Question about Dell OptiPlex GX1 PC Desktop
My dell gxa is detecting cdrom but does not boot with 98 or xp and after a while it goes to hard disk.....
  • 74 Answers
Try to change your booting setup in your bios maybe it reads first the hardisk not your cd rom.
Posted on Oct 06, 2009
None of the keys work to get into bios setup so that i can change the boot order. i need to reinstall windows xp pro because of the error code 0x07e bsod
As SOON as you press the power on button, start tapping on the F12 key.
When the Boot Device list appears, use the Up, or DOWN arrow key to highlight CDROM.
(The option goes by very F-A-S-T.
It's easy to go right by it. Don't wait until you see the Dell logo splash screen)
Press the Enter key.
Put the Restoration Disk, or Windows XP full installation disk in the optical drive.
Press any key to Boot from CDROM.
For additional questions please post in a Comment.
Regards,
joecoolvette
Jul 24, 2011 | Dell Vostro 1710 Laptop
Corrupt missing C:\windows\system32\config\system no original windows xp oem disk cannot use recovery console cannot get to a c:/ prompt no floppies have cd rom bios does not support usb boot possiblity...
Your master boot record of the hard disk is damaged. I suppose you have access to CDROM through bios. But it is not clear from your question. Set CDROM as first boot device. Get a bootable CD & make sure that it contains fdisk utility. Boot from it & you will get a:\ prompt. at a:\prompt type fdisk/mbr & press enter. Your master boot record of hard disk will replace. Now you will be able to go to c:\ prompt. Use your your xp cd to recover your windows.
-sonsunny
Jul 14, 2011 | Dell Dimension 8250 PC Desktop
Dell Optiplex GX270 will not boot from disk
Does it show
boot from cdrom?
did you answer (Y)
then hit spacebar?
have the bios set to boot from cdrom/first boot device cd-rom?
If any of these settings are not applyed you will not restore xp on your computer
go into bios and conferm settings
first boot device if set as floppy or hard drive change to cdrom
on some systems you can hit the (f12) key to bring up a boot window and select the cdrom and boot from there then it will ask the normal questions
Dec 03, 2009 | Dell Optiplex GX270
Getting problem in formatting the IBM PC
check if the cable from the cd rom connected to your ibm pc if its ok , also check the master, slave configuration pins into the back of your cdrom. make sure that theres no conflict between the hard disk and the cdrom. Your cd rom may probably cannot be detected. make sure that it is working first. then install the hard disk. The hard disk must be in primary master and the cd rom must be in primary slave. then try booting it to your cd rom. also, try checking if your windows xp setup disk is bootable, it means that it can boot from cd rom. PM me if you have other experiences after doing what i adviced. Thank You.. heres my email. jmizpahadonai777@gmail.com
Aug 07, 2009 | IBM Thinkcentre 8185 PC Desktop
I want to boot from cd to change windows from xp to 98
enter the bios set up on start up. Go to boot sequence, change 1st option to cdrom instead of main drive. Save and exit. Let it boot up, put 98 disk in cdrom. Shut down, reboot and win 98 installation will begin asking you to over write existing ops sys. Choose yes and the install should be a breeze after this. Once xp is installed, dont forget to return to the bios and change back your boot sequence to hard drive as primary /master.
Sep 26, 2008 | Compaq Computers & Internet
Wd300ab
Please check if the hard drive comes with small wire bridge inserted in master pins (not in slave or cs) all the disk come with three diff posisions, for this small bridge comes in colours black , white or blue. in ide hard disk.
after that please goes the computer to setup F2 and start in boot seccion and active only ide cdrom ( please don't use a hard drive or floppy options.) other systems with f12 and u can star with cdrom and insert the operating system(windows 98, Xp or vista and the machine starting the load againg. please check step by step for replace the missing information.
May 17, 2008 | Western Digital Caviar® WD300AB 30 GB...
Boot problem - Win98SE
change the boot sequence in bios set up ...
keep in this order
first boot device as floppy
2.hard disk
3.cdrom
then save it and then have a check it should work ..
you have not mention hard disk here so i think the hard disk is not detected there may be some loose contact inside and it is not connected properly so it is not able to verify DMI pool ...
if so connect the hard disk properly then then have a check it will surely work..........
Feb 23, 2008 | Microsoft Windows 98 for PC
Installing XP on a dell computer
try to go to bios and load bios defaults, esc then save and exit. boot from the cdrom by, tapping on F12 at dell screen. at boot menu screen, choose cdrom, press enter, when you see the message, PRESS ANY KEY T5O BOOT TO CDROM, hit any immediately, that should allow you to install xp directly from the cdrom.
Feb 13, 2008 | Dell Dimension 4600 PC Desktop
Boot problem
The BIOS is detecting the cdrom but it is not detecting the Bootable cd I have in the CDROM
Nov 07, 2007 | Dell PowerEdge 2600 Server
Used Dell Dimension 3000 drive issues
If you mean you need to install windows, you need to set your cdrom drive as first boot device in advanced bios settings or it will try to boot into a non-existent windows. Make sure your hdd is showing as the master drive, save settings and exit bios. Re-boot pc with windows disc in cd drive and hit enter when prompted to boot from cd.
Jan 26, 2007 | Dell Dimension 3000® Pentium® 4...
Dell OptiPlex GX1 PC Desktop Logo
97 people viewed this question
Alun Cox
