Question about Ruud Heating & Cooling
Ocasionally when the compresser shuts down the bloower keeps running and the compresser wil not start up untill we reset the thermostat
  • 25 Answers
The blower fan will usually run for a short while on after the compressor kicks off on most systems. this is due to the colloection of condensation in the evaporator coil. running the fan will evaporate the remaining water on the coil, therefore it will not flood the drain lines.
Posted on Oct 09, 2009
At night its shuts down when the therm is satisfied,but trys to restart right away and when it does start it shuts down right away and just keeps doing this
The thermostat has a differential built into the temperature sensing operation. The differential is normally a degree or more. If the stat shuts down at 72 degrees it should not start the unit again until the temperature in the room reaches 73. If the AC runs and cools properly until it shuts down, I would check the thermostat. The AC can not restart immediately after it shuts off because the pressures in the system are too high at the compressor. It takes a few minutes for the pressures equalize allowing the compressor to start. If the stat tells the unit to start under high pressure, the compressor will shut down on overload. It will start and run after the pressure falls enough for the compressor motor to run.
Jun 04, 2015 | Dometic Rooftop RV Air Conditioner
WHAT SHOULD THE heat anticipator BE SET AT ON A MODEL COAT066BDA COLEMAN EVCON FURNACE
The typical starting point for heat anticipation is .4 amp. If you do not have a clamp-on ammeter, adjust it to .45 and observe operation for a few days. If not quite right and still short cycling slip it to .5. Then keep doing this until you are satisfied cycle time is correct.
If you have an amprobe or can borrow one, remove the stat and take a single loooooong thermostat wire. Attach it to the R or Rh and wrap it around the clamp on ammeter ten times then attach the other end to the W terminal. The furnace will initiate the heat cycle at that point. Observe the amp reading on the amprobe when full heat is on, DIVIDE that reading by ten (for the wraps of wire) and adjust the heat anticipator to THAT setting.
Feb 05, 2015 | Coleman Heating & Cooling
Thermostat keeps shutting down a/c system
A couple questions. Have you ever tried switching from auto-on while the system was working properly? And when it shuts down, does the blower in the furnace/air handler shut down as well? And the no batteries just means the thermostat is drawing power from the transformer in the furnace.
Apr 17, 2013 | Heating & Cooling
My radiator hose is very hard and hisses when i shut the car off. I just replaced the hose, put a new clamp on it, It was running hot so I replaced the thermostat. The temperature is fine now but the
Yup , best thing to do is fill jug, run till warm, shut off and let cool and **** coolant from jug and start up and do again, overnight works best, just make sure jug has enough in it to draw back into system with out running out cause then you wil still have air in system
Feb 15, 2012 | 2000 Oldsmobile Alero
My reliance electric hot water heater keeps shutting down. when I push the reset button it goes on and works for anywhere from 1 day to 5 weeks. Where do I look for a solution.
According to Reliance's trouble shooting guide, you may have faulty upper thermostat that is overheating, which is causing the high temp limit switch to open and shut it down. Pushing the reset switch is only a temporary solution until you find out what is causing it to shut down. Is it still under warranty? Call Reliance and find out. 1-800-365-4054
May 17, 2010 | Reliance WATER HEATER CO #9-40-DKRT 40GAL...
Is there a thermostat shut off switch . car runs
The amount that it gets hot is a clue but theres no shut off switch. It's possible that the car is over heating and the temp gauge does'nt have enought water over it to report the problem. once the cooling system is cleared as it's full circulating and the fan will come on when it's hot ( disconnect the temp. switch on the therostate cover on the top of the transmission, ( the stat is in the lower hose ) with it disconnected and the key on the fan should be on and connected f till it's real hot. The crank senser or distrubutor module can can too hot and shut down too
May 13, 2010 | 1997 Toyota Corolla
Compressor short cycling
If the compressor is run off of a relay then you could install a delay timer to prevent short cycling.
http://www.climatedoctors.com/items/item.aspx?itemid=429504
Jun 04, 2008 | Dometic Heating & Cooling
Toyostove laser 55
sequence of operation is just like the monitor. combustion blower comes on to purge chamber of fumes. after the delay, the solenoid pump comes on and deposits fuel to the burner mat, within 20 sec the igniter comes on, incandesces and ignites the fuel if there is no flame, the flame rod is supposed to shut down heater and go into a lockout condition until shut off or unplugged to reset. check solenoid pump first. you already know the igniter works. check the fuel filter in the fuel sump might be clogged. check the fuel sump float valve, might be stuck, supposed to hang free in the sump with needle valve open. thermostat is digital just starts and shuts down the burner and solenoid pump.
Dec 13, 2007 | Rinnai Toyostove Direct Vent Heater:...
Frigerator runs constanly till compresser gets to hot
Sounds like it might be the thermostat
sensor bulb is defective see if you can
turn the refrigerator off with the thermostat
the defrost heater is supposed to heat up
enough to open the defrost thermostat
Make sure the defrost timer works to
turn on lhe heater & turn off the defrost tstat
turn the power off and check the tstat & defrost
heater for continuity check to see if tstat open
and closes when you turn the knob,
if you remove the tstat you can check the
bulb in ice water and warm water aborv 40
to see if tstat cycles on and off
Nov 26, 2007 | Maytag MSD2650H Side by Side Refrigerator
Heating & Cooling Logo
74 people viewed this question
Top Ruud Heating & Cooling Experts
Donni Steen
Bill Long
Tim Whalen
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
