Question about Maytag Dishwashers
Washer fills, runs 5 seconds and stops for 5
Magtag dishwasher fills, runs 5 seconds and stops for 5 seconds. repeats this 3 times and then stops all together and lights on panel go out
  • 120 Answers
Major problems here. Sounds like a circuit board thing. If the machine is on the old side , ditch it and start new.
Posted on Oct 06, 2009
Quiet Partner IV. Why is the pots and pans light blinking and it won't run?
Its normal for the drain pump to run for 5 to 15 seconds and then your washer should fill and you wash pump should run if your was pump is not running and just makes a humming sound then your start capacitor may need changing see the link below this is a simple task and not expensive. When ordering a new capacitor make sure it is the same size in ?F.
Washer Motor Capacitor part 8572717 How To Replace
May 28, 2015 | Whirlpool Dishwashers
Washer repeats entire cycle - does not stop at end of spin cycle.
It is possible that presence of moisture within the START button can trigger the cycle to continue as it keep the processor to continue the wash cycle,Hence you must remove the panel and board after disconnecting the wiring harness and use a hair dryer to warm off any presence of moisture on the panel and board. Do it with time to ensure there is no moisture within the panel.
I think this must solve the issue. Repeat the work many times as sometimes moisture and dirt together might form a conductive bond to trigger as a pressed on switch. If possible open panel to clean switch pad.
Jan 23, 2013 | Kenmore 2.1 cu. ft. Compact Portable...
It has an F1 error code. It will start the water flow for about 2 seconds. Stops and beeps f1 on the screen. I hit the stop button and start again and have to repeat this 3 times before the wash machine...
The manufacturer has issued a remedy for the F-1. What you do is empty the machine of water and unplug it. Open the control panel and remove the pressure hose. Blow out the hose to remove sediment . Re secure it to the control and retry. No parts needed. F-1 Error infothemobilian_1223.jpg
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Feb 01, 2011 | Kenmore Oasis HE 27082 Top Load Washer
Water is not pumped away, or stops in the middle of a cycle and displays one of a several error messages
Recall the error codes by activating the Automatic Diagnostic Test Mode to determine the cause of the problem. Select any one button, except Power, Start, and Stop, and follow this:
Press and hold the button for 3 seconds>Release the button for 3 seconds>Press and hold the button for 3 seconds>Release the button for 3 seconds>Press and hold the button for 3 seconds
All of the indicators on the console will light up for 5 seconds while 88 is displayed on the Estimated Time Remaining display. If not, repeat the step. Let us know if it cannot be activated.
The program then checks for any saved error codes after 5 seconds. List down the codes and post it back here. The console indicators will turn off then on with the 88 displayed if no error codes are recalled. After 5 seconds, the automatic test begins. The program performs a four-minute automatic test to check major washer functions. Press the same selected button in activating the automatic test above to advance through the automatic test steps.
  1. C0: The motor goes to a slow spin.
  2. C1: Warm water fills through the fresh dispenser and basket floats then disengage.
  3. C2: Cold water fills through the bleach valve for 10 seconds.
  4. C3: Hot water fills through the fabric softener valve for 10 seconds.
  5. C4: Warm water fills through the detergent valve for 10 seconds.
  6. C5: Agitates for 15 seconds.
  7. C6: Recirculates for 10 seconds.
  8. C7: Drains to engage basket and drain further for 10 seconds.
  9. C8: Drains and spins slowly.
  10. C9: Coasts to stop.
  11. Press the Stop or Power button to cancel/exit the test.
Inform us about the result of the test for the repair guide if necessary.
Feb 10, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Dishs have soap flim
If your dishwasher has been in use for a period of time, you may need to clean the interior of the washer.
The next time you are at the grocery store, pick up (2) containers of "Tang" orange drink. With no dishes in the dish washer, fill the soap container with Tang, close the lid and poor the remaining Tang in the bottom of the dishwasher.
Close the door and run through your regular wash cycle. You may have to repeat this with the second container if it is an older model washer.
The citric acid in the Tang will clean the soap scum off the inside as well as the pump chamber inside the washer.
Good luck, it worked for me, cleaned it nice and shinny and smells good too.
Regards,
Aug 13, 2009 | Dishwashers
Purging ge profile smart dispense dishwasher
How to Purge Incorrect Liquid Detergent from the Bulk Dispenser
The purge routine operates the bulk dispenser pump continuously to drain the bulk dispenser tank when an incorrect liquid was poured in the tank. The process consists of setting up the dishwasher to run the purge mode, running the purge mode and then cleaning up the purged detergent.
Follow these steps carefully to have a successful purge run.
For Top Control Models:
  1. Make sure Pre-wash, Added Heat and Heated Dry LEDs are off.
  2. Press Heated Dry and Down Arrow buttons together for 3 seconds. All LEDs will illuminate.
  3. Press Added Heat and Up Arrow buttons together for 3 seconds. The Anti-bacteria LED will illuminate
  4. Press Start button one time
  5. Select Normal and make sure Pre-wash, Added Heat and Heated Dry LEDs are off.
  6. Press Start button one more time and dishwasher will run a complete cycle without the main motor running. Cycle is complete when the Clean light illuminates. This should take approximately 60 minutes.
  7. Open door and wipe up excess detergent from the door and tub
  8. Flush remaining detergent off by pouring water on the door and tub where there is detergent residue.
  9. Remove SmartDispenser cap and fill tank with water and then replace cap.
  10. Repeat Steps 1 through 9 one time.
  11. Then, repeat Steps 1 through 6. When the Clean LED illuminates, the system is purged and ready to be refilled with the correct detergent.
Front Mount Controls (same as above except for the changes in the two below steps):
2. Press Heated Dry and Cookware together for 3 seconds. All LEDs illuminate.
3. Press Added Heat and Cookware together for 3 seconds. The Anti-bacterial LED illuminates.
Jul 05, 2009 | GE 24 in. Profile PDW9880JSS Built-in...
Dish washer 665.13824k601
LOCK LIGHT STAYS ON AND WILL NOT START. I HAVE TURNED THE POWER OF AT ELECTRICK PANEL AND IT STARTED ONE TIME. BUT DID NOT START ANYMORE.
HELP
Nov 27, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
GE Washer WSSH300GWW front loader washer CONTROL LOCK!!
Solution: Hold down the power and delay start button at the same time. In about 3-4 seconds a beep will occur and the red key lock will turn off. I think it is a problem in the machines firmware. I just guessed at what combination of buttons the engineers used to do a firmware reset. In any case it worked for me.
May 23, 2008 | Kenmore Elite 45986 Front Load Washer
Maytag washer panel show a red light that say control lock what if anything i can do to releaseit
Try the "End of Cycle" button to the right of panel front, next to Start button. Mine says hold for three seconds to lock/ unlock control.
Mar 10, 2008 | Washing Machines
Dishwashers Logo
196 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
