Question about Linksys Wireless-G WUSB54G 802.11g/b
I NEED TO CONNECTLINKSYS WIRELESS-G TO A NON
I NEED TO CONNECT LINKSYS WIRELESS-G TO A NON LINKSYS ROUTER
  • 2,260 Answers
What is the operating system on your computer.
If it is windows XP, then follow the steps below.
In the bottom right hand corner, in the system tray, you will find the Linksys icon ( it looks like green or white square). Right click on the icon and go to the option " use windows XP" then click Yes on the next window.
It will disable the Linksys utility and enable the windows utility.
If dont see the linksys Icon in the system tray, then it might be using windows utility.
Now go to START ==> control panel ==> network connections==>
Right click on the Wireless network connect and go the option View available wireless networks.
Now you will find your wireless network. choose the network and click conncet. if it is secured then type the network key and you will be able to connect.
Click Here for more information
Posted on Oct 06, 2009
  • Prashant M
    Prashant M Dec 04, 2009
    Click Here for Easy Set up Guide for step by step instructions.
    It will guide you with simple steps to resolve the problem in your network.
I am through which port do i connect the router linksys E900 to my laptop?
It's a wireless router, so you may not need to use a port at all.
You can connect to any of the ports numbered 1 through 4. The yellow Internet port should connect to your outside network. (Cable modem or router or Ethernet port from your Internet service provider.)
Mar 16, 2015 | Linksys E900 Wireless N300 Router
I have linksys 2.4 ghz + one 12' line. My new computer is in another room, 32 feet from cable modem how do I connect to internet?
I'm assuming that one computer isn't wife enabled. Depending on where the non wifi computer is located in relation to the router, you will need another either patch cable or a wifi adapter.
Feb 01, 2014 | Linksys Wireless-g 2.4ghz 802.11g W/speed...
After turning the power off for about 1 hour I am unable to connect via my wirless router. I can by pass the router to connect to the internet.
Make sure you update your wireless router firmware..
Use link below to update
http://homesupport.cisco.com/en-ca/wireless/lbc/WRT54G2
Please note:
Linksys is known for alot of problems with there firmwares causing tons for problems ..
I use a linksys wireless router my self & had to unplug the router every 2 to 4 days because it would stop any computers to go on the internet.
I flashed my firmware and put in a 3rd party firmware that has never caused any problems and it gave me tons of features that your linksys firmware did not.
If you are a advanced user you can flash your firmware and put in non-linksys firmware. Not all routers can accept this firmware but you can search up your router model and version to see. Make sure you read all the how to install and all the warnings .. Keep in mind there is a chance no matter if you followed the instructions exactly that it could destroy your router. But the chance is low.
Check out this site http://www.dd-wrt.com/site/index
Feb 27, 2011 | Linksys WRT54G2 Wireless Router
I need to secure my linksys router, please advise. Linksys WRT160N
Is there any computer connected to the router ?
If not then you will need to connect the computer to the router.
Do not change any wireless settings on the router with the wireless computer.
you will need to connect the computer to the router with the Ethernet cable.
check the IP address of the computer.
open the router set up page of the router.
Here you can change the wireless settings of the router.
Now once you change the network anme and security on the router, you will need to connect to the wireless network on your wireless computers.
Click Here for step by step instructions
Oct 15, 2010 | Linksys WRT160N Wireless Router
Ireless-B 2.4GHz Broadband ROUTER Linksys i need key
the key maybe written on the bottom of the unit otherwise you will need to loginto the router and goto the wireless section to find the key and security type
Connect with a cable to your computer, and enter the Router's default IP address, 192.168.1.1, in the Address field. Then, press Enter. A login screen will appear. (Non-Windows XP users will see a similar screen.) Leave the User name field blank. use the default password admin. Click OK to continue.
Sep 28, 2010 | Linksys WRT160N Wireless Router
Hello i am trying to connect to me friend on xbox live with a WRT54GS linksys router and i unchecked the nat filter and the upnp is enabled but i still cant connect
PS3 and Xbox ( NON BELKIN)
You Will Have to Disable the Firewall In Your modem / Router
And IF it is a router then Open The Ports
• TCP 80
• UDP 88
• UDP 3074
• TCP 3074
• UDP 53
• TCP 53
And also make sure that UPnP is Enabled
May 20, 2010 | Linksys Wireless-G WRT54G Router...
2nd laptop will not connect to internet
I'm assuming that your 2nd laptop is wireless? Does your router have encryption? If it has, then you need to get the encryption key from one of the working computers. Access the linksys interface from one of the working computers. Usually this is done by going to http://192.168.1.1 (leave username blank, password is "admin"). Go to Wireless> Wireless Security. Is encryption selected? If yes, get encryption key #1 and use it on the non-working laptop to connect to the router. If encryption is not enabled, go to the steps below.
On the 2nd laptop, click on the wireless icon at the bottom right part of your screen. Look for the linksys router from one of the available wireless networks, click connect and enter in the encryption key when it asks for it (not case-sensitive. Usually it's 10 or 24 digits). If encryption is not enabled, it will not ask for the encryption keys when you hit connect. See what happens.
Jul 05, 2009 | Linksys Wireless-G WRT54GS Router...
Linksys wireless adapter won't auto connect to 2Wire router
Go into the wireless adapter settings and make your connection "default" and then it should connect automatically .. and if not then look for a "connect automatically setting
May 29, 2009 | 2wire HomePortal® 1800HW Router...
Router connections
Is your speedstream router also your high speed modem? If so, you will have to go into the settings on the Linksys and change its IP Address subnet from 192.168.1.1 to 192.168.2.1 (or you can use a different number than 2) You will then need to reboot both routers (and possibly the computers) and try again. The easiest way to get into the Linksys settings is to connect it directly to the laptop via network cable, then type in 192.168.1.1 in the web browser. No user name and admin is default password. (Make sure you change that, and the name of the wireless, and the security settings)
Good Luck!
Dec 08, 2008 | Computers & Internet
Linksys Wireless-G WUSB54G 802.11g/b Logo
203 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
