Question about Medion Computers & Internet
Motherboard model for PC medion md7168pn (how to connect a front pane cables to the motherboard)
    President:
  • 2,351 Answers
You need to provide more information about your Medion.
Click on the Medion link;
http://www.medionusa.com/
Click on the link, Download Library
Fill in the search windows. Serial number & or model number should be on your case. Download the manual.
Mike
Posted on Oct 10, 2009
Medion pc mt5
Medion MT5: Is there a diagram for the PSU wiring setup for this computer? I cannot find a connector for the Green color 4 pin (female) connector. Also I would like a diagram of this unit's mobo with PSU connections.
Oct 13, 2013 | Computers & Internet
Akoya medion split screen
check the screen cable first. as it does not always happen. tilt the screen front and back to see it at some angles the split stop then you can confidently say it's the cable
Jan 03, 2013 | Medion Computers & Internet
Cannot enable wlan
Download the specific driver for your make and model of pc, install and you should be ready to go. Type it in the google search pane and several sites should have it ready for installation. This only works if you have an internet access, if not plug your PC direct to an internet via cat 5 cable.
Hope this helps
May 09, 2012 | Medion Computers & Internet
Ront pane audio
Sorry but that is not possible internally. From the rear panel, plug in an extension chord and use the extn in front. Use a shielded cable to eliminate disturbances......................sodeep
Nov 10, 2009 | Computers & Internet
Need sound drivers for medion pc model: pc mt6 med mt 166
i need sound drivers for my medion med mt166 computer. how do get it?
Oct 31, 2009 | Medion (MT8381) (40004683) Motherboard
I have a medion 3.4 turns on but dont boot up and leaves the screen blank prob started when ciosed down would not open up
If it is beeping more than once when you start it up, you will need to either find the error codes for your motherboard/bios or post your motherboard type and model and bios type and revision here. Simple possible solutions: Make sure you do not have a floppy in your floppy disk drive Make sure there is no CD in your CD drive Make sure your HD is connected properly, and set to Master or CS (if your MoBo supports cable select) and has an Operating system installed on it. Make sure your RAM is present and seated properly (in the sockets all the way and aligned) If none of these solves your problem please get back to us with your mobo model and bios type / revision and error code. It IS possible that 1 or more of your hardware components is dead or malfunctioning.
Jun 15, 2009 | Medion MD-1768 PC Desktop
Medion PC model MD 1777 wabout 4 yrs old will not start/boot up. Blue light just flickers continusly and makes a tapping sound.
Remove any disk inserted n your computer (floppy or cd) and try again.
Check the cables connection and monitor connection.
If no boot, try boot your PC using the CD restore provided with your machine
Oct 12, 2008 | Medion MD-1704 PC Desktop
VIA Technologies, Inc. PC Model KM400-8235
Probably the cables your are referring to are the front bezel USB and Audio Panel connector .If you do not use front USB port on your cab leave it NC .
Apr 28, 2008 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Medion motherboard?
Please make it clear that how are you trying to connect to web ? Is it through dialup modem or mobile or broadband or some other medium also make clear what error is it showing . Thanks
Oct 09, 2007 | Computers & Internet
Medion Motherboard
if you cannot reach the BIOS settings screen at power-up, then try another known-good keyboard...it is likely dead.
Jul 05, 2007 | Medion (MT8381) (40004683) Motherboard
Computers & Internet Logo
289 people viewed this question
Top Medion Computers & Internet Experts
John Anderson
John Anderson
Are you a Medion Computer and Internet Expert? Answer questions, earn points and help others
