Question about Samsung Prostar 816 Phone
I moved system to new location but have not installed for several months,i can not find my service manual to set up system.when i plug in the phones they make noise and beep and all lights are flashing
    President:
  • 860 Answers
The beeping and such is hapening because the wiring is reversed. In that case exchange the red and green wires with each other and the yellow black wires with each other.
Posted on Oct 06, 2009
How do I remove administrator password on the BIOS of Optiplex 390
The CMOS contains the current BIOS settings
  1. Turn off the computer and disconnect the power cable from the electrical outlet.
  2. Remove the computer cover.
  3. Locate the 2-pin password connector (PSWD) on the system board.
  4. Remove the 2-pin jumper plug.
  5. Locate the 2-pin CMOS jumper (RTCRST) on the system board.
  6. Move the 2-pin jumper plug from the password jumper to pins into the CMOS jumper.
  7. Plug in AC power to the system and wait ten seconds for the CMOS to clear.
  8. Move the 2-pin jumper plug back to the password jumper.
  9. Replace the computer cover.
  10. Connect your computer and devices to electrical outlets, and turn them on.
Location of the RTCRST Jumper will vary by platform and form factor. For more information about the jumper locations refer to the system service manuals located at www.dell.com/support/manuals
Aug 15, 2016 | Dell OptiPlex 390 DT Desktop Computer...
Hep needed....
You may download a copy of the manual by entering the model number of your VTech DECT 6.0 phone into the box at http://www.vtechphones.com/support/general/manuals
Dec 23, 2013 | Vtech DECT 6.0 Cordless Phone with Digital...
My water heater needed to be restarted and my comfort recirculation system isn't working now.I"m hoping it is just the timer. I need to reset the timer and I don't know how. I can't find my manual....
Grundfos timer and pump operate by plugging into ordinary 120V outlet.
1) If outlet has power, then dial on timer should rotate.
If dial is not rotating, then check power to outlet.
2) If outlet has power, but timer is not rotating then timer has gone bad > if grundfos pump is working but timer is not working, you can buy cheap plug-in timer and use that as the timer.
3) If outlet has power and pump is not working, then manually rotate timer dial to see if pump will start.
If pump will not start, then you need a new grundfos.
There are no repair parts for these pumps, and nobody at Fixya has reported taking Grundfos apart and repairing it.
My Grundfos pump will not come apart.
4) Following link has links to Grundfos installation manual, website, product manuals, and contact.
http://waterheatertimer.org/Water-heater-recirculation-system.html#Grundfos
5) To set timer: Grundfos timer dial has movable pins that are used to set on-off times.
When pins are pushed out, timer turns pump ON.
6) Rotate timer dial clockwise until current time lines up with arrowhead located on inner dial.
Dial rotates as time passes, and pins move a lever that turns pump on-off.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on Grundfos or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 09, 2011 | Grundfos Comfort System Recirculator ...
Hpm 24 hr manual timer , i dont know how to get it working
HPM 24 hour timer has segments located around dial.
http://waterheatertimer.org/Woods-timers-and-manuals.html#HPM-dial
http://waterheatertimer.org/images/hpm-24hr-timer-500.jpg
Segments appear to move up or down.
Other similar timers: Segments down = Load ON; Segments up = Load OFF
Press several segments down.
Plug timer into wall.
Plug 240Volt load into timer.
Manually rotate timer dial clockwise to see if segments down turn load on or off.
There is also a 2-position slide-switch located on top of timer.
Move slide switch to each position to see which is need for timer to turn load on-off.
After positions are defined, push segments down or leave segments up for times you want load to turn on.
Rotate dial clockwise until current time lines up with arrowhead located on inner dial.
Timer dial rotates as time passes, and segments move a plastic lever that turns load on and off
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Jan 20, 2011 | Hardware & Accessories
How to move my ext# to a new phone location Nortel t7316E
The system has a built-in feature called "Set Relocation", which will allow you to move your phone to another active telephone jack in your office and the extension number, voicemail box, and all features will stay with your phone.
Have your system administrator turn on Set Relocation, or check your Norstar administration manual for programming details. Or, you can call your telecom service company and have them send a technician.
May 14, 2010 | Nortel Norstar 16-Line PBX Speakerphone
I cant get my T7208 to ring
Norstar doesn't like phones to be moved around some times on the old norstar systems moving phones caused problems. How old is this system and in programming there is a setting called set relocation this has to be a yes to move sets.To move a set to another local unplug both sets wait 1 min. plug one set in it's new local wait 1 min. plug other set in its new local.
Nov 22, 2009 | NorStar T7208 Corded Phone
Are you able to move or change extensions?
First, move the telephone sets back to where they were.
Next, we'll have to change the system programming.
Programming2.gif is done on 7310, 7324 and 7316 type sets.
Enter programming2.gif by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming2.gif.
At the terminals&sets prompt, press the next key 7 times(bottom right arrow).
The display should say system programming.
Press the show key (top right arrow)
The display should say hunt groups
Press the next key 2 times(bottom right arrow) .
The display should say Featr Settings
Press the show key (top right arrow) .
The display say Backgrnd music2.gif.
press the next key 20 times (bottom right arrow)..
The display should say set relocation.
Press the chng key. change from N to Y.
Press the release key when finished
Move sets from their old locations to their new locations
Sep 28, 2009 | NorStar Meridian M7310 Phone
I'm looking to rotate phones around the office so that they can remain with their employee. Basically, I want to plug in the original phones to another line and reprogram for the original extension with...
In my workplace, when you move the Nortel M7100 phone, the programmed info (extension number, etc) moves along, just like if I was rewiring all phones. Have you tried just to unplug the phone and plug it on the new location? Here the extension number moves along with the equipment... (Nortel Norstar M7208 and M7100). Good Luck!
Jul 02, 2009 | NorStar M7310 Corded Phone
Office Moves/Swaps
pretty new to this myself but ive moved a few numbers around from the server room.
ours is set up with the proper ext numbers on the extensions around the office and in the server room i have those numbers on a hub with another hub with ext numbers for the phones.
you will have to unplug the correct ext cable and plug it back into the new ext number for the office its going to
sorry if this is no good or not what your looking for, pretty new to this and if it does help then excellent
May 02, 2008 | NorStar M7310 Corded Phone
How do you program keys to call phone to phone
This is a little more complicated in a Norstar system because of an optional feature they have to remember phone settings when replacing phones. Normally a phone system port is programmed for one person.. let's say Kathy... the programming is stored in the system so you can plug in any phone that is compatible with that system at that port and it will be set up for Kathy. The Norstar has a feature that lets you move Kathy's phone to another location on the system, the system detects the serial number of the phone and moves Kathy's settings to that new port. BUT if Kathy's phone is broken you can plug another phone into Kathy's port and that new phone will now be Kathy's phone erasing Kathy's old phone from the system.
So, you could have a combination of some phones holding the settings of the original user in a new location while others do not. Also, if Ilene's port was originally on say extension 107 but in your new location there is no phone at location 107 the button would no longer work and it would say something like you say "not in service"
Nov 20, 2007 | NorStar M7310 Corded Phone
Lands Phones Logo
106 people viewed this question
Top Samsung Lands Phones Experts
ray gallant
richie46
Are you a Samsung Lands Phone Expert? Answer questions, earn points and help others
