Question about Bosch Axxis WFL 2060 Front Load Washer
Front load door will not open
The washer seems to drain but the door will not open
  • timdm Dec 24, 2007
    my maid did not know that the door only opens after completed cycle and attempted to open the handle and broke the plastic on the handle. After removing the door assembly and applying epoxy to the broken lever, I am having a very difficulty time putting the damn thing back together. any ideas on how you reassemble this door?
Get the book how to fix your washmachine at the library and ask by phone for them to get you every book. If ou have a Ma Pa or family run appliance store that sells parts, ask the sales clerk for instructions. I had a drier problem and did this and fixed it myself. It is just getting the right book or the right person who will actually give you the info you need as there is nothing a woman can't do, but how to get detailed instructions that don't skip the key points is difficult......and the answer Buy A New Or get a boyfriend or husband to do it or drop your useless boygriend and they are available.
Posted on Jan 09, 2008
  • 105 Answers
Replace door catch ass
or if you think you have it as good as new spray the lock with a little crc to lube
Posted on Jan 02, 2008
My Kenmore front loading washer will not open
what is your model number is then we can get started then
Jan 17, 2013 | Kenmore HE2 Plus Front Load Washer
Electrolux washer door won't open
Hi.
Usually the door does not open because there is water inside the tub.
Disconnect power and empty the machine through the drain filter. With Electrolux front-loading washers the drain filter access is located in the front lower side of the machine.
Jun 11, 2012 | Electrolux Washing Machines
The washing machine Electrolux AURUM16 Problem
Make sure the water is drained or the door wont open
Sep 08, 2017 | Electrolux AWF1220 Front Load Washer
Door will not close
Make sure you are allowing the washer to completely finish its cycle before opening the door. It is normal for the door to lock at the end of a cycle. The locking mechanism keeps owners from opening the door before all of the water has been drained. If the door on the washer is locked, select the "Drain" or "Spin" options on the front-load washer. This will completely drain the water from the system and unlock the door, allowing you to open it.
Thank you !!
Jul 09, 2010 | Frigidaire ATF6000ES Front Load Washer
Can't get the door open
Thank you !!
Jul 06, 2010 | Frigidaire ATF6000ES Front Load Washer
Door lock light is on door is not locked and
Thank you !!
Jun 19, 2010 | Frigidaire GLTF1040A Front Load Washer
Door won't open
If you can drop down drain hose to floor level then drain into bucket this will allow you to open the door . Sounds like coin in the pump /remove the filter and clean check pump blades are free...Good luck
Apr 28, 2010 | Whirlpool GHW9100L Front Load Washer
Frigidaire affinity door will not lock when door is closed or register door is not closed when open
Apr 21, 2010 | Frigidaire ATF6700F Front Load Washer
I have a front load Duet washer. The washer won't drain. The door is locked. I got the 3 screws out for the lower access panel, but it seems that the door needs to be opened to remove the panel. Is that...
no not at all after removing those bottom screrws the panle will pull right off, pull from bottom. behind htere yo will see the pump drain cleanout, you can unscrew to clean out , but i warn you that all the water in the machine will exit drom that point, you will get wet, be prepared!
Dec 02, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Bosch Axxis WFL 2060 Front Load Washer Logo
70 people viewed this question
Top Bosch Washing Machines Experts
Marvin
Marvin
Craig Butler
Craig Butler
Carmen Mikulic
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
