Question about Gestetner DSm620d All-In-One Laser Printer
DSm620d - automatically select a new tray when out of paper.
Is there a way I can get the DSm620d to go to the next print tray automatically when one runs out of paper? Thanks so much.
  • 32 Answers
Yes in the user tools under system settings, paper settings turn aps on. auto paper select. Also see paper settings under print settings
Posted on May 08, 2010
Ricoh Aficio AP410N printer won't print on tray 1. Paper feeds through but no print on it. Tray 2 is fine???
Here are a couple of notes I found on the printer:
  • Before printing on paper other than envelopes, make sure that the levers inside the rear cover are pulled up. Leaving the levers lowered can cause print quality problems when printing on paper other than envelopes.
  • If you set [Paper source tray:] to [Auto Tray Select] on the [Setup] tab in the printer properties dialog box, the machine selects the tray automatically. (I imagine you'd have to enter printer Properties or Settings and choose a tray there.)
Nov 29, 2017 | Ricoh Office Equipment & Supplies
Any time i try to print with my sharp ar-m205, it automatically reselect bypass tray and give error Check bypass tray: out of paper or misfeed. But the original tray i selected is tray 1 and there is paper...
Make absolutely certain the correct size is specified for the paper in your tray, otherwise your print driver may be locked on selecting from the bypass tray and not set to 'auto select'
Nov 01, 2013 | Sharp AR-M205 Copier
Hp laserjet p2055dn tray1 manual feed problem
Go to menu, in tray tray behaving tray1 select as unless paper load,in tray2 page size as any size.. while giving print command select printer properties, goto paper/quality select paper source automatic or tray2 & shoot print command & check...
# if you are not selected tray 1 as unless paper load, it will ask paper to load after command reached to it.
# if you are not selected tray2 as any paper size, defined paper size only it will allow to print..any paper size it will print with out questing you..
Aug 01, 2012 | HP LaserJet P3005n Printer
How to fix this error in printer hp p2055dn ''manual feed press ok for available media into tray 1
Aug 01, 2012 | HP LaserJet P2055d Printer
Manual feed tray bypass
Jul 25, 2012 | HP LaserJet 4250n Printer
Hello sir, how to take print on A4 page? please help me
Hi The A4 paper size is an internationally used paper format. Although not often used in America, it is by far the most commonly and widely circulated paper size. At 8 1/4 inches by 11 3/4 inches, it is similar though not quite identical to the American standard U.S. letter size, which is 8 1/2 inches by 11 inches. Because of its ubiquity, all printers and programs have the ability to handle the size, and getting a printer to print to it is a matter of adjusting the settings.Put the A4 sized paper into the automatic feeder in the printer. You may have to adjust the tray guides to fit the paper in snugly. Close the tray firmly when finished.
  • Step 2.Set the printer to register the A4 sized paper inside the the tray. This varies from printer to printer but generally involves going into the print menu, scrolling to the automatic feeder and designating the tray as an A4 tray.Step 3.Select "File" and then "Page setup" in the program you are using.Step 4.lick on the drop down menumag-glass_10x10.gif next to paper size and choose "A4.Step 5.Select "File" and then "Print." Click the "Print Summary" button to ensure the file is set to print to the A4 size.
  • Step 6.Press "Print" to print the photograph.
  • Jul 31, 2010 | Toshiba e-Studio163 Copier
    I am making a baby shower announcement. The paper is not a standard size. It is recommended that I manually feed it. I don't know how.
    first go to control panel and select printers and faxes.... in there right clik ur printer and choose printer preferences..... choose the printing shortcuts.... in the left side u ll have a list of available types of print... select ur required type... on the right u have paper source .... select automatic.... and then next to the printing shortcuts tab... go to features tab... there in the resizing options ..... choose custom and put in the size of the paper u want to print in.....
    Make sure that the paper exit tray is extended out. This will give your print job a place to rest when finished.
    Feed the paper manually through the paper support. This should be done at the speed the printer allows. Do not try to rush the paper through.
    Watch the paper come out through the paper exit tray. Make sure it is not crooked or creased.
    thank you
    have a nice day
    Apr 12, 2009 | HP PhotoSmart 7260 InkJet Printer
    Somebody has messed with the settings and now whenever we print we have to press "Select" for each page
    The tray 1 is same as manual tray, it opens in front of you.
    normally (in windows) you need to configure printer driver from printers => properties => printing preferences.
    Oct 14, 2008 | Lexmark T632 Laser Printer
    Ricoh Aficio 450 paper format printing problem
    This could be a few things, first thing i would try is to go in page setup under the program you are using and make sure paper is set to auto select (File>page setup). The program will override the print driver.
    next make sure the driver setting (paper source) are also set to auto. make these changes by right clicking on the driver>printing preferences.
    third I would go to the copier, Make sure the tray are set to the proper paper size and the display paper size matches the tray
    Dec 26, 2007 | Ricoh Aficio 450 Copier
    Gestetner DSm620d All-In-One Laser Printer Logo
    191 people viewed this question
    Top Gestetner Office Equipment & Supplies Experts
    Adorjani Laszlo
    OfficeServiceAjnc
    OfficeServiceAjnc
    CheckitRight
    CheckitRight
    Are you a Gestetner Office Equipment and Supply Expert? Answer questions, earn points and help others
