Question about Motorola Mobility i776 Cell Phone
Connectivity in advanced settings, the network ID, also baud rate
In the settings menu. Under advanced. I need to know what connectivity should the network id be set at? ID 1:5 , 2:9, 3:15, 4:21.
Also under the same menu what should the Baud rate be set at?
How do I access system settings to change the baud rate and turn off ECM.Thanks in advance.
Fax settings for VoIP ' How to lower the Baud Rate ' Faxing ...
www.voipmechanic.com/voip-fax-settings-9600-baud.htm
How to Lower the BAUD rate to 9600 on fax machines for better VoIP faxing success.
Faxing over VoIP, the correct configuration settings that you ...
www.voipmechanic.com/faxingissuesandotherdevices.htm
How to fax over VoIP and the settings and configurations, like BAUD rate that you need to set.
Dell VoIP Fax Settings, how to lower the BAUD rate and ...
www.voipmechanic.com/voip-fax-settings-dell.htm
VoIP Fax settings for Dell printer/fax machines/multi-purpose machines.Missing: kyocera
Faxing over VoIP - Sfax
Dec 15, 2015 | Kyocera FS-1128MFP FS-1128MFP...
Bricked. firmware needed
It's kinda hard to answer these when we don't know the product name or model number. If the device has an RS232 serial port, you can usually use it (9600-8-N-1) to get to the boot menu, and there is often an option to upload firmware via XMODEM.
Caveat: if the boot menu gives you the option of increasing the baud rate above 9600, use that before starting the transfer. 9600 baud means ~9K/sec, which translates to roughly 2 minutes per Megabyte.
Feb 28, 2014 | NetGear Computers & Internet
Change baud rate on brother fax machine
Lowering the Baud rate on Brother fax machines.
  • Press the Menu or Menu/Set key. Then Fax, Miscellaneous and Compatibility.
  • Press the Up or Down key until you can select Basic. Basic reduces the modem speed to 9600 bps.
  • Press OK or Menu/Set or Set key.
  • Press Stop/Exit.
Note these instructions should work for the following models: Fax-1835C, Fax-1840C, Fax-1940CN, Fax-2440C, Fax-2820, Fax-2825, Fax-2920, MFC-210C, MFC-215C, MFC-240C, MFC-3240C, MFC-3340c, and most other MFC models.
http://www.voipmechanic.com/voip-fax-settings-9600-baud.htm
Mar 06, 2012 | Brother FAX-8360P Plain Paper Laser
Need to the baud rate how do you do it
Enter Maintenance Mode:
1. Unplug power from rear of Fax machine, hold the Menu button while plugging power back in. Continue to hold the Menu button until "Maintenance" appears in the LCD window.
2. There are no helps for the Maintenance mode. Follow parameter change procedures to the letter.
Changing Baud Rate from Automatic to 9600:
1. Enter 10 (one, zero). This will bring up WSW00 on the LCD window.
2. Change the 00 to 19. If the baud rate is set to automatic, the numbers that appear will be 11100010.
3. Change the 11100010 to 01100010. This sets the baud rate to 9600.
4. Press the "Set" button just below the LCD window.
5. Press "Stop".
6. Enter 99. This will exit Maintenance mode and make the fax ready to use again.
Feb 15, 2011 | Brother IntelliFax-4100e Fax
My sylvania notebook keeps displaying baud rate setting error which is enabling me to connect.
If you are getting the error code concerning the baud rate.. You need to go into my computer, click on control panel, go into network and connections and delete my connection. This will take care of the error message then you can continue to connect your device to wifi.
Hope this helps
Sep 16, 2010 | Sylvania G-Netbook
Need to connect to the console port what are the settings
This all depends on what model of firewall you have.
But the settings are most likly
Baud Rate: 9600
Data: 8 bit
Parity: none
Stop: 1 bit
Flow control: none
You may need to play with the Baud Rate
Oct 20, 2009 | Computers & Internet
Need to change Baude rate of HP 4215 all-in-one mechine
1. Press the setup button (upper right corner of the fax machine)
2. Keep pressing the setup button until you get to the fourth option which says "Advanced Fax Setup"
3. Press OK to select the "Advanced Fax Setup" menu
4. Then using the left or right scroll arrows (below the OK button) scroll till you get to the sixth option which says "Fax Speed"
5. Press OK to select this menu item
6. Press the right scroll arrow till you get "slow" for the fax speed.
7. Press OK to accept this selection.
Then initiate a fax as you normally would.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 12, 2008 | HP OfficeJet 4215 All-In-One InkJet...
Forgot my unlock code
forgot to unlock my motorola i855e phone number
Jun 24, 2008 | Motorola Mobility i855e Pay-As-You-Go Cell...
