Question about Lands Phones
My homephone keypad is crackling when I punch in a number,and intermittently I'm getting a message saying that a local number is out of range!
  • 32 Answers
If this is a cordless change your batteries.also check for a stuck number key or #&*
Posted on Oct 06, 2009
My whirlpool accubake oven works but it won't stop beeping
The keypad is failing and pushing buttons by itself intermittently, use your model number to search for a new key membrane.
May 12, 2016 | Whirlpool Kitchen Ranges
Random intermittant crackling sound from Hotpoint electric oven
This could be insulation on the wiring or more importantly the connecting spot might be frying. In any event, disassemble it and check into it.
Feb 24, 2013 | Hotpoint Ovens
Displayed error message F-2. Now it will start but the cancel/off button will not work and i can only stop the machine by opening the door. It feels warm inside.
F2 on a Kitchenaid means you have a shorted membrane keypad.It's not uncommon for it to be intermittent or partially operable.
On these models, the membrane keypad is not available as a separate part, so you would have to order the control panel frame assembly which comes with a new keypad.
In this case, you simply move your circuit board into the new frame. That is a simple do-it-yourself job.
You can find helpful exploded view diagrams and order parts by entering your full model number (with suffix) from the tag on the oven here.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Then you unplug the keypad (as per the photo below) and move the circuit board into your frame.
Some connectors on the relays may have a lock:
Jul 09, 2011 | KitchenAid KHMS155L Microwave Oven
Htr 6030 crackling sound when using dynamic range standard or max
The manual (on page 47) says the settings are only effective when decoding Dolby Digital or DTS source signals. Does that conflict with your symptoms or match them?
Mar 25, 2009 | Yamaha HTR-6030 Receiver
''Cavity Size 30'' message appeared, can't get rid, can't use oven
Had the same message on my display after spilling water on the cooktop. Obviously, the seal (rubber gasket) that prevents liquids getting inside the control area is not very good.
I replaced the Control (p/n: 10181439 / 9761799, 2 numbers, same part) and the flat cable between the touch keypad and the Control (9762781).
After turning the breaker back on, only had the message to set the clock.
Feb 23, 2009 | KitchenAid KERS807SSS Electric Kitchen...
Kitchenaid YKGRT607HS6
F2:E0 is shorted keypad, and F2:E1 is no keypad connection, you need to replace the keypad.
You can find schematics and find replacements by entering model number here.
Dec 14, 2008 | KitchenAid KGRA806PSS Gas Kitchen Range
Message EO F2 on the panel
EO and F2 means you have a shorted keypad. Or the oven temp is too high. The cheapest route to go is to replace the oven temp sensor first. If you give me the model number i can get the part number. If the oven temp sensor doesnt fix the problem You have to replace the electronic control. Check to see if there is a y near the end of your model number. if there is then it is most likely just the sensor. If there is no y then it is most likely the electronic control. (this is what my code chart says) But you can try the oven temp sensor anyway. It may fix it.
Nov 21, 2008 | KitchenAid KERA205P Electric Kitchen Range
Keypad I9 cect
When making a call there are three items above the pictures on the bottom of the screen, one is to choose options, the other is H-Free on the right. You want to hit the middle one which is a green telephone button which will bring you to the keypad to punch in ext and voivemail info
Nov 11, 2008 | Dual Electronics CECT P168 Cellular Phone
Kitchen Aid KESA907 Error F2E0 Stuck Key
Turn off the breaker and wait for 5 minutes. the follow these steps:
--> After turn the breaker back on, go to the range and press "OFF", "OFF", "START", then click on the "clock set", there is a message on the display saying that do you want to delete the error, at this time press on the "START" again. And wait for a while until the everything on the screen disappear except the clock time. Hope this will fix yours. It fixed mine.
Apr 24, 2008 | Whirlpool GERC4110PS Kitchen Range
Cable & Wireless CWD265 homephone operating manual
you need to press the tape button (looks like an upside-down pair of goggles), the screen will say ANS RECORD if the answering machine is switched on, you then need to press the PLAY button (on my phone PLAY is written under the number 2)
Nov 07, 2007 | Lands Phones
Lands Phones Logo
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
