Question about IBM (02R4084) Motherboard
We are running Terminal Services we have a MF5700 series printer at one of the rural offices but the printer doesn't show on the Server when logged into TS any ideas?
Setting up Terminal Services on Server 2003 at the head office of a client in a workgroup environment, no Domain Controller. The branch office wants to log in through a VPN Router ( Linksys RV042 that has...
Assuming you can connect via Remote Desktop without any issues...
Printing through Terminal services requires that printing be enabled in the Terminal Services Configuration (Client Settings Tab). It also requires that the printer driver be installed on the Terminal server, not the actual printer (as it shows under the control panel) but just the driver. You can install just the driver by going to File/Server Properties under Printers and Faxes ON THE TERMINAL. Install the printer normally on the client machines.
Note: For a printer to work via Terminal services it needs to have a compatible driver (which I believe is called PCL??) So some consumer printers (the ones that only come with Setup programs, not just driver packages) will not work. The majority of HP Officejets and laserjets are fine, as are Brother lasers.
Oct 27, 2009 | Microsoft Windows Server 2008 Terminal...
We are trying to print remotely through terminal services and cannot make it work
Terminal Services should map to a local printer, you will need some adjustment to the Terminal Services manager to set the map to the server to which the printer is attached.
Oct 08, 2009 | Zebra TLP 2844-Z Thermal Label Printer
Is there a totally free driver download for a canon mf5700 series printer all the ones i find say they are free then you need to register and pay
Go to the canon website. Click on the support link. Lookup your specific model # and input the operating system you are running. The software/driver package will appear for free download. Download and install. You should be all set. Hope this helps.
Sep 06, 2009 | Canon imageCLASS MF5770 All-In-One Laser...
RPC Service not running
Please restart the service of RPC.
Write the script for RPC services by the help of google ur problem will be shortout .
Regards
MAYANK GUPTA
May 27, 2008 | Microsoft Windows Server Standard 2003 for...
CanoScan Lide 25 scanner
i hv windows server 2003 on which canoscan LiDE 25 doesn't work i don't hv windows server 2003 driver .pl. help me.
Jan 11, 2008 | Canon MX700 Office All-In-One InkJet...
Printing throw terminal server
Are you remoting into your server from a differnet location than where the server is? I need to know th physical location of the printer to the server. If the printer is connected to the server there is a problem with the driver. if the printer is connected to your local PC you will need to click on the options button in remote access and tell it you want to use local resorceses. If the server / Printer / PC are in the same location do not access the server thru terminal services, set it up as a client server.
Dec 25, 2007 | D-Link Express EtherNetwork DP-301P+ Print...
Sharp BC320 Networked Printer
Need to contact your IT dept. to give access to change info.
Only Administrators can change.
Oct 31, 2007 | Computers & Internet
Toshiba PA1390U-1NKP fails under Windows Terminal Services from XP to Svr 2003 R2
I don?t have the equipment to test your setup; however, I suspect your problem is in redirecting the device to the terminal server session. Check the terminal server system event log file to see if you are generating any messages when you connect. When my users have issues, typically with printers, they will be listed in the log as *Errors* and the source will be *TermServDevices*. If you?re using the latest Remote Desktop Client there is a tab in options called Local Resources which is used to deal with configuring your workstation sounds, keyboard, printer, and other local resources to redirect to the terminal server. Click on the More button at the bottom and you will be taken to the more generic section of resource redirection that deals with other items. Your device is probably USB so if it is going to work is would fall under the scope of the section labeled *Supported Plug and Play devices*. You would start by placing a check in that box, reconnect and see if you keypad works now or if anything shows up in the event log. Let us know how this turns out and if you have any other questions. As always please don?t forget to rate this post.
Apr 03, 2007 | Toshiba PA1390U1NKP Keypad
Computers & Internet Logo
26 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
