Question about Coby MP-C582 MP3 Player
Drag and droping songs
All i get is cannot copy song ,,, disc is write protected ,,from songs i ripped from my own cd s
  • 2 more comments
  • siuengr Dec 25, 2007
    same problem
  • ddaflunky Mar 29, 2008
    Anyone come up with a solution yet. Just got this for my son and nothing seems to get around this errors.
  • Anonymous Apr 04, 2008
    how to remove copy write protection
  • saritita Aug 20, 2008
    i try to put music into it and it dont work it says that it is media protected and it dont let me put no music in it
  • 3 Answers
There is a lock switch on the side of the player. It will not copy files if it is in lock mode.
Posted on Dec 25, 2007
Yep that fixed it! Just switch the "lock" off on the side of the player. Much thanks to siuengr.
Posted on Aug 02, 2008
Why do i get format error when i put songs from a cd on the eclipse?
1. Why do i get format error when i put songs from a cd on the eclipse?
= This is probably because the format that your songs are currently in is not supported by your device. Supported devices on the Mach Speed Eclipse 180 MP3 player are: mp3, wav, and wma. If your music is for example filename.cda, it won't be able to play because of the file format being .cda.
2. I also see the song on the eclipse but it says drm protected and will not play the song.
= When ripping your music, check your ripping options in whichever ripping software you are using that protecting music files is off, this may be the reason why your music cannot play - it may be protected to only play on the computer that ripped(recorded or duplicated) the song.
Sep 17, 2012 | Mach Speed Eclipse 180 MP3 Player
I turned my computer on and tried copying some music onto a disc but it would'nt let me. it wasn't on my devices with removeable in my computer. i followed online help but nothing seems to work any...
It will not possible to COPY songs from a commercially (original disc) available easily as you copy a regular file. In such cases you need to RIP the music files from the disc. There are soft-wares available that can rip files off the disc. Click on the link below:
http://www.freerip.com
Download and install Freerip. You can save t as mp3 format and copy to a cd to play in devices that play mp3 format or copy in wav format and then create a CD using a CD authoring software to create a regular disk. However, please note that copyright protected material should only be copied, if you own the original CD and should be done done only for archiving.
May 31, 2010 | Computers & Internet
Bought a gpx8gb digital media player for my daughter for christmas. I have downloaded her cd's into itunes library. Now how do I get those songs onto her media player?
Check to see that when you rip a music CD that your music is not copy protected. The RIP function in your Windows Media Player will allow you to convert the music CDs you have purchased into either an MP3 or a WMA format.
To adjust the copy protection setting on your ripped music files,
  1. Open the Tools tab at the top of your Windows Media Player.
  2. Select Options and then select the Rip Music tab.
  3. Choose the type of music file as well as the quality with which you would like to save the music. (Your GPX player has the ability to play music files in both the MP3 and WMA format.)
  4. Make sure to use MTP when transferring copy protected WMA files.
If you are using Windows Vista with Windows Media Player 11, you will need to follow these instructions.
Note: You will be able to download purchased/subscribed songs to the unit.
  1. Start Windows Media Player 11 and then connect your unit to your computer. If you have not set up synchronization between your computer and this device, the Device Setup Wizard starts.
  2. In Device Setup - Configure Sync, write a name for your mp3 player.
  3. Click Finish. The window closes and the Sync feature in the Player is displayed.
  4. From the left pane of this Sync feature, you can select from Playlists or Library and you will see the content of these folders in the center pane.
  5. Select the songs or entire albums from the center pane.
  6. Drag these songs or albums into the Sync List, which is the right pane of the Sync feature.
  7. Click the Start Sync button on the Sync List pane.
  8. Repeat steps 4-7 for any other items that you want to copy to your unit.
If you are using Windows XP with Windows Media Player 10, you will need to follow these instructions.
  1. Start Windows Media Player 10 and then connect your unit to your computer. If you have not set up synchronization between your computer and this device, the Device Setup Wizard starts.
  2. In the Device Setup Wizard, select Manual.
  3. Click Finish. The wizard closes and the Sync feature in the Player is displayed.
  4. Select the Library option. On the left pane select Sync List.
  5. From the left pane you can select All Music or My Playlists and you will see the songs located within these folders in the center pane.
