Question about Water Heaters
Hot water works but heating is not coming on - Water Heaters
  • stuarttruslo Oct 06, 2009
    its a ferroli felcon
  • Water Heaters Master
  • 19,396 Answers
Hi.
First ensure that the thermostat is well connected and turning on the boiler.
Ensure that water has sufficient pressure.
Check the radiators , and ensure that the problem is not given by air inside the radiators.
There are several pipes connected to the boiler. Find the ones that send water to the radiators, and check if the valves in the pipes are open.
If there is nothing in there, then there are more faults that can cause heating to stop, like for example a faulty diverter valve, but at that point for safety reasons it is better to call a service technician, since the boiler must be partially taken apart and tested.
Please do not forget to leave feedback.
Regards.
Ginko.
Posted on Mar 05, 2010
My central heating turns off when i turn the hot water tap on. when i turn it off the central heating doesn't come back back on until i turn the power off and on.
Combi-boiler-turn hot water tap on/off and the heating stops for ...
singletrackworld.com/.../combi-boiler-turn-hot-water-tap-onoff-and-the-...
Combi-boiler-turn hot water tap on/off and the heating stops for 20secs ... hot watertakes priority over central heating so when you run the hot tap, heating is ... Yeah onmy worcester combi there is a diverter valve - it feeds either the heating or ...
My central heating works but I have no hot water - 24'7 ...
https://www.247homerescue.co.uk/my-central-heating-works-but-i-have-...
Diverter valves switch heat between the hot water and the central heating. When youturn your hot tap on, the diverter valve temporarily shuts off the water supply ...
Does your boiler keep switching itself off? Here's why ...
www.dhs-uk.com/does-your-boiler-keep-switching-itself-off-heres-why/
Jul 7, 2015 - ... Bathroom Suites, - Showers, - Wet Rooms, - Taps and Accessories, Information and ... Low water pressure can cause your boiler to turn itself off. ... boiler is not turning off, you aren't getting the amount of hot water you require. ... If there is air in your central heating system, then your boiler may shut down.
Feb 09, 2016 | Water Water Heaters
Need to separate heating and hot water - just have hot water on
You need a heating engineer to come in and do this.
Sep 09, 2017 | Water Water Heaters
I HAVE WORCESTER 24SI BOILER , THE HEATING IS WORKING BUT NO HOT WATER THANKS.
Hi Mustafa, you are going to need a Gas Engineer to fix this one. It could either be the Hot water sensor or the flow switch that activates the water to come on. Good Luck.
Jan 03, 2015 | Water Water Heaters
This on demand hot water heater works ok but it sends a gallon of cold water through it before the hot water starts. Is there a way to tweak it so it starts heating the water right away?
feel the pipes coming from the water while you turn the hot water on. It does come out hot, but it has to push the cold water through the lines first (the water that has been sitting in the pipe)
Dec 05, 2009 | Bosch Water Heaters AquaStar 250SXO...
Central heating and hot water have suddenly stopped working
not an engineer but maybe a heating compant,, it sounds like you have a relay that has gone bad, you have what we call a winter summer system your domestic water comes from a tank inside the boiler, you might want to think about splitting the system to save you some money in the long run, seperate the water heater from the boiler so you only heat up in the winter, right now you are heating the system that heats your house to get 30 or 40 gals of domestic hot water, it would cost you less by seperating them
May 17, 2009 | Water Heaters
Heating elements do not operate together
That's how they work. First you need to know that cold water goes into the tank near the bottom (because of the "dip tube" inside the tank) and hot water is taken out at the top. Also hot water naturally rises.
so... when the tank is full of cold water the top element will come on and heat up the top 1/3 of the water then the bottom element will come on and finish heating the rest of the tank
Mar 28, 2009 | Rheem 80 GAL ELEC TALL Water Heater 6YR SC...
Water Heaters Logo
77 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
