Question about Bosch Axxis WTL 5410 Electric Dryer
Bosch TD WTA3000 can't find reset button
Please tell me where I can find the reset button. The drum is turning but no heat. I have taken the back panel off but don't see a red button.
  • 82 Answers
YOU NEED take out hood cover 210162 in the back dryer.
Posted on Oct 06, 2009
Bosch dryer will not heat
If you have a Tumble Dryer that is not heating up but the drum is turning ok, then the chances are the thermal overload cutout has tripped. Bosch dryers have a reset button but you will have to remove the heater cover panel to access it, you will find it just above the heating element (a black stat with small red button) simply press the red button and if it clicks you've fixed it.
It also may be:
If the dryer doesn't heat, but the drum turns, check the thermal fuse(s). The thermal fuse protects the dryer from overheating and helps to prevent fires. If the thermal fuse is blown, it will have to be replaced
Dec 13, 2013 | Bosch Nexxt 800 Dryer
What is recommended load size for Bosch Nexxt dryer
The Bosch Company is probably known best for its high-end dishwashers, but the company also produces other home appliances including refrigerators, stoves, washers and dryers. Bosch dryers carry the Energy Star rating. A Bosch dryer has a structured drum that provides more thorough drying and condensation drying for faster cycle completion. If mechanical problems occur with the dryer and troubleshooting efforts fail, performing a reset may return the dryer to normal functioning.
Instructions
1Unplug the Bosch dryer from the power supply and then reconnect to the power supply.
2Replace the local fuse or reset the circuit breaker if a fuse or circuit breaker has tripped.
3Place items to be dried into the dryer and select a program. Close the door firmly.
4Press "Start/Pause."
5Press "Stop/Cancel" if the above steps do not resolve the problem.
6Pull the dryer out from the wall and use a standard screwdriver to remove the central metal plate on the back of the dryer.
7Locate the small red reset button above the heating element and press and hold the button for a few seconds. Release the button.
8Place the back access panel back on the driver and move the dryer back against the wall. Repeat steps 3 and 4. If the problem continues, press "Stop/Cancel," turn off power to the dryer and contact an authorized service technician for assistance.
Jan 09, 2013 | Bosch Nexxt WTMC 3300 Electric Dryer
Hello, I have a Bosch Axxis electric dryer that when i turn it on and hit the start button the light comes on telling me that the unit has started but it is not spinning. Also there is not any heat being...
Hi, Welcome to FixYa. If you turn the drum by hand do you feel any airflow out the back ? (you need to undo the vent hose too) This will tell you if the belt is broke. Let me know and we can go forward from there. Regards, Macmarkus :)
Mar 21, 2011 | Bosch Axxis WTA 3510 Electric Dryer
My Bosch Axxis WTL 5410 will turn on and spin but no heat comes out of it. I cleaned the heat exchanger and wiped down the moisture sensors inside the drum, but still can't get heat out of it. I've read...
How long have you had the dryer (is it still under Warranty) and do you have the owner's manual and have you looked in it for a solution?
If not then you can contact the manufacturer on line to pose the problem to them.
There may not be a reset button on it at all. If there isn't then it is more than likely the heating element and you will have to replace it.
Oct 17, 2009 | Bosch Axxis WTL 5410 Electric Dryer
RICOH AFICIO 2027 SC392 CODE,IM AN ENGINEER AND RESET SC CODES BUT STILL DOESNT WORK. HAVENT COME ACROSS THIS BEFORE.I KNOW ITS TD SENSOR FAULT, CHANGED WITH ANOTHER 2ND HAND UNIT I KNOW WAS WORKING FINE...
• Someone forgot to remove the toner
seal of the PCU
• ID sensor defective
• TD sensor abnormal
• Drum does not turn
• Development roller does not turn
• Poor connection of the PCU drum unit
Clean connector of TD sensor and
Try Change the development unit, adjust TD sensor.
Clean and you verify the connector of PCU.
Good luck...
Oct 12, 2009 | Ricoh Aficio 2022 All-In-One Laser Printer
Locked up AL-1642CS with blinking Drum Light
the clear key may be stuck which seems to lock up your machine. The procedure to reset the drum lite is clear, auto (exposure setting), clear, auto when hit in a timely manner the display will go blank. Enter 24 then press the start key, then enter 07 and press the start key again. If you can't get the keys to work the circuit board may have cold solder joints.
Good luck
Bob
May 03, 2009 | Sharp AL-1642CS Copier
Dryer drum will not turn
check to see if there is a little red button on the back if so push it in thats your re-set button
Mar 24, 2009 | Dryers
Bosch tumble dryer wta3000 drum turns but no heat
there is a small red reset button on the back of the dryer mine used to do that every now and again just press it and it works
Feb 25, 2009 | Bosch Dryers
Bosch WTA4108 Dryer Not Heating
check and make sure you have 220 volts leving panel and @ the dryer motor runs on 110 volts takes 220 to heat
Oct 19, 2008 | Bosch Axxis WTA 3510 Electric Dryer
Bosch nexxt 500 series dryer
I just had the same problem, motor runs but no heat. I had a fun time figuring out how take the front panel off, hint the rubber seal comes off easily. It looks like mine tripped the resettable over heat sensor. So far so good.
Jul 30, 2007 | Bosch Nexxt WTMC 3300 Electric Dryer
Bosch Axxis WTL 5410 Electric Dryer Logo
712 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
