Question about Palm Treo 650 Handheld
Error code 0x80040702
Trying to remove old palm file to download newer version and get error 0x80040702 and can't get old palm program to delete from programs failed to load dill: hsapi fatal error during installation. install disk, connect phone, the above comes up...
  • john19462712 Jan 10, 2008
    did all of the above but no joy. thanks anyway
  • Anonymous Nov 24, 2008
    Trying to uninstall palm program (For 3Xe) wich is apparently not supported by Vista and it keeps coming up with error code 0x80040702 and does not uninstall.
You should go into your computer to my computer. then file programs.look for palm then open. look for your user name open then look for backup file rename the back up file then hot sync the phone then use the same user name it will start up a new back up folder. you might have something on your phone that the phone do not agree with. this should work if you hot sync your phone to your computer.
Posted on Jan 09, 2008
"how to fix error code 0x80040702
The 0x80040702 error is common on computers on which you are trying to install a game or piece of software. The error will show for a variety of different reasons, but is almost always shown when you are installing something on your PC. There are several causes of this problem and several ways to fix it, depending on the cause. Here's what you need to do to fix it...
The biggest reason why this error appears is because of missing DLL files on your system. To fix this, you must first see if your PC has any of the missing DLL files on your PC and if it does, then put that file in the right place. To do this, click on Start > Search. Then search for the filename the installer claims is missing. If any results come up, then copy the file into the C:\Windows\System32 folder of your PC. If there are not any files with that name on your system, you should search for " download" on Google, download the file and put it into the C:\Windows\System 32 folder. This should cure the problem.
If that method does not resolve the issue, you should then perform a clean out of any leftover settings that previous installs might have left. To do this, browse to C:\Program Files\ and delete all the files inside that folder, clean out your PC with a registry cleaner and restart your PC. This should stop the error if it appears when you try to perform an upgrade, repair or reinstall of your software.
If these don't work, you might have a virus infecting the files or settings the program needs to install. To combat this problem, you should download an antivirus program and then install it on your PC, allowing it to scan your system. It will find and remove all the infections on your computer, which might stop the error from appearing.
Article Source: http://EzineArticles.com/4122823
Apr 04, 2014 | Computers & Internet
Cannot Uninstall Existing Version of Webroot Spy Sweeper
try removeing the program from add or remove programs.
start -> control panel -> add or remove programs.
find the program from the list and click uninstall or change, which ever it may say.
Jul 29, 2008 | Webroot Spy Sweeper (spysweeper) for PC
They are probably in a format that the pda can not handle.
Sep 14, 2009 | Palm Tungsten E2 Handheld
Trying to install Spore. Receive the following error message: Error 0X80040702 Failed to load. Can you help?
unninstall
not that it helps but try getting rid of all spore files on your computer and reg files. (that may be there from the partial install)
for the files got C:\programs
delete spore
get CCleaner to get rid of registry file problems.
try again. of this does not work sorry for useless answer :)
Aug 06, 2009 | Sony PlayStation 2 (PS2) Console
Reinstall the game if problem stays repair ur operating system
May 17, 2009 | Microsoft Gears of War for Windows, Mac
Error 0x80040702 while installing corel draw 11
http://www.download.com/1770-20_4-0.html?searchtype=downloads&tg=dl-20&query=registry&tag=srch
Download one of these programs and it will check for files that have been corrupted that is not allowing you to download your file
Feb 17, 2009 | Corel IGrafx Process Central 2005 - 2...
http://forums.cnet.com/5208-6122_102-0.html?threadID=267023
Try this site because others have solved their problems and they seem to be different. Good Luck
Fehdi
Jul 09, 2008 | Computers & Internet
it may not be removed compltely . use any mamory defragmention progrmas like ram booster ot dspeet it up extreme and defragameny ur ram and try insatalling again
Dec 12, 2007 | Toshiba Satellite A135 Notebook
Unable to install a new powerdvd version
I imagine that it's trying to uninstall the older version to install the newer one, which it can't. NOTE: This is a desperate step. Delete the Cyberlink folder in C:\Program Files\; Go to Add/Remove Programs and attempt uninstall - it will say it can't uninstall, and ask you if oyu want to remove it from the program list. Click yes. Go to start->Search (or Find) and search for Cyberlink (make sure that Hidden and System files are being searched). Delete all Cyberlink files. Do the same, but with PowerDVD. Download and run CCleaner. Attempt to reinstall PowerDVD.
Nov 09, 2007 | CyberLink SW- DVD Software Power DVD...
Palm M515 and compatibility with Vista Home Premium
I was having a similar problem with my M515.  I had originally installed the Palm Desktop from my CD, which was an older version.  When I totally uninstalled the old version and installed the newer version from the Palm website I was able to do a successful sync.  I'm using Windows Vista Ultimate and Palm Desktop version 4.1.4
Oct 24, 2007 | Palm m515 Handheld
Palm Treo 650 Handheld Logo
427 people viewed this question
Top Palm Computers & Internet Experts
Marvin
Marvin
JC Meredith
JC Meredith
gary433
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
