From the sound of things I think you need to replace your hot and cold water tap washers. this should solve your problem, if you are unable to do this I suggest getting a plumber to do it. Also while they are at it ask them to receed your fittings before putting new washers in, this will make washers last longer. Hope this helps.
If it has a single valve in the center you have gotton dirt in the valve and this is stopping the water from flowing, it is notto diffiuclt to fix if you know how to turn the water off let me know and I will tell you how to take it apart and clean it.
