Question about Zanussi ZWD1470W Front Load Washer / Dryer
The washing machine filter pipe has come undone and we can't see where to fix it back under the machine.
  • 3,600 Answers
Are you talking about the water drain or are you speaking of the fill pipe.
Posted on Oct 06, 2009
Why is my Miele Novotronic w1512 saying Drain fault?
I have the same problem, i have cleaned the filter area and there was a plastic sweet wrapper in there also. However, I have put the machine back on an express cycle ans still have the error message coming up?? Drain Fault! I then tried to spin and the spin cycle wasn't working eithet. Whilst the machine was still on i patially undone the filter cap and removed a full tray of water, it then began to spin. What could yhe problem be?
May 21, 2012 | Miele Washing Machines
Water does not drain does not rinse
while water is in machine it cant go forward to rince. Check for a blockage, by getting the waste pipe at the rear of machineand placing it as low to the ground as possible in a bowl. If water flows from pipe then this will indicate a pump failure.if no water flows from pipe then you will need to remove back from machine and then under the tub will be a black pipe going to the pump. Starting with this remove the pipe and cheak for blockage. you will then need to temove the grey waste pipe and check this.If you have a filter check the filter first. but not all machines do have a filter at the front. Also if you have removed pipes then just feel inside the pump for any objects stopping it running.All of this can be dine without machine bieng on so just unplug machine before you start. Good luck
Mar 13, 2010 | Washing Machines
The machine is flashing f-08 and will not switch off what may be wrong
F-08 means the output pipes are blocked.
Often this can be fixed just by undoing the jubilee clip on the pipe and taking the ball out of the filter in the pipe and removing whatever is stuck under it but expect lots of water to flood out when you remove the pipe.
Unplug from the wall then undo the screws holding the bottom plate at the back (probably just the 2 phillips heads)
The thick back pipe with the clup on is the one you want.
Mar 08, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Clothes washer does not drain completley
Clear the filter and the pipes between it and the pump, tip the machine back and look under you will see a black pipe from the filter to the pump. Simply remove the pipe and clear it and the pump while your there.
Aug 23, 2009 | Maytag MAH6700AWW Neptune Front-Load...
I can't undo the filter cap
i had same problem so removed the inlet pipe on the pump at the back of the filter and removed debri from back of filter [screws coins and a darning needle] because of this the design of the lid would not allow it to open.........
Mar 18, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Washing machine problem
probably filter blocked. if memory serves me right, filter is located in pipe from sump to pump. remove bottom back panel. remove sump hose where ir is clamped to tub and filter is inside this pipe, take out and clean
Jun 18, 2008 | Indesit W 123 Front Load Washer
Cleaning the filter / wash cycle not running properly
you need to put the machine on its front and look under it and you will see a black rubber it gos to the pump and to the drum well the drum one has to come undone with a flat head screw driver and if that's clean then put it back properly when you have done that and you have cleaned the pump out if the machine still done work then your pump has gone you will get one from ebay don't for get to wright down your model number ok good luck
Jan 08, 2008 | Bosch Exxcel WVT 2850 Front Load Washer /...
Washing machine
you almost certainly have a blocked filter .Unplug the machine , take the screws out from the back you will see a black hose coming from the tub to the pump, this is the filter if the machine is still full of water get yourself a washing up bowl and lower the grey waste pipe into the bowl and gravity should let the water out, raise the pipe when bowl is full.If no water comes out like that tilt the machine forward and put the bowl under the black hose undo the clip with pliers and slowly take the hose off water will flow when full push hose back up and empty the bowl keep doing this until empty , then remove blockage. Getting someone to hold the machine while you do this will be much easier.
Sep 05, 2007 | Hotpoint Aquarius WD63 Front Load...
Zanussi ZWD1470W Front Load Washer / Dryer Logo
172 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
