Question about Kenmore 43142 Front Load Washer
Water seeping back in washer after load is done?
  • 909 Answers
Very possible your household drain pipe is almost the same size as the washers drain pipe. The house hold pipe should be approximately twice the diameter so as to allow equalising air in while water is being expelled from the washer. If at any time there is water flowback, it wont be forced into the washer pipe as it will now have an air gap.
Posted on Oct 06, 2009
Why is the washer slowly leaking water into the back of tub between washes?
There is grit in the water valve holding it open just enough to allow the water to seep by. You should get a filter system for your washer and replace the water valve, Grit is not covered by most warranties.
Mar 13, 2016 | Maytag Bravos XL 4.6 cu. ft....
Water slowly runs in washer when it isn't on
Sounds like a valve isn't closing properly. I would suggest you call for service.
Oct 24, 2017 | Whirlpool Duet GHW9150P Front Load Washer
My front loader LG washer works fine during the load, but when I come a while after the load is done, water has seeped back into the washer and I have run the drain cycle to get it out. LG says it needs...
If you have the capability its probably a leaking seal on the water input line at thetop of the water. Often its a simple hoseclamp that needs tightening. Without looking myself thats the easiest solution. Hope this helps!
May 09, 2011 | LG WM-2277HW Front Load Washer
Water seeping from hose connections in back. hoses are brand new.
make sure that the hose washers have been inserted properly and that the hose connection is not cross threaded it is easy to do
good luck i hope this is some help to you
Feb 03, 2010 | Maytag MAT13MN Top Load Washer
Water that seeps into washer after cycle is done
Hi, If you are getting water in the tub when the washer is off, you will need a new inlet mixer valve. You can test this by tirning the water off at the wall and see if any water seeps in. If you would get me a model #, Icould look this up for you.
Please let me know if I can assist you further.
Vic
Jun 01, 2009 | Kenmore Elite 45986 Front Load Washer
Water seeping in after load done (Hot water only)
yes the hot side of the water inlet vavle is defective...if you need any help replacing i will be glad to talk you through,,onthejob
Jan 03, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Kenmore 22422 seeping water from under machine
look underneath the washer.there sould be a hose there.sometimes an unbalanced load can cause the hose to rub up against sharp metal when the machine vibrates.mine had a zip tie that held the hose to close to the edge of the machine which had some sharp metal and it put a small hole in the hose.hope this helps.
Dec 19, 2008 | Kenmore 22422 Top Load Washer
Help!!!!!!!!!
Your inlet valve at behind top of machine is defective; or the pressure from your faucet is insufficient.
Close your faucet valve on wall & unscrew your hoses to check screens on hoses & machine. Clean out well. See that the water pressure is good. Refit, check for leaks. If this is not the problem change your inlet valve, it is easily done.
Sites for spares:
RepairClinic.com (which is good)
espares.co.uk
AppliancePartsPros.com
Pl rate if helped.............
Jun 12, 2008 | Frigidaire Affinity ATF7000E Front Load...
Kenmore 43142 Front Load Washer Logo
Sal De
fordexpert
Whirlpool
Whirlpool
