Question about Xerox XA7-17i 17" LCD Monitor
Tft LCD monitor normaly start after 40 min takes-on
I have tft LCD monitor, 17 inch, model TFT 1780+,China,After takes-on any picture appear or no screen message, just some lines flashed on.Exactly afrer 40 min. takes-on normal picture will appear or normal message appear on screen.After then monitor works normally all time until take-off.Would you please be so kind to define this failure.I have no schematic plan and no troubleshooting manual.Much thanks of Janez Koncilija, Slovenia, My E-mail is:
  • Xerox Master
  • 563 Answers
Posted on Dec 21, 2017
  • 317 Answers
SOURCE: compaq tft 5000 out of work
Your backlight probably went out and needs replaced.
Posted on Jul 31, 2007
SOURCE: Problem in TFT
Posted on Sep 24, 2007
  • 198 Answers
Sounds like an inverter problem. If the power supply is internal replace the capacitors coming out of the voltage regulators. These are usually 1000mf and/or 470mf. If that doesn't do the trick look up the numbers on the 8-pin chips that drive the secondary transformers on the inverter to see if they are getting the right voltages.
Good Luck!
Posted on Feb 20, 2008
  • 191 Answers
The OSD can be enabled or disabled by pressing and holding the Menu button on the front panel for 10 seconds. If the OSD is locked, the warning message OSD Lock displays for ten seconds.
  • If the OSD is locked, press and hold the Menu button for 10 seconds to unlock the OSD.
  • If the OSD is unlocked, press and hold the Menu button for 10 seconds to lock the OSD.
Posted on Jun 09, 2008
  • 1288 Answers
SOURCE: My 19" TFT LCD monitor
Power capacitor problem, needs taking to a qualified TV repairshop to have the capacitor replaced / checked
Posted on Dec 28, 2010
I was given an ilive dvd player boom box, model IBPD882B and the display screen doesn't work. Can I get another screen for player?
yes, but check connections
7inch TFT LCD Display HSD070I651 480×234 Resolution 7"Analog ... > ... > LEDs, LCDs & Display Modules > LCD Display Modules
7" HSD070I651 480X234 LCD Screen Signal Interface 26 pins TFT Specific Analog RGB, FPC. Resolution 480 ( RGB)×234. Viewing Angle 60/60/40/60 (Typ.). (CR?10) [Left / Right / Up / Down]. Display Mode TN, Normally White, Transmissive. ' eBay!
7 Inch TFT LCD Color 480 x 234 Resolution Stand/Mount Rear Button ... 7 Inch TFT LCD Color 480 x 234 Resolution Stand/Mount Rear Button Leg Monitor with 420 TV Lines Night Vision Camera: Car & Motorbike.
7-inch TFT LCD Module with 480 x 234 (RGB) Resolution, Available in ... > All Categories > Electronic Components Number of the colors: 65KModule dimensions: 164.9 x 100.0 x 5.5mmVA size: 7 inchesAA size: 154.08 x 86.58mmResolution: 480 x 234 (RGB)LCD type: TFT and transmissiveViewing direction: 12:00IC: HX8227-A01 and HX8655-ABacklight: CCFL backlightOperating temperature: -10 to 60 degrees CStorage temperature: ...
Feb 06, 2018 | iLive Televison & Video
I use 17" TFT LCD monitor of HCL make. there is a blue straight line appears on my screen. please suggest what to do to resolve the problem.
change your screen resolutions two~three different settings and a different computer - lf the line appears in same position, it's most likely bad monitor.
Sep 22, 2010 | Computers & Internet
There are vertical lines appearing on the screen. the lines come and go.
The lines could be a broken or faulty video cable (VGA, HDMI) whichever your using. Try replacing the cable, if it persists it could be a faulty or broken screen.
Aug 22, 2010 | Dell E173FPb 17" TFT LCD Monitor
There is horizontal line come in TFT in last 2 yr i ask the dealer he told that its bcoz some resister short now after another line come in my TFT whats the problem? and notice that this problem come after...
You may have failing TFT (Thin Film Transistor, each pixel on the screen is driven by one transistor, so there are 100 of thousands on the LCD panel
) or bad connection or failing T-CON board.
See pictures here:
It will usually get worst with more lines as time goes by. New panel will be needed.
Jun 15, 2010 | Samsung SyncMaster 740N 17" LCD Monitor
Where can I buy a power supply for an AOC LCD monitor model TFT 1780?
hi, i don't know if you will ever find just the power supply board for this monitor. i repair lcd monitors for a side business and i have never found the exact power board i needed for any of the monitors except for dell 17in. you would have to look on ebay for another broken monitor just like your with a working power board, broken screen maybe. that being said, why do you think you need a power board complete? the parts on the board are replaceable. maybe you could post a reply so i can read to help with what the symptoms are and help you diagnose the problem components? if you posted pictures in your reply of both sides of the board, it might help me describe more in depth.
Mar 08, 2010 | AOC 1780 (Beige) 17 in. Flat Panel LCD...
Dell E173FPf 17 vertical line problem
Yes, but the cost is not worth it. If you get it apart you will no doubt find a couple of bulging capacitors. Dell site has the disassembly instructions.
Oct 10, 2009 | Dell E173FPf 17" TFT LCD Flat Panel...
Dell E173FPc 17" TFT when turned on goes black
Hi Gaz,
First, verify the monitor is functional.
Monitor STFC (Self Test Feature Check)
Turn off the monitor
Plug the monitor power cord directly into the wall socket to remove any surge protectors or APCs from the troubleshooting equation
Unplug the monitor video cable from the back of the computer
Turn on the monitor
The floating dialog box should appear on screen against a black background.
If the issue appears during the STFC, the monitor is defective. What are the results please?
Jan 22, 2009 | Dell E173FPc 17" TFT LCD Flat Panel...
No display, clipping sound appear
The clipping sound is the internal safety switch that keep shutting down the monitor.
It means there is an internal problem on the main board (overvoltage, bad component , short).
Try unplugging power cord and leaving it unplugged two or three hours, this will reset ICs by draining power completely from circuits, it is called hard reset, it rarely works.
CRT monitors waste up to 15 times more energy than TFT screen, if your CRT starts giving troubles, then it is a good time for upgrading it to a new TFT.
17'' start at $120
17'' Dell 1703FPt DVI LCD Monitor w/USB Hub (Black/Silver) -B
171ABB 17" Widescreen LCD Monitor - 1440x900 (WXGA+),
Envision H716A4 17 in. LCD Monitor
19'' Princeton VL1919 DVI LCD Monitor (Black)
19'' panoramic
V7 Series D19W12 19" Widescreen LCD Monitor
Sep 10, 2008 | ViewSonic E70f 17" CRT Monitor
Open Questions:
See all Xerox XA7-17i 17" LCD Monitor Questions
Xerox XA7-17i 17" LCD Monitor Logo
77 people viewed this question
Top Xerox Computers & Internet Experts
Jack McCann
Jack McCann
Are you a Xerox Computer and Internet Expert? Answer questions, earn points and help others
