I have a 10 year old Kenmore 70 series washer. It just started making a grinding noise on the regular cycle and the agitator doesn't seem to be working properly, only agitates very slowly. Also When the cycle completes I have to put the dial back to the spin cycle for it to spin the clothes dry, but it does spin then dry. Help
SOURCE: maytag PAV2300AWW Washer makes grinding sound when agitating
Sounds like it is the bearing on the water pump. Take off back plate and replace and remove 3 screws and two hoses (the one hose is a waste line so make sure you have a bucket to empty our waste water) after removing these remove belt on bottom of pump.
SOURCE: the agitator moves slowly and grinding
If this is a Whirlpool manufactured TOP LOADER, an agitation problem can have several causes. Most commonly, this is caused by a broken motor coupling. The following link explains how you can diagnose the problem and repair:
http://www.fixya.com/support/r3965207-whirlpool_top_loader_no_spin_problem
I have included parts sources and instructions on how to replace any parts as well.
If this just a simple matter of the agitator not working, but everything else does, you may just have a worn agitator cam assembly, worn agitator dogs, loose agitator bolt, or all of the above. The following link explains what agitator dogs are and how to access them:
http://www.fixya.com/support/r3608577-replacing_agitator_dogs
Whirlpool manufactured washers use a split agitator design. The top half is known as the "auger, while the lower half is the agitator. Between the two pieces is a cam assembly, with small teflon teeth known as "dogs". There's also an agitator bolt that holds the entire assembly to the center post.
If the auger (top half of the agitator) is slipping, I would suspect the dogs or cam assembly need to be replaced. The part number for the dogs is included in the link I provided. For a little more you can purchase the entire cam assembly which includes the dogs, the cam, the cam seal and thrust bearing.
If the entire agitator appears loose or slipping, check the agitator bolt to ensure it is tight. DO NOT overtighten as this can restrict movement of the agitator or damage it. Tighten until snug.
Last of all, the most expensive problem that can occur, is a failed gearcase (transmission). The gearcase averages between $80 and $160 to purchase. If you wish to replace the part yourself, it is not that difficult. The following link explains how:
http://www.fixya.com/support/r3576575-replacing_a_gearcase_on_whirlpool_manufa
The procedure is rather lengthy, but not as difficult as you would think. It can save you a lot in labor charges.
Replacement parts (if required) can be purchased at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
All these sites are reputable and offer great service with competitive pricing, so shop and compare. The first three sites I listed also include helpful exploded view parts diagrams to assist you in locating and properly identifying the parts you need. If the model number is correct, the following part numbers you may need:
Motor Coupling 285753A
Agitator Cam Replacement Kit 285809
Agitator Dogs 80040
Gearcase 3360629
NOTE: If you replace the gearcase, replace the motor coupling as well. The sears website will sometimes offer a refurbished gearcase for about half the price of a new one. The part number will end in the letter "R".
If you have any questions, please post back and let me know. I hope this is helpful to you.
SOURCE: I have a HotPoint washer
Do you here the motor running on the agitation cycle yet it doesn't agitate? If so the agitator coupling is the problem.I have included a youtube video that will show you step by step how to repacle the coupling.The part number in the title of the video(WH49X10042) is the part number that you would need(Hotpoint is made by GE) it could be ordered by simply googling that part number
here is the lik for that video http://youtu.be/N26MCQKuXn0
I hope this helps and if it does please give me 4 thumbs up
Gene
SOURCE: Maytag washer doesn't agitate
Google the model number. I had the same problem, Googled it, and found the actual turial on YouTube to fix it.
