Question about Xante CL30D Led Printer
Xante cl30 toner reset
How to reset the low toner error i am using toner refills
  • fareed1025 Oct 06, 2009
    my printer is a xante cl30 laser printer i need to reset the low toner message i use toner refills and after fill up with toner the low toner error keeps coming up (printer does not recognise that the toner cartridge is full)
    how to reset consumables count toner drums transfer belt on xante cl30 printer
    Guru:
  • 1,049 Answers
Turn off the printer
Turn the printer on whilst holding down Menu button. (Display says user maintenance.)
Press the menu button three times. (The display will say drum counter reset.)
Press enter key. The system should go back on line, if not press on-line key.
Posted on Oct 06, 2009
  • 4,281 Answers
First press on\off button for 10 secodns.
Then pull toner from printer.
Then check there is not any paper jam.
Also clean dust and blur thing from printer.
Then refix toner then check.
Le me know if you need more assistance.
Thanks.
Fatal error 142 xante Cl30
it's a problem with cyan ID. clean the cyan drurum's contact and the cointacts inside the printer where cyan drum ''sits''. if not try with a used drum.
Aug 22, 2012 | Xante CL30 HSE Laser Printer
Xante cl30 printer drivers for windows7 32bit & 64bit
go to www.xante.com -->support -->drivers & docs -->legacy products -->cl30
Aug 20, 2012 | Xante CL30 HSE Laser Printer
Fatal error 133 xante cl 21. Course for this
yellow led head. swap yellow with cyan and see if the error changes
Feb 14, 2011 | Xante CL30 HSE Laser Printer
Xante CL30 Fatal Error 177
I think that's a buffer overflow error, but if you get that error no matter what you print I would check to make sure your memory isn't bad.
Feb 13, 2009 | Xante CL30 HSE Laser Printer
Xante CL30 Fatal Error 127 Code
When to many consumable is low at the same time.
Oct 08, 2008 | Xante CL30 HSE Laser Printer
Xante cl30
If the printer is still under warranty, and a new yellow drum doesn't fix the problem, or if you install a new drum and the problem returns, Xante should provide you with warranty support. This problem can be caused by a defective high voltage power supply, and that is not a user replaceable item.
May 02, 2008 | Xante CL30 HSE Laser Printer
Xante Cl30 laser printer error
Error 125 is indicating an error detected at MT home position, which means the transfer belt may not be returning to the proper start position. The normal solution to this, if it persists after a restart, is to replace the transfer belt.
Mar 26, 2008 | Xante CL30 HSE Laser Printer
Xante CL30D Led Printer Logo
192 people viewed this question
Top Xante Office Equipment & Supplies Experts
edy copier
edy copier
Are you a Xante Office Equipment and Supply Expert? Answer questions, earn points and help others
