Question about Dyson DC07 Animal Bagless Upright Cyclonic Vacuum
CUTS OUT MOTOR OVERHEAT?
DC07 keeps cutting out motor overheat?
  • 372 Answers
Try this site for help.
http://dc07.atspace.com/
Chris..
Posted on Dec 23, 2007
Dyson dc07 is getting really hot but is NOT cutting out
Hi there, it's Jack at Dyson.
It's normal for a vacuum cleaner's exhaust air and casing to become warm in use, due to the heat created by the motor when it's running. Dyson vacuums are equipped with a thermal cutout device, and this will shut the vacuum down if it starts to overheat.
It's worth checking your machine for blockages, and giving the pre-filter a wash - we recommend doing this at least once every 3-6 months as shown in the video attached. Use cold water without detergent, and allow at least 12 hours for both parts of the filter to dry completely before replacing them.
As long as your DC07 is picking up as normal and isn't making an unusual noise or smell in use, there shouldn't be an issue. But if you're concerned, you're welcome to reach out to our experts for further advice. You can reach us by calling 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Jun 05, 2014 | Dyson DC07 Bagless Upright Cyclonic Vacuum
My dyson DC07 is getting hot but NOT cutting out
Hi, it's Jack at Dyson.
Is it possible to overheat the motor?
This can happen , normally if the filters are kept clean and replaced now and again the motor should last quite a few years if it does overheat then it has a thermal cut off that resets after it cools down ,,Hope this is of some help
Feb 22, 2011 | Dyson DC07 Animal Bagless Upright Cyclonic...
Dyson DC07 keeps cutting out and smells of
does it smell like an electrical burning smell? sounds like your motor has went bad.
Mar 06, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
Dyson dc07 keeps cutting out after few minutes
This is a sure sign of a blockage. The motor cuts out because it gets too hot and will start again when it has cooled. Follow the instructions in your user manual for clearing blockages (you can download a copy from the Dyson website if necessary). Make sure the washable filter is clean too (and completely dry before you use it).
Jan 15, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Dyson working one moment then it completely cuts out
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Most Dyson cleaners have a thermal cut-out to protect the motor from overheating in the event of a restriction to the airflow. So, if anything causes it to overheat, it will switch off. If this happens, leave the cleaner switched off for at least two hours, as it will not start again until it has cooled down.
The most common cause of a cut-out is that the cleaner has a blockage or the filter needs washing. A high room temperature may also trigger it. Before you continue vacuuming, ensure the filter is clean and there are no blockages. You can download the user guide at www.dyson.co.uk/support/. Just click on ‘Get Expert Help’ then ‘Using my Dyson product’ then ‘User Guide’.
Dec 24, 2009 | Dyson DC07 All Floors Bagless Upright...
Motor overheats and shuts off
The priamry cause of motors overheating is that the filters are not cleaned or replaced frequently enough. Once a motor starts to overheat, it has already been damaged and even after the filters have been cleaned, may well still overheat and cut-out. The motor has a built in over-current trip to protect itself (and you if it seriously overheated). This normally automatically resets itself, however if the motor has just about had it, the moemnt it is switched on, it just trips again.
Replacement motors are avaible on eBay for about £25, however repalcing one requires good DIY skills and tools.
Have a look at www.dysonmedic.com and see if you feel you can tackle it yourself. If not, take it to a repair shop or call the Dyson helpline.
Oct 17, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Dyson DC07 motor overheats
the motor brushes are worn down and can be expensive to get someone to fit them for you so i think its time for a new cleaner
Aug 23, 2009 | Dyson DC07 Allergy Blue/Turquoise Bagless...
Machine cuts out due to getting hot
most vacuums have a heat resister in when they overheat they cut out, this is normally because they are full up, got a blockage or the filters need cleaning, suggestions are, clean filters, empty and check for blockage.
Jul 13, 2009 | Dyson DC07 Allergy Blue/Turquoise Bagless...
Dyson Quits
cut out switch on the motor needs replacing this overheats and cuts of the motor when the motor cools down it will start again you have to keep both filters and cyclone clean and free of dust or after replacement the same will happen again
Sep 04, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Dyson DC07 Animal Bagless Upright Cyclonic Vacuum Logo
243 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