  6. Select the songs from the center pane, and drag them to the Sync List.
  9. Good Luck, I hope this helps
  10. Please rate me, Thank you
Dec 09, 2009 | GPX MW3836 MP3 Player
How do you load songs on the tascam MP-GT1? does anyone know cause it would be much appreciated thnx
Connect the unit to your computer with the USB. It will show up as an external hard drive. Click on the unit from the menu and you will see 3 folders on the menu. Drag any mp3 music file from your computer to the "Music" folder on the unit. The problem you may run into however is that itunes music are copy righted and many songs on your computer may be mp4. You may need to rip directely from the cd's onto the computer, or even burn to a disc and then rip them back.
Nov 16, 2009 | Tascam Mp-gt1 Portable Mp3 Guitar Trainer
Why does it say error when i put on song onto my gpx mp3 player?
sEVERAL POSSIBILITIES:
* You downloaded protected music on your Windows 98/98SE, Windows 2000, Windows XP computer using Windows Media Player 9. Music was purchased online or the music was ripped form your own audio CD with Copyright Protection turned ON.
o You must use Windows XP and Windows Media Player 10 for online purchased songs.
o You must turn OFF Copy Protection on your Windows Media Player 9 before ripping your audio CDs into WMA files
* You downloaded protected music to your MP3 player using your Windows XP computer and Windows Media Player 10 with your player in USB mode. Music was downloaded from the internet, purchased or subscribed, or it was ripped from your own audio CD with Copyright protection turned ON.
o You have to use your MW3836 in MTP mode.
-Tha Mp3 Doctor
Nov 27, 2008 | GPX MW3836 MP3 Player
Wont copy songs to mp3 player because of write protection
  3. Under this menu, you will be able to choose the type of music file as well as the quality with which you would like to save the music.
  4. Make sure the box next to Copy protect music is left unchecked.
Your GPX player has the ability to play music files in both the MP3 and WMA format. Make sure to use MTP when transferring copy-protected WMA files.
-Tha Mp3 Doctor
Nov 04, 2008 | GPX MW3836 MP3 Player
Need help!!!
Here's your answer: Songs will skip ...
  • If "Copy protected" option is selected when ripping CD in WMP10 or WMP11.
    • Deselect "Copy protected" options in WMP10 or WMP11 before ripping CD.
How to deselect "Copy protected" options
  1. Run WMP software.
  2. Right click Ripping on the top menu, then select Tools / Options.
  3. Click Rip Music.
  4. Make sure to deselect "Copy protect music".
-Tha Mp3 Doctor
Jun 20, 2008 | Philips GOGEAR SA6045 MP3 Player
Coby mp3 player problem
Write the songs to a CD (or a CDRW) first, then re-rip them to Windows Media Player/iTunes/whatever as mp3s, or unprotected WMAs.
Honestly it's easier to burn and re-rip than remove the copy protection. When you burn it to a CD, the DRM goes away, and you'll have a new file that actually plays on your player.
Dec 23, 2007 | Coby MP-C883 MP3 Player
Won't play songs
If you used Windows Media Player to copy the Cd's to your PC the default setting is to "copy protect my music". To change that go to Windows Media Player>Tools>Options>Rip Music and uncheck the "copy protect my music" box. You will need to delete the previously ripped music from your device. Then re-rip the Cd's and transfer them to your device. Best of Luck.
Sep 19, 2007 | SanDisk Sansa e250 MP3 Player
Playing a song?
Did you use your own cd's? If so, did you use Windows Media Player to copy (rip) them to your computer? Windows Media Player, by default, has "copy protect my music" selected. To remove this, in Windows Media Player select Tools>Options>Rip Music and un-check the copy protect my music mark. You will need to delete the music you already transferred, then re-copy the music without protection, then re-transfer them to your device. Best of Luck.
Sep 10, 2007 | SanDisk Sansa e260 MP3 Player
Coby MP-C582 MP3 Player Logo
97 people viewed this question
Top Coby Audio Players & Recorders Experts
Gyula Lacz
Are you a Coby Audio Player and Recorder Expert? Answer questions, earn points and help others
