Question about Clarke Air Tools & Compressors
I have an old tiger air compressor. How do I
I have an old tiger air compressor. How do I service it?
    President:
  • 1,167 Answers
Is it a piston machine buddy
Posted on Oct 06, 2009
Triumph Tiger 885 rough idle
Hi, Margret and the usual suspects are:
1. Idle speed improperly adjusted.
2. Air fuel mixture screws not properly adjusted.
3. Inlet system air leak.
4. Leaking accelerator pump.
5. Loose low-speed jet.
6. Plugged low-speed jet.
7. Contaminated or plugged low-speed circuit.
8. Enrichner valve/choke not seated or leaking.
9. Multi carburetors out of sync and need to be balanced.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Tiger rough idle
1999 Tiger 885i Fix build Help
Triumph Tiger Service Manual
http://www.worldoftriumph.com/triumph-motorcycle-parts.html Triumph Tiger Handbook
Jul 05, 2017 | Triumph Tiger Motorcycles
Hi How long should the service take when checking shims ? Sorry Triumph Explorer 1200 (2014)
Hi, Mark all depends on the mileage but a 20,000 service takes which includes checking and adjusting valve clearance takes about 7 hours for more information about your question and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Triumph 2012 2015 Tiger Explorer 1200 Service Repair Manual Download... $18
Hermys Tire Cycle Inc 2013 Triumph Tiger Explorer Genuine Motorcycle Parts...
Triumph Tiger Explorer Owner Handbook Manual
Triumph Tiger Explorer 2014
May 05, 2017 | 2013 Triumph Tiger Explorer
Replace discharge line on air conditioner 2008 Honda Pilot
tiger by tail.
read the FSM , see what it says.
not one tool you own , i bet.
go to alldata.com (pop that into google and bingo)
RTM , then ask questions.
IIRC:
  1. pull battery cable neg lug.
  2. connect collection system to our car and capture all freon.
  3. replace line., (unscrew fittings)
  4. new receiver dryer.
  5. pump down system to a vacuum. (gets killer water out)
  6. new compressor oil.
  7. new Freon. by weight added.
  8. test system.
its more then that. but you can google "car freon loop service" any time. or "car R134 loop service"
1million hits. google is your friend. LOL>
here ill type it for you....
https://www.google.com/#q=car+R134+loop+service
Jun 09, 2013 | 2008 Honda Pilot
Clarke tiger 8\35 1.5 hp compressor runs for short time then shuts off and will not start
It sounds like the motor has a weak thermal overload if after a while it starts again. Either that or it's drawing high amps in which case you could have one of several different problems.
Jan 04, 2013 | Air Tools & Compressors
1 month old compressor has oil in tank
the piston rings may have not seated allowing oil to get by. The oil is then carried to the tank with the air. After enough run time and cycles they should seat. If not and this is a new unit I would call the 800 # on the unit and talk to customer service at IR.
Aug 29, 2010 | Ingersoll Rand Type 30 Reciprocating Air...
No cooling at all
I have been out of the air conditioner service sector for a while. I wanted you to know up front that I may be out of date. When running service I replaced many compressors for a fraction of the cost of a new unit. Many of these customers had been told the same thing. Service companies make allot more on a new unit than they do repairing an old one. Many don't have anyone capable of replacing a compressor. Get more than one opinion and if you replace the whole unit get more than one bid. Make sure all of the bids are for the same tonnage, or btu unit. Some lower bids are for a smaller unit that won't keep up after it has a little wear or the coils get a little dirty. If your unit is more than ten years old you should consider a new one. If not, if you can find a honest company it should be worth replacing the compressor. Replacement compressors, if installed by a certified tech, have at least a five year warranty.
Jul 06, 2010 | Weather King 10AJA6001AH Air Conditioner
EC119SA less than one yr old just has started showing signs of low air volume. Was using it to clean off work bench, first blast of air was strong then quickly has very little pressure. The pressure gauge...
hi there, if there is enough air pressure present in the compressor the motor will stop,the pressure switch is working.if there is a good pressure at start then suddenly lost the pressure,there is no maintaining pressure to use but on the pressure gauge appear to be have a good or enough air pressure. check if the pressure gauge have enough air pressure the motor is stop,meaning the cut out limit switch stop the motor,if you loosen the air pressure from the valve until the cut in pressure attain or meet the motor will run again there will be a cycle process of differential pressure of cut in and cut out set up on pressure switch. checking the compressor,be sure there is a high pressure on compressor and the compressor motor is stop,shut off service valve and disconnect unit device / tools from the service valve. if the compressor have enough air pressure crakc down the service valve and observe the pressure until it run again the compressor motor,if the pressure maintain the pressure you need to clean the bench, the problem is the unit device/tool you use is defective, but if the maintaining air pressure in the compressor is lost due to malfuction of motor and the compressor engine. check the pressure switch, check the motor function by loosening the belt and run the motor w/o the compressor engine if it is tripping brought it to service center, check also the lubricant oil,if neccessary change oil.have a nice day and fix my rate thanks a lot.
Apr 20, 2010 | Hitachi EC119SA Twin-Stack Air Compressor...
Triumph Tiger Air in braking system in spite of bleeding a few times
Try bungee tying your brake lever on over nite, the pressure will force bubbles to the top,I hope you did not shake the new brake fluid when you got it as will absorb air easily allways let it settle for a hour after transport and allways use new fluid as old stuff absorbs water (Hydroscopic).
Mar 05, 2010 | 2006 Triumph Tiger
Weather King 10AJA6001AH Air Conditioner with bad compressor
If it is five years old it is either right in or out of warranty a service tech can determine this through the serial number. If not the unit is only a little bit more to replace than the compressor. A replacement compressor is only warrantied for one year verses a unit replacement with five years on the compressor and one year parts and labor.
Oct 04, 2008 | Air Tools & Compressors
Air Tools & Compressors Logo
358 people viewed this question
Top Clarke Air Tools & Compressors Experts
John Trevino
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Clarke Air Tool and Compressor Expert? Answer questions, earn points and help others
