Question about Energizer 30-Minute AA and AAA Battery Charger
Lights do not go out when batteries are charged, left it on overnight, it is hot but green lights are still on.
I have Xperia X 10 mini from Sony Ericsson. I left it charging overnight as I do every night since I've got it. And today when I woke up, I took the phone and instead of it being fully charged and
Chances are your phone got too hot during the night and overcharged the Lithium Ion battery. If those batteries are exposed to too much heat then they won't have the battery life they used to have. You need to purchase a replacement battery or contact your wireless carrier to see about getting another one.
Jan 24, 2012 | Sony Ericsson XPERIA X10 Cell Phone
I have replaced joystick, batteries, motors and the chair still losing lights will go about 1/4 mile and loses all green lights with in 1/2 mile loses all the yellow lights, drove on 1 flashing light for...
Janice check your charger it could not be charging the batteries. Now always charge your batteries overnight while you sleep When you get up lights on the charger should be red and green if they are red and yellow then the charger hasn't fully charged the batteries and overnight should be more than enough time to charge fully. This could indicate a bad battery remember new doesn't always mean good. Like they say always charge before use and this goes for new batteries too you need to charge new batteries nightly for 10-15 days before they start operating at 100%. If when you plug in the charger before bed and the lights are red and green then there is a problem with the charger or the batteries or the charger circuit Hope this helps you
May 23, 2011 | Spirit Activecare /wildcat Foldable Power...
I recently puchased an EGET MO-H04CD portable oxygen concentrator and I am having problems charging the Lithium batteries that were supplied with the unit. There are no instructions on how long you have to...
Red light normally means that the battery needs charging. The green flashing light can mean the battery is charging or has charged, and the same with the solid green light. Green in this case is good.
Charge the unit overnight and see what the indicator state is. It should not take more than 8 hours of charging for a Li-ion battery. Once you know what the full state light looks at, then you can tell what the charging indicator looks like.
In all cases, ensure you are using the proper charger with the unit.
May 14, 2011 | Health & Beauty
The power chair does not show a charging green light,although the red light is on.... Batteries???
The green light won't come on until the batteries are fully charged now if after an overnight charge you still don't have a green light then I would replace the batteries. Hope this helps you
Feb 24, 2011 | Pride Jazzy 1103 Ultra Standard Power...
2010 Ford fusion I left the parking lights on overnight and find battery dead the next morning. I charged battery overnight, but still could not start engine. When key is turned it displays the battery...
Well contact your dealer and tell them that your battery is gone bad for no reason and don't mention you let the light overnight because your battery is under warranty and they will put in a new one. Good luck
Jan 09, 2011 | 2009 Ford Fusion
Acer 5315 Battery cHarging Problems
All rechargeable batteries have a limited life, and as they age their charge capacity reduces over time and you get shorter and shorter time between charges.
Recharage batteries have a finite number of charge and discharge cycles and batteries over 2 years old are considered nearly worn out. Worn out batteries won't charge up at all.
Jun 30, 2009 | Acer Aspire 5315 Notebook
Yellow / green light will not go off when charging
Its likely the batteries will take at least several hours to fully charge, if not more. NiCad batteries are slow charging and usually need 4-6 hours for a full charge. Keep them on longer or even overnight but make sure you remove them in the morning. You will probably find the light turns green after 4-6 hours of charging. If lights stay yellow and green after 12 hours of charging, it may indicate a fault in the battery itself where it will not accept a charge.
Jun 18, 2009 | Ryobi Multi-Volt Battery Charger
New charger
it may not be the charger on most occations have the battery checked out at your nearest cellphone tech. to find out if you need a replacment battery
Jun 15, 2009 | Duracell AAA NiMH Battery Charger with 4...
Peg perego 12v charger question
The green light means it is ready to use. If the battery is bad though, the light will still be green.
Mar 07, 2009 | Peg Perego 12 Volt Rechargeable Battery
My motorola H700 keeps staying red when charging
Wait, how long have you waited for it to charge? It's supposed to stay red until over 80% charge, then switch to yellow. When it is fully charged, it goes to green. When you mean it stays red when plugged in, have you waited the 2 hours?
Jul 10, 2007 | Motorola Mobility H700 Wireless Headset
Energizer 30-Minute AA and AAA Battery Charger Logo
26 people viewed this question
Top Energizer Cameras Experts
Jaye t rock
Arthur Cowgill
Level 1 Expert
Are you an Energizer Camera Expert? Answer questions, earn points and help others
