Question about Garden
The clutch spring on my riding lawn mower broke, I've replaced the spring but can't find the original location it was mounted.
  • 1 more comment
  • jammill66 Oct 06, 2009
    Sears 12hp Model# 502.354982 I hope this helps.
  • Chuck
    Chuck May 11, 2010
    This is NOT a "generic" problem. It is model specific so without a model number it will be difficult if not impossible for anyone to offer you a solution
  • Bruce Hathcock May 11, 2010
    what brand of mower?
  • 472 Answers
WHAT MOWER DO YOU HAVE
Posted on Oct 07, 2009
I got stuck in the mud the other day. Now the belt that turns the blades is loose. On my old mower I just pulled a lever and the belt tightened.
either the belt came off a pulley of the spring for the tensioner cam off the mounting area.....or the belt is broke.
May 27, 2016 | Simplicity Broadmoor 20hp Briggs &...
Can I replace the wires in the clutch ?
if the is no tail sticking out then NO you can not fix . just replace with a new one .
Apr 23, 2016 | Husqvarna Rz5424 Zero Turn Lawn Mower...
How do you replace a starter seleniod on a Craftsman riding lawn mower, 17.5 HP?
It mounted to panel under the dash. Unhooked battery, (2)then unbolt solenoid,(1)then unhook wiring. Install new.
May 17, 2014 | Craftsman Garden
I've got a 2005 husqvarna yth 2042 riding mower,i broke one of the belt guides,(on order)-the spring extension for the clutch,where does it hook to?
Not too sure which guide you are refering too, the only keeper at the clutch is the anti rotation bracket for the clutch itself, it bolts to the side of the chassis and the other end sits into a cut a way in the side of the clutch assembly.
Apr 24, 2012 | Husqvarna Riding Lawn Mower 42 Inch Cut...
YTS 3000 clutch return spring noise, sounds like it is rubbing on something when you release the clutch but I can't even find the spring
The spring will be attached to the tensioner pully right on top, there is a threaded bolt with nut holding the spring on, I just had to order the clutch cable because the spring broke, from rubbing on metal when engaging and disengaging the clutch lever.
Jul 30, 2010 | Craftsman YT 3000 42" Kohler 22 hp Gas...
The mower deck clutch cable broke so blades will not engage and lever is loose on my Sears Craftsman 42-inch lawn tractor (917-271-742). I fished out the top piece of the cable, about 12 inches down to a...
I just got the kit 175067. Have the old one off except for where it's attached to the lever, schedule and weather has kept me from going further. Very simple to reconnect things at the pulley and above but not too sure how to connect the rest onto the lever and haven't had a chance to get a good look at how the old one might be connected yet. Should be a simple fix.
Jun 20, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Spring is broken
There are many springs on a riding mower. Is it the clutch spring, the idler pulley spring, or maybe the blade brake springs. There are also springs on the brakes and even under the set. Please be more specific.
Aug 23, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
My john deere riding mover the clutch will not disengage it still keep going.any solutions
With the engine OFF, reach underneath and locate the plug for the blade clutch and unplug it. Start up the mower and see if the blades are turning. If they are still turning with the clutch unplugged, REPLACE THE CLUTCH
Jul 18, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Mower will not stop when clutch is depressed
When you replaced the belt you either got a shorter belt or you have rerouted the belt wrong. You might try and get an original; belt and replace the one on the tractor. Good Luck-David
May 16, 2009 | Craftsman 20 hp 42 in. Deck Yard Tractor
Weedeater Clutch Spring Replace
Counter man at the local mower repair shop said to use a thin rope. Tried it and it works great. Think I over engineered this problem.
Thanks for your help.
Wayne
Sep 22, 2008 | Garden
Garden Logo
230 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
