If you can’t get the manufacturer to fix it or send you the parts you may want to try and fix it yourself. I found a guy in South Carolina who sells good used parts and will give you some suggestions on how to do it yourself. I bought a LCD from him for $39.00, fixed it myself and it works great. I think his email is [email protected]
More than likely it is a bad battery. They seem to fail frequently. Papasgirl
Here is the solution
when the battery totaly drain you encounter blinking error. it mean its not charging. You need to charge the battery using fash charger... or use universsal charger for cellphone. for 5
mins. then charge to your regular casio charger it will work
joelskie
I had the same problem, the charger kept blinking red when I attempted to charge the battery.
This morning I called casio and they are sending me a out a new battery free of charge, and i don't have to send the old one back. It only took about 10 minutes and they said I should get it in about a week or so. So hopefully this helps everyone who has the same issue as I did.
Same problem here.
My EX-Z75 wont turn on, the battery charger has a red light on & is blinking all the time, I dont think its charging the battery. According to the manual it should be on untill charged but doesnt say anything about why it should be blinking. Its brand new & was a present for someone, not happy!!!
I have the same problem, the battery just won't charge.
Hi. I've just purchased a casio EX-Z75 digital camera from an ebay shop.
Trouble is I haven't ben able to use it yet as when I try to charge the battery, the red light flashes indicating that it is not charging.
Any ideas as to what I can do about this.
Many thanks
Ray
I have the exact same problem and it was a gift. She took 4 pictures and now it doesn't work. Put the battery in the charger and the red light just blinks....
Have not used my casio camera for a while, but the batteries seem to have gone dead and will not charge. Sometime,when the battery is charging it flashes red. What can I do. I have two batteries and they are both the same.
My Exilim EX -Z75 will not turn on. I think there is a problem charging the battery. The red light flashes when I try to charge. Please advise.
