchased or McCulloch about getting it replaced.
Sep 02, 2011 | McCulloch Heat Gun Kit
PRINTER LOW HEAT ERROR
Low heat means either the fuser is not heating up or it is not sensed properly. you can find a new fuser at www.precisionroller.com but the low voltage power supply could be bad as well.
Oct 29, 2009 | Samsung SCX-4100 All-In-One Laser Printer
Dryers Logo
50 people viewed this question
Top Dryers Experts
