Sony RDR-HXD860  DVD Recorder / HDD Recorder
Problem for Sony RDR-HXD860 (160 GB) DVD Recorder / HDD Recorder
Won't play back or burn some discs originally
By CrouchEnder on Oct 06, 2009
Won't play back or burn some discs originally burnt on PC, although these are finalised and will play on my older Panasonic VHS/DVD combi and on PCs other than those on which the original burn was carried out. Discussion groups for software e.g. Roxio Easy VHS to DVD suggest that the DVD player is the problem, not the software. Why is this? And what can I do about it?
Comments:
Oct 06, 2009
- In the case of disc I burnt myself, I put it on the highest possible setting to get the film onto one disc (i.e. "good" rather than "best" quality, but still one up from "normal"); I used Verbatim discs, which seem to be recommended by most sites. Therefore, I can't improve quality on either of these fronts. In the case of discs burned by others, they were also on Verbatim, and also presumably burned on as high quality setting as possible. So this advice doesn't help, I'm afraid.
Oct 06, 2009
- (You may still say I should try "best" quality burn, and use more discs; but that doesn't explain why the same discs play OK on my older Panasonic, or why other people from whom I originally received them don't have the same problem with their hardware.)
Solution #1
posted on Oct 06, 2009
Not Rated)
metallica4
Rank: Guru
Rating: 88%, 32 votes
When burning cd try putting on highest quality burn setting, or useing better quality discs.
Was this helpful?
Yes
No
Popular Solutions for Sony RDR-HXD860 DVD Recorder
Questions and Unsolved Problems for Sony RDR-HXD860 DVD Recorder
Do you recommend Sony RDR-HXD860 (160 GB) DVD Recorder / HDD Recorder?
Answer
Answer
not recording series and putting timer programmes in that weren't selected
Answer
My sony rdr hxd 860 wont allow me to timer record to hard drive. when select the film on the EPG... (More)
Answer
When I switch to watching TV through the recorder I get a display in the top left hand corner of the... (More)
Answer
Only recently I have started to have problems with the automatic series record. It seems to omit... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top DVD Players Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
