Question about Xerox WorkCentre PE16 All-In-One Laser Printer
When power is turned on, a small red light comes on (bottom right of the display) for 2 seconds & then turns off. Then nothing else happens. Please help.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 78 Answers
COULD BE A PAPER JAM/OR A DAMAGE.BENT SENSOR
Posted on Nov 30, 2009
  • 217 Answers
Your printer maybe can't recognise print cartridge, for sure use old one to check this. if i'm right - replace toner cartridge!
Posted on Oct 06, 2009
LG 47LN5750 TV has no back light issue-
replace screen it's faulty period ensure it comes with T-con
Oct 03, 2015 | LG 47LN5750 47" LED TV 1920x1080, 120 Hz,...
Sony Grand WEGA KF50WE610 tv will not turn off
Problems that do not happen all the time are hard to find--2 things: if set blinks the red light try to count the blinks--usually that is an error code.
Also this set if it does for the most part work should have an error buffer.
With the set turned off and using the Sony remote:
Display
5
Volume down
power
If it has this when it comes on there will be a box in the middle of the screen with several items listed---all must have a zero to the right of them---if one has a number(any number) it means it has detected that error that number of times.
Let me know what you find
Apr 11, 2012 | Sony Grand WEGA KF50WE610 50" Rear...
I have a wall switch, top button for lights,second fan and third reverse bottom power. Yesterday had a power out outage for less than a minute. The power button popped out and now the lights will not go...
Replace the switch. When Power Company electricity goes out and comes on by itself, it often "Surges" frying small electronic components. This is what happened. No biggie...happens all the time. Be sure to turn off power to the switch in your breaker box first.
Mar 26, 2010 | Casablanca Fan 3245T Ceiling
SONY KDF-E55A20 5 red blinking lights on power button
Symptom shows Lamp is weak in result and causing restart of TV again and again. Your TV requires new lamp as per following part number...
A1085447A* LAMP BLOCK ASSY XL-2200U
It is available in Sony Accessories Store for $200 and replacement procedure is written in instruction manual of TV.
Always buy Sony original lamp for TV and avoid aftermarket / cheap lamp for TV safety.
May 18, 2009 | Sony KV-36FV26 TV
Kenwood kac-x1r flashes code e-03
HI DUDE EVERY REMOTE WIRE THEY HAVE FUSE NEAR THE BACK OF PLAYER TRY TO CHANGE IT .... R...TRY UNPLUG UR AMP .. AND ..FIX IT BACK
Apr 16, 2009 | Kenwood KAC-X1R Car Audio Amplifier
AKAI 32" LCD HDTV WILL NOT TURN ON
The only solution at this point would be to get the power supply repair since new boards are not longer being manufactured. In about 95% of the time if the LCD doesn't power up or turns OFF by itself or need to be unplug for some time to make work again; those are the symptoms of a dying or defective power supply.
I service these power supplies, for more info write to jah2mil@hotmail.com
Nov 27, 2008 | Akai PDP4294 42 in. EDTV-Ready Plasma...
2 red lights w/green light
The problem is the black screws on the bottom of the frame that screw into the X-Clamps. Most of the time, you usually don't have to even put the black screws back in. However their can be exscruciating headache inducing problems with fine tuning the black screws. If you do end up needing to put the black screws back in, I suggest to start with one @ a time, starting with the bottom right screw. ( thats with the 360 standing vertical with the dvd drive faced toward U.) The tightness can range from almost as tight as you can possibly get to soooo!!!!!! loose u can't possibly imagine how its doing anything at all. The best way to do this is, with the 360 hooked up, (and the case left off) take the small white plastic frame off that covers the power button, start with the screw loosened and then proceed to turn slightly like an 1/8th of a turn, then power on and then turn off if 2 red or 3 red ring proceeds and then repeat. You shouldn't have to put all the black screws back in, mine only has bottom right bottom left and top left, and are incredibly loose. My friend however has bottom right only and is tightened only about 1/2 way.
Sep 21, 2008 | Microsoft Xbox 360 Console
Xerox WorkCentre PE16 All-In-One Laser Printer Logo
79 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
