WIDL146 - washing cycles stop dead after pumping water into drum
I own a WIDL146 washer/dryer, it is 4 years old. Washing cycles seem to get stuck after initially pumping water into the drum. pumping out water and spinning works perfectly but is of course of little use if I cannot get a complete cycle to work. any idea what it could be and how expensive it would be to fix?
  • Washing Mach... Master
  • 909 Answers
You could very possible have a faulty heating element. If water does not heat, the cycle will not continue unless you forward it by hand. Buy a reasonable voltage/ resistance tester and do resistance test across element. You should get approximately 25- 30 ohms. If resistance is present, look for reset switch in the vicinity. If not, connect tester to heater wires and set reading to 250- 300volt reading. Start the cycle one click at a time and note if the element voltage ever reads on the meter. If not, your timer must be replaced.
Posted on Oct 06, 2009
Washing machine don't makes the spin dryer at the end of washing cycle
This video will show you how to change the pump washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Feb 21, 2013 | Bosch Washing Machines
The motor on my Miele washing machine is running constantly even when not set on a programme. The water seems to empty out as soon as it comes in. I Have to release the Stop /Start button to stop motor.
what motor do you mean the motor that spins the drum or the pump motor if its the pump motor i would check the programmer as it tells the pump when to run, on a rinse water evacuate cycle it would seem that you are stuck in that mode call a loacl engineer
Jan 16, 2010 | Miele Novotronic Premier 500 Front Load...
Hoover hpe 236. water not draining, stops mid cycle, lights flash
Have you checked the pump filter, and or that the pump is actually working. if it spins o/k with no water in, then I would suspect a draining problem.
If filter clean and pump o/k, then it could be a control module fault. if this were the case, then it would probably be wiser to purchase a new washer.
Hope this is of some help to you.
Jan 16, 2010 | Hoover Washing Machines
Stoping under process on every step from begning to ending
its very common for front load washers to have the water pump to freeze up.
ever washed something with sand or little rocks or rubber bands?
flip the washer to the side, then locate the water pump. take the filter and the hoses around the water pump. sometimes the water pump too, to make sure that the fins on the water pump are free and not stuck. put everything together and try the cycle. when the water pump is stuck it will cause the error and will not go into the spin cycle.
Aug 14, 2009 | Zanussi ZJD1219 Front Load Washer / Dryer
Lower washing machine function inoperative in Maytag stackable
rclasky check this one
http://www.fixya.com/support/t827165-maytag_model_lsg7806aae
Mar 13, 2009 | Washing Machines
Fault code on washer/dryer
Hi.
F05 means pressure jammed on full or pump not draining.If pump o/k, then you will neeed to call an engineer.
Nov 23, 2008 | Hotpoint Aquarius WD640 Front Load...
Hotpoint WD61 stops near start of wash cycle
all in the timer. but there may be nothing wrong. sometimes in the cycle there will be a gap between water full and agitate or between drain and spin depending on settings. try it again and let it go and if there is a gap of more than 5 minutes than it needs a timer. most machines timers are right around $75 and you can most likely replace it yourself. sears appliance parts is the place to buy it. you can order it and they will deliver it to your door. or if you can get the phone # most of the outlets have a parts dept. also they take parts back for full credit for any reason.
Mar 05, 2008 | Hotpoint WD62 Front Load Washer / Dryer
Front Load washing machine
common for the impellor to come off the drain pump also common to have water in the pump rotor housing making the pump fail to start
Oct 13, 2006 | Indesit WA 115 Front Load Washer
Washing Machines Logo
148 people viewed this question
Top Washing Machines Experts
