Question about Plumbing
Need to adjust pressure and flow compensating valves on this 5230 tractor, could use some info, thanks, Steve
  • 3,600 Answers
Well do you have a double stack vavle? does it have a flat head scwerdrire and a nutto adjust itto increste the pressure? you did not give enought information for me to help you.
Posted on Oct 06, 2009
My husband scan our 2006 Cadillac SRX and the code reads fuel pressure regulator. Can you tell me if where this parts located. I appreciate your answer. Thanks
What DTC ? P0000 what , What engine 3.6 or 4.6 L Need more info if you would like help .
The fuel pressure regulator attaches to the fuel return pipe on the fuel sender assembly. The fuel pressure regulator is a diaphragm-operated relief valve. A software bias compensates the injector on-time because the fuel pressure regulator is not referenced to manifold vacuum. The injector pulse width varies with the signal from the mass air flow (MAF)/intake air temperature (IAT) sensor.
With the engine running at idle, the system fuel pressure at the pressure test connection should be between 380-410 kPa (55-60 psi). With the system pressurized and the pump OFF the pressure should stabilize and hold. If the pressure regulator supplies a fuel pressure which is too low or too high, a driveability condition will result.
Feb 17, 2017 | Cadillac Cars & Trucks
Why a bobcat 331-c travel is slow on right side forward or backwards
Check pressure at spool valve input.If the pressure is ok then look at the flow control valves (sometimes refered to as compensating valves)
May 16, 2014 | Toys
How do you adjust the fuel flow on the carburettor ?
there shouldn't be necessary to adjust fuel flow. Gravity feed and needle valve shuts it down when needed.
Dec 23, 2013 | Garden
HOW TO CHANGE OVER FROM NATURAL GAS TO LP
There are some variations from one manufacturer to the other but basically they are all similar. If you have a gas valve that is convertiblble then normally there will be a screw plug cover on the gas valve where you can change the pressure for L.P. by removing the plug and spring and inserting a new spring to compensate for different gas pressures.You will need instructions for your unit as some require a specific number of turns on the plug to put proper tension on spring so gas pressure is right. On some units the burner orifices are adjustable on others you will need to change orifices on burners and pilot light.
If your gas valve is not convertable then you will need to get one that is. Hope this helps you. Thanks.
Feb 03, 2011 | Heating & Cooling
I have a Craftsman 42" rider cuts uneven
Check your tire pressure first, uneven tore pressure will cause this problem.On the rear of cutting deck on both sides there are height adjustments, if your deck has a rear roller this also can be adjusted to compensate,If your a stout person sitting on tractor can cause unevenes.
Jun 25, 2017 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Have a turfmaster 16.5 hp 42"....left the deck engaged when I turned it off now it won't start after it is disengaged. It trys to turn over, but won't.
The deck engage is not the problem here. If it were related, the engine would not even try. The valves need adjustment to compensate for wear on the "internal compression release" located on the camshaft. This is normal wear.
To "get by" for now, you can turn the flywheel by hand (in a clockwise direction) until it is just beyond the compression stroke and the starter should start it just fine, provided the rest of the machine is healthy.
PLEASE NOTE: this procedure for starting is masking the REAL issue and the valves will need routine adjustment as soon as feasible.
If you are handy with tools, know the internal workings remotely, and wish to explore, reply with a request and I will explain the valve adjustment procedure in detail for you.
Hope this helps,
Dolf-
Oct 13, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Reddy heater has spark but no fuel to ignite it?
the black hose that goes to the back hooks to a pump on back of motor take screws off back and filter clean when back together turn fan by hand and should hear a small vacum at back of motor , not pluged in clean nozzel
Apr 13, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
96 Mercury Villager stalls upon deceleration.
suspect distributer needs replacing. common to find brown dust from bearing going.
go here
http://autos.groups.yahoo.com/group/villagerquest/
Mar 27, 2009 | 1996 Mercury Villager
Increasing water flow rate
With a flat head screw head driver adjust the pump pressure. The screw is on the left side of the image below.
Sep 13, 2008 | Coffee Makers & Espresso Machines
Plumbing Logo
27 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
