Question about Huffy Diego 10 in. Bicycle
Where can I buy just the training wheels for a 10 in. bike?
Can I use 12in training wheels on a 10 in. bike
Posted on Jul 26, 2011
  • 718 Answers
Your best bet is the store you bought it from or you local bike shop. Try online also.
Posted on Oct 08, 2009
2 Suggested Answers
  • 6 Answers
SOURCE: install training wheels
when installing the training wheels, check to see if it is put together in this order ....flat washer, training wheel, flat washer, lock washer, nut. I hope this helps. If you are missing any of these you can find them at any auto parts store, Wal-mart, or hardware store such as Lowe's or Home Depot. (Be sure to take the traing wheel and nut to make sure you have the right size)
Posted on Dec 28, 2009
Hi I have a Revolution Sabre road bike with a 7 speed shimano cassette. Can I change to a 9 or 10 speed and if so what would I need to to at the minimum cost.
Not practical, as you would need to change far too many parts of the drive train, and the rear wheel, at a significant expense. Two of the gears added would be higher than your current high gear, and therefore of very limited use (no, they will not make you go faster). If you feel you have to have a 10 or 11 speed then sell your bike and buy a good used one.
I’m happy to help further over the phone at https://www.6ya.com/expert/donald_f2ed37026a3ac881
Sep 06, 2017 | Shimano Cycling
Bought a 16 inch rosebud girls bike. No kickstand was in the box. Are you suppose to lay it down when u are through riding?
Apparently. They come with training wheels so how would they fall over? You could go to a Bike Shop and see if they have small kickstands for it when the training wheels come off. None of MY bikes have kickstands (or training wheels). Teach her to lay it down gently on its left side.
Aug 23, 2011 | Cycling
Dear sir/madam, I am using a Scott Sportster P4 for triathlon trainning but the problem is : the suspension is too heavy. What would you sugest ? I want to replace the suspension for a carbon fork. I am...
The fork's weight is NOT your limitation but its bobbing may alter your spin enough to negate the best effects of pre-race training. I'd definitely ditch the suspension if you ever anticipate having to stand and pedal.
Get a Bike Shop involved in your fork modification as you'll probably have to cut a new one to size anyway.
Static equipment weight is no big deal. Go on a diet. You'll never safely take 10 - 15 lbs off a bike.
Lighter wheels and rider aerodynamics are where sustainable speed is at.
If you have any realistic expectation of maintaining a racing speed in a triathlon you're going to need a relatively aerodynamic position. Get a clip-on aerobar and train until it feels like a position you can maintain indefinitely.
I'd stop messing with the geometry of this bike and get a true racing bike with an aero-bar.
Feb 13, 2011 | Scott Sportster P4
Hello, I bought my little girl the huffy 12in disney princess bike (blue) already assembled from walmart. she tried to ride it today, but when she pedals the back wheel spins, but the training wheels and...
ONE AT A TIME, loosen the nuts securing the training wheels to the rear axle and slide each one upward a little bit so it float a little bit off the ground when the bike is vertical, then retighten the nut.
As she develops her handling and balance skills she'll need less help from the training wheel. So you can gradually raise them a bit higher as she masters balance and then she'll develop the 'lean' for turning. Ultimately, you remove them entirely.
I hope she's wearing a properly-fitted helmet.
http://www.nhtsa.gov/people/injury/pedbimot/bike/easystepsweb/index.htm
Jan 27, 2011 | Huffy 12 in. Girls Disney Princess Single...
20 inch Slumber party bicycle will not accept training wheels? Rear threaded axle is not long enough to allow for training wheels (that i cna find)
Yes you can add training wheels to this bike. The origional axle is too short, however, if you are mechanical enough, you can remove the axle and buy a longer one. I did this for my daughters bike, and for abot 5 dollars you can pick up a longer axle which will accept training wheels. But be warned, there are several bearings and you need to place them back in the correct position or the bike will not work.
Dec 27, 2010 | Dynacraft Cycling
The training wheels won't reach the ground. I loosened them and lowered as much as possible and theare still above the back tire and will not touch the ground at the same time
The training wheels are not meant to be as low as the back wheel. The idea is that the child learns to balance the bike but if it goes over to one side the training wheel touches the ground and stops the bike from falling
Dec 20, 2010 | Dynacraft Girls 16" Barbie Bike
18inch misty girls bike any training wheels available?
Yes, you can use the same training wheels that are intended for 20" wheeled bikes. check with your local bike shop, they should have in stock this time of year. Or you can get on-line of course.
Dec 18, 2010 | Cycling
I bought a set of EZ trainer training wheels at Goodwill for my Granddaughter a couple of months ago. I was going to put them on her bike today but then realized that there was no hardware with it. Only...
Doubtful, There may be a spare parts kit available through a distributor that a bike shop can order for you. And/ or if the particular shop carries alot of childrens bikes then they may have some spare hardware.
Training wheels are the kind of product that is carried as a complete unit, and ordering spare bracket kits which are not much less than the complete kit is generally not worth it to a shop.
Go into your local bike shop and see what they can do for you, Who knows they may have the parts and will install for you as well. Good luck.
Nov 22, 2010 | Cycling
Install training wheels
Dec 27, 2009 | Huffy Disney Princess 16 in. Girls Bicycle
Huffy Diego 10 in. Bicycle Logo
61 people viewed this question
Top Huffy Cycling Experts
Michial Gueffroy
Charles T Nevin
Charles T Nevin
Are you a Huffy Cycling Expert? Answer questions, earn points and help others
