Question about Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White
Frigidaire oven is slow to heat then exceeds set temp set
Figidaire side by side oven model # REG46NW-1 is slow to reach set temp and then proceeds to exceed set temp. Set at 350 degress -reached temp after 45 min. 1hr later, temp was 425. This was all monitored by oven thermometer. Where might I find a part for such an old oven?
  • Frigidaire Master
  • 909 Answers
Normally you should have an appliance spare parts supplier in your area. They generally stock all range of spares for all appliances. You need to pull plug out of the wall and remove the panel covering the wiring to gain access to the oven thermostat. Look carefully on the body of the thermostat and record any numbers you see on a sticker that's present. Then remove knob off in front of thermostat and see if there is a nut attached to the centre which holds the thermostat in position or if there are 2 screws holding the thermostat in place. Use this information to order the thermostat also quoting the oven model number.
Posted on Oct 06, 2009
Frigidaire Oven Problem
please post the model Number here..so i can look it up but just off hand there maybe an oven sensor (thermistor) problem this in inside the oven and tells the electronic ctrl board what the actual temp is in the oven it says 135 beacause it will until the temp reachs that after that as the temp goes up it will read 140 150 160 .. and so on until it reachs the set temp .. Is the oven getting hot and are there any fault codes coming up??
Jan 28, 2008 | Ovens
Frigidaire stove is about 12 yrs. old. My oven will not heat past 250 degrees and it takes along time to reach that temp. The stove never indicates that the preheat temp. is reached. This just started last...
Hello, welcome to FixYa.
If you can provide the complete model number (usually on inside of door frame or around the bottom door opening), I'll see what I can find for you.
There are many possible scenarios as I hope you can appreciate being this is a global repair site, even within' the Frigidaire brand so I'll need to clarify the make & model before moving forward.
Regards,
Macmarkus :)
Aug 14, 2011 | Ovens
We purchased our Frigidare Double Oven, Model Number FPET3085KFA, October 2009 (15 months ago). We ran the self-clean process for the first time yesterday on the top oven using the 4 hr option and it...
try turning your breaker off for 20 minutes, then try it again,, if this does not help it could have burnt out a element or the main board has went out,,, also make for sere you are getting the full 220 volts to the unit,, this will involve taking the unit out
Jan 19, 2011 | Frigidaire 30 in. Electric Gallery Series...
When set to bake eg: 350 degrees the audio alarm will indicate it's reached temp but the oven is 50- 75 degrees lower. Must wait another 15 min for it to reach the proper temp. Have tried to adjust the off...
If you are monitoring the oven temperature with an analog style thermometer you may actually be ok, but seeing the thermometers slow reaction time.
Some newer ovens actually do pre-heat beep prior to reaching temp in an effort to conserve eelectricity.
A good home test is to try your oven at several different temps to see if there is any variation in internal temperature. Try it one day on 300, the next at 375 and another day at 450. Give your analog style thermometer time to catch up (usually just about 15 min) and leave it on for a half an hour to see if the temp maintains.
Also Beware of aluminum foil AND THE NEW OVEN LINER MATS as they can alter oven performance bay absorbing and blocking the ovens natural heat radiation and convection air flow currents that happen in all ovens, not just convection models.
Another interesting fact is that older ovens used a thermostat in them that operated much like your thermometer and was very slow to react making the oven typically about 100 degrees hotter than where the customer set it. This was just a fact of life before the advent of electronic temperature management and became noticeable when people began trying to bake older "hand me down" recipes in the newer ovens with less than stellar results.
You can mimic the older oven performance by preheating the oven about a hundred degrees higher than called for and after it reaches temp, re-set it to the correct temperature and put the items in right away.
If you find your temperatures fluctuating ask your servicer to replace first the temp sensor and as a last resort the control board as this part is usually pretty expensive.
Good Luck with this!
Jun 14, 2010 | Ovens
I have a frigidaire oven model # PLEB30S8CCB won't get above 290
The coils should glow red when working. If the lower (bake) element does not glow it may be burnt out. Some ovens cycle the bake and broil elements during preheat and that mey be why you are getting some heat.
Aug 27, 2009 | Ovens
OVEN WILL NOT COME UP TO TEMPERATURE
You can calibrate the oven on this model. Press the bake button, adjust the bake temperature up to 550 degrees and then press and hold the bake button until a 0 displays. Now you can adjust the oven temperature up or down to match the display.
Here is a repair manual link that you can use to download frigidaire repair manuals. The one for 30 inch freestanding ranges will have the section on calibrating the oven's electronic control.
Thanks
Jan 09, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Oven Temperature Probe
It could be your ignitor, if weak it might not be good enough to draw ampage.I would suggest to change both ignitor and temp probe to be in a safer side. part number for ignitor is 12872 $56.0+, Part # for your oven temp. sensor 833085, it should not be more than $28. other part from www.repairclinic.com.
Jul 25, 2008 | Frigidaire FGB24S5A Gas Single Oven
Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
311 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