Baud rate
1. Why 9600?
Because you are using a VOIP service it can from time to time lose connection briefly. The slower the speed the less data can be loss do to network congestion. It also gives the error correcting function of the receiving fax a better chance of filling in any lost data.
9600 is a good choice becasue the industry minimum is 9600. This means you will be able to communicate pretty much any fax thats is still tickin today. Raising the speed will get you a faster transfer but will also increase the chance that you are sending data at a faster rate than the recieving fax can send.
2. How to change the baud rate....
Press Menu/Set, 2, 0, 1.
Press ▲ or ▼ to select Basic or
Normal (or High*).
Press Menu/Set.
Press Stop/Exit.
* High is available for FAX-2910, FAX-2920
and MFC-7225 only.
Note
bps. Unless interference is a recurring
problem on your phone line, you may
prefer to use it only when needed.
Normal sets the modem speed at
14400 bps.
High sets the modem speed at
33600 bps.
May 28, 2008 | Brother IntelliFax-2820 Laser Fax
HELP, LG SHINE 970
Internet Setting Cingular:
Profile Name: Cingular
GPRS setting:
APN: wap.cingular
User Name: WAP @ CINGULARGPRS.COM
Password: CINGULAR1 (ALL UPPERCASE)
Time Out: Off
Primary Gateway IP: 66.209.11.61
Port: 9201
Secondary Gateway IP: 0.0.0.0
Port: 0
DNS Server:BLANK
CSD setting:BLANK
Dial in number NONE
Query at Logon: (NO CHECK MARK)
User Name
Password
Baud Rate Auto
Line Type: ISDN
Time Out Off
DNS Server:
Then go to your browser and enter the following settings:
Profile Name: MEdia Net
Homepage: device.home
Network Link: Cingular
MMS Settings:
Profile Name: MMS over HTTP
MMSC: http : //mmsc.cingular.com/ (No Spaces)
Max Sending Size: 30K
Network Profile: Cingular
Internet Setting T-Mobile
T-MobileWeb Settings:
Primary IP Address: 216.155.165.050
Secondary IP Address: (Blank)
Access Point Name (APN): wap.voicestream.com
Data Bearer: GPRS
Profile Name: GPRS
Username: (Blank)
Password: (Blank)
Home Page: http://wap.myvoicestream.com
Picture Messaging Settings:
Multi-Media Service Center (MMSC) Address: http://216.155.174.84/servlets/MMS
Validity Period: 72 hours
Hide ID option (if option exists): set to off, no, or disabled
Internet Setting FIDO
Profile name: FidoWAP
GPRS setting:
APN: wap.fido.ca
Username: fido
Password: fido
Timeout: 15 minutes
Primary Gateway IP: 205.151.11.11
Port 8080
Secondary Gateway IP: (blank)
Port: (blank)
DNS Server: (unchecked)
CSD Setting:
Dial in number: (blank)
Query at logon: (unchecked)
Username: (blank)
Password: (blank)
Baud Rate: Auto
Line type: Modem
Timeout: Off
DNS server: (unchecked)
Then press Save.
To get MMS working (what I haven't included are the blanks and all boxes should be unchecked unless specified)
Setup-->Data Network
Profile Name: Fido MMS
APN: mms.fido.ca
Username: fido
Password: fido
Timeout: 15 minutes
Primary Gateway IP: 205.151.11.13
Port: 8080
Baud Rate: Auto
Line type: Modem
Timeout: off
Then click SAVE.
THEN
Messages-->Service Setup-->Multimedia Message
Default profile: FidoMMS
(all other settings are to your preference)
Tap the box beside Default Profile and ensure that FidoMMS is the default profile.
Settings for MMS profile goes
Profile name: FidoMMS
MMSC: http://mms.fido.ca
Max Sending Size: (your preference)
Network Profile: Fido MMS
Internet Setting Rogers
Proxy Name: Rogers MMS
Proxy Address: 172.25.0.107
Access Point: Rogers MMS
Home: ((Set whatever page you like here))
Port Number: 8080
Authentication Type: HTTP-BASIC
User Name: media
Password: mda01
Access Point Name: Rogers MMS
APN: media.com
Authentication Type: PAP
User Name: media
Password: mda01
DNS: <>
Linger Time: 180
MMS Accounts (Main Menu -> Messaging -> Messaging Settings -> MMS Settings)
Profile Name: Rogers MMS
Proxy: Rogers MMS
Relay Server URL: http://mms.gprs.rogers.com
Master Reset
Dial the following 2945#*#6 or 2945#*45#
Feb 14, 2008 | LG Shine KE970 Cellular Phone
Motorola Mobility i776 Cell Phone Logo
840 people viewed this question
Top Motorola Mobility Cell Phones Experts
Rami Obeid
Level 1 Expert
D. E. Hev
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
