Question about Rinnai Desa Vent-Free Infrared Gas Heater: Vent-Free Infrared Gas Heater(18,000 BTU)
Glo-Warm heater shuts off
I have a glowarm heater that I used for one season last year. I've been using it for a bout a week now and this morning when I got up it had shut itself off. I started it back up and when I went into the room it was off again. What do I need to do? There is plenty of air flow. This is an old house and not air tight at all. Thanks for your help.
  • 2 more comments
  • Lawdog1880s Dec 23, 2007
    Glo-warm heater shuts off after being on for awhile. Have to let cool down and relite pilot.
  • Anonymous Jan 02, 2008
    If I turn the heater down to 1 burner, after several minutes It shuts off the burner, and pilot.
    we have two glo warm gas heaters in our home. since the temp. has dropped one of our heaters wont burn. my husband has cleaned it and still when he lights it , it will only burn for about 10 seconds then go out. can you help?
  • Anonymous Dec 11, 2008
    My Glo-warm heater is two years old and when the burner cuts off during operation the pilot also turns off and has been difficult to relight. It's turned cold here and we really rely on our heater to stay warm. Any help would be appreciated.
I have had the same problem and I think I fixed it. Near the pilot light you have the part that shots the spark (electric ingitor?) behind it is another brass part which I beleive is flame sensor, what I did to fix it is losen the philips screw that holds the two in place then pushed the flame sensor higher so the pilot light hits it more, then just tighten it back up. I hope it helps....
Posted on Dec 12, 2008
  • 625 Answers
Near to where the fire plate is there is a high temperature limit that is connected by two wires to the pilot millivolt generator. try relocating this limit further away from the flame jet. it too might be faulty - go to desatech dot com for a new limit.
Posted on Dec 25, 2007
I have a GloWarm propane/lp gas space heater. Can I use bottled propane tanks?
no you can't, and aren't you worried about carbon monoxide poisoning? Where does the burnt air go?
GloWarm Heaters - ventfree infrared heaters
GloWarm Infrared heaters are residential gas space heaters that are ventfree,
so no venting is required
GloWarm Plaque Infrared heaters direct heat from radiant plaques that
"warm like the sun."
Infrared heaters heat objects in the room before the air,
making them ideal for un-insulated rooms in your home.
All propane heaters require a 100 lb. tank or larger!
GloWarm Heaters ventfree infrared heaters
Oct 27, 2015 | Heating & Cooling
Glo warm wall heater will not stay lit
Hi Cindy,
It seems that your heater is not sensing the flame is lit and is shutting gas supply off. There should be what is called a flame sensor, it is a thin pc. of metal that sticks out into where the flame when lit.
This usually gets charred and dirty, if you unscrew it and clean it with a soft cloth then re-insert it, it will get you by. You should get a new sensor when you have a chance.
Good luck and be sure to disconnect from any power source or turn unit completely off when orking on it.
Jan 27, 2009 | Desa International GWP20T GLOWARM Wall...
the first thing I would do is pull it apart and give the bricks a good cleaning with a wire brush to get any soot off. If they are broken beyond the point of replaceing them in the unit you will need new bricks.
Jan 18, 2009 | Desa International GWP20T GLOWARM Wall...
First brick burner worn out, can all bricks be replaced?
They can be replaced, go to enerco/Mr.heater as they own Desa and they will hook you up with the parts you need at a fraction of the cost of a retail parts supplier. you can also cal 1-800-251-0001 and talk to a tech.
Jan 16, 2009 | Desa International GWP20T GLOWARM Wall...
Natural Gas wall heater
It sounds like the thermocoupler is either not adjusted into the flame properly, or you may have gotten a bad one. The thermocouple is the main thing that makes the pilot work.
Dec 22, 2008 | Dyna-Glo D-E36 Infra-Red Wall Mounted...
Were do i install the thermostat
It should just hang out the back of the unit. I hope this helps...
Dec 21, 2008 | Desa International GWP20T GLOWARM Wall...
My glo-warm propane heater keeps shutting off automatically-pilot and all.
my heater says if the pilot light keeps going off automatically it is a safety function that means it does not have enough fresh air to operate
Nov 03, 2008 | Desa International Blower Glow Warm Wall...
Glo warm heater
These are vent-free heaters and use an oxygen-depletion sensor to shut a unit off if there is not a sufficient amount of oxygen available for combustion. It is either doing it's job and you may have to open or crack a window while it's operating.
Feb 07, 2008 | Heating & Cooling
Heating & Cooling Logo
1,129 people viewed this question
Top Rinnai Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
vance jones
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
